AFR 290 489 dyno - Chevelle Tech
 9Likes
post #1 of 19 (permalink) Old Jul 10th, 19, 10:15 PM Thread Starter
AFR 290 489 dyno
Friday I'm getting my engine dynoed. Anyone want to guess some numbers?
Gen 6 454 block
0 decked
Scat 4.250 crank
Compstar 6.385 rods
SRP 18cc pistons
AFR 290 angle milled 95 cc
Port matched vic jr
Bullet solid roller 257 in 262 ex .685 .680
Pro systems 1000
Devain lil evil 1230
Hoping for around 750. Am I crazy?
489AFR290 is offline
post #2 of 19 (permalink) Old Jul 10th, 19, 10:18 PM
Gary
Re: AFR 290 489 dyno
685 is my guess
gnicholson is offline
post #3 of 19 (permalink) Old Jul 10th, 19, 11:14 PM Thread Starter
Compression is 12.33 to 1
110 race fuel
post #4 of 19 (permalink) Old Jul 10th, 19, 11:51 PM
Gary
ok i should have looked at your head ccs. the heads are a little small to make big power but im revising my guess to 730
post #5 of 19 (permalink) Old Jul 11th, 19, 12:14 AM Thread Starter
AFR says heads flow 375 cfm @.700. I've looked at some other 489/496 builds with these heads and they put up some pretty impressive numbers. I think I seen one vortecpro did 830 on a 540 build with these heads. Although he probably did some massaging to them. 730 is actually what I was thinking.
post #6 of 19 (permalink) Old Jul 11th, 19, 1:09 AM
Anything over 700 I think would be a good day. Should be a nice broad torque curve.
Tarheel Chevelle likes this.
Youtube Channel.
Instagram:
Twitter:
-SS454- is online now
post #7 of 19 (permalink) Old Jul 11th, 19, 9:02 AM
Gary
if those heads flow an honest 375 on a 290 cc port that would be impressive to say the least especially out of the box.
post #8 of 19 (permalink) Old Jul 11th, 19, 9:33 AM
Wait? Are you Tom from NY?
post #9 of 19 (permalink) Old Jul 11th, 19, 9:51 AM
James
Show me the numbers! Looking forward to seeing the results. Hope you hit 700.
69Chvll is offline
post #10 of 19 (permalink) Old Jul 11th, 19, 2:24 PM
Carb may be small for it but it should make north of 700. How far north remains to be seen. Interesting build! 750 would not surprise me but I think it might be a little high.
'66 SS Chevelle
565 BBC Mamofied 300cc Ovals
4.11 12 bolt
Best e.t. to date [email protected] @115.31
1.301 60' 3355 pbr 1.306 3055S
Stokerboats is offline
post #11 of 19 (permalink) Old Jul 11th, 19, 6:15 PM Thread Starter
I'm running 2 different carbs on it. The one is a pro systems 1000. The other one is a BLP little bo basically that robbie devain built. Its 1230 cfm. From what I've read it flows about the same as a 1050 dominator.
post #12 of 19 (permalink) Old Jul 11th, 19, 6:17 PM Thread Starter
Yes
post #13 of 19 (permalink) Old Jul 12th, 19, 1:33 PM Thread Starter
Dyno postponed until Monday due to a medical issue with engine builder. So got a few more days to guess if you’d like.
post #14 of 19 (permalink) Old Jul 12th, 19, 6:00 PM
When all the hoopla dies down after the session, would you please post a couple of pictures of the dyno being driven around the block, please. Thanks.
Dave Ray is offline
post #15 of 19 (permalink) Old Jul 12th, 19, 6:16 PM
My 496 made 630 HP with way less cam, way less compression, way less carb and reworked OEM iron heads that flowed a little over 300. I think you'll make 730 easy or something is wrong.
70 Camino...Roller
Tommy the Cat is offline
