Correct Oil? - Chevelle Tech
 10Likes
post #1 of 16 (permalink) Old Jul 7th, 19, 4:45 PM Thread Starter
Matt
Correct Oil?
Hello All,
I found the following block number for my Chevelle: 14088548
From www.enginelabs.com I decoded the following: 14088548 Small Block V8 1986-1988 350, 2 bolt or 4 bolt
When I changed the oil I put in Valvoline 'High Milage' 10w30 and a bottle of zinc engine additive.
I was talking with a friend who has been wrenching on old/classics for a while and he thinks I used the wrong oil. He recommends straight 30W engine oil with the zinc additive.
I thought since this was a 'newer', post 1975 engine, that the 10x30 would work best.
Thoughts/advice?
v/r,
Matt
mattimuss is offline
post #2 of 16 (permalink) Old Jul 7th, 19, 5:54 PM
Re: Correct Oil?
I think your fine with the valvoline hi mileage 10/30, as long as you’re in the ballpark of 10-20 psi of oil pressure at hot idle. I’m assuming this is a stock oem motor with flat tappet cam?
Video:
fr8dog is offline
post #3 of 16 (permalink) Old Jul 7th, 19, 6:20 PM
Re: Correct Oil?
I think you should no use engine oil and add a zinc additive. Why not just use an oil that has the zinc included with the friction package? Valvoline VR1 for example (available at most auto parts stores), is the oil you need and 10w30 is fine for your application. There are others that will work just as well as others will chime in with their preference.
boyd66k20 likes this.
oldcutlass is offline
post #4 of 16 (permalink) Old Jul 7th, 19, 6:53 PM
Re: Correct Oil?
San Diego? Nice engine-friendly climate. I think that an 86 - 88 year model Chevy V-8 equipped automobile owners manual would specify 10-30. Single grade oils are obsolescent for cars, I use 30 wt in my lawn mower. Zinc additive to the oil? You are paying good money for oil that has the additives needed to perform to spec, whether its SF for a chevy V-8 back in the 60's or whatever it is today. By the way, modern oils are backward compatible. Zinc is a metal. Zinc atoms are combined with other atoms to create a chemical compound. There are other chemical compounds that do the job in modern oil formulations that the zinc-containing compounds in the additives of the day did before. Forget the single grade and zinc additives. High-mileage? The marketing people needed another means of hype, so they came up with High-Mileage. The chemists made up a seal-softener just in case your "hi-miles" engine is suffering from hardening of the arteries...I mean oil seals. Well, unintended consequences can mean damaged seals and oil leaks. "Seal Job in a bottle"? Good luck. Lose the high-mileage too.
Just another $0.02 p.s. If you have a real honest-to-goodness race engine, you might need a "racing oil", but I'd wager that you don't have.
JJ'65 is offline
post #5 of 16 (permalink) Old Jul 7th, 19, 8:27 PM
Al
Re: Correct Oil?
For your climate area 15-40 VR RACING OIL by Valvoline would be a better choice. But I would go ahead and run what you have until the next oil change. Use Wix filters not the Fram joke of a filter.
JoeGibb racing oil is another top performer.
In my opinion you want the high zinc oils to protect that flat tappet cam.
fr8dog and shovelrick like this.
DUTCH MAX HEADWORK is offline
post #6 of 16 (permalink) Old Jul 7th, 19, 10:17 PM
Gary
Re: Correct Oil?
I haven't searchd this, and others here with a lot more knowledge can correct me, but isn't the late 80's about when GM started putting roller cams in the SBC? He said it was an 86-88 motor. To be safe I would use an oil with high ZDDP until I was sure what I had because it isn't going to hurt running it in a motor w/o converters, but you may have a roller in your motor and not need to worry about the zinc levels.
People here will help you figure out what you have, with a little more information from you.
Gary
(oo_____oo)
gman628 is offline
post #7 of 16 (permalink) Old Jul 7th, 19, 11:29 PM
rick
Re: Correct Oil?
Isn't 86 and up sbc with bolt through VC a roller cam/lifter engine? if not I like Valvoline VR1, watch Amazon and you can find it on sale some times
shovelrick is offline
post #8 of 16 (permalink) Old Jul 7th, 19, 11:51 PM
Re: Correct Oil?
Some of them, not all. His is not.
post #9 of 16 (permalink) Old Jul 8th, 19, 12:10 AM
leo
Re: Correct Oil?
10W30 oil is fine, if it isn't a fresh rebuild, no zinc additive needed. I started a fresh rebuild on Mobil 1 at the advice of the machine shop that did the work, flat tappet cam and all.
hydro462 and shovelrick like this.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #10 of 16 (permalink) Old Jul 8th, 19, 8:23 AM
Re: Correct Oil?
I have been using Mobil 1 5w30 for years in four different flat tappet engines without any issues. One was a Pontiac 462 with a big cam and heavy springs, never used any additives.
Sam's Club sells the Mobil 1 5W30 fairly cheap..
I also only use Wix oil filters.. Lots of times they are renamed as the parts stores brand..
shovelrick likes this.
hydro462 is offline
post #11 of 16 (permalink) Old Jul 8th, 19, 9:55 AM
rick
Re: Correct Oil?
Napa Gold is also a Wix filter
post #12 of 16 (permalink) Old Jul 8th, 19, 11:54 AM
Harry
Re: Correct Oil?
Mobil 1 - 15w50 has much more zinc additive for flat tappet motors. Zinc level is 1300, Phosphorus 1200. This is the only Mobil 1 synthetic oil designed for older motors that need zinc. It specifically says for "flat tappet motors". I have used it in my Chevelle and old Flat Tappet Land Cruiser for years. You can get it at Walmart for a good price for 5 quart jug.
Note: I live in a hot climate, so, 15w50 is a fine weight oil for me.
Harry
hjdca is offline
post #13 of 16 (permalink) Old Jul 8th, 19, 6:29 PM
Harry
Re: Correct Oil?
Here is the link to Mobil 1 specs - 15w50 has the zinc --
https://mobiloil.com/~/media/amer/us...pecs-guide.pdf
Harry
hjdca is offline
post #14 of 16 (permalink) Old Jul 8th, 19, 10:11 PM
Mr Bill
Re: Correct Oil?
I am going to add that unless you know the engine has never been rebuilt or modified in any way, that number does not mean a thing other than it is a 4" bore 1 piece rear main seal block. You are probably safe with what you used but if the engine originally was in a car it might be a roller cam and there is no need for the zinc. No way to know without tearing it apart though.
I will agree with Eric that if you do need the zinc, use an oil that already has it rather than an additive. No need for 15W50, way to "thick" for that engine. 10W30 is fine. GM probably called for 5W30 in those years.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #15 of 16 (permalink) Old Jul 8th, 19, 11:04 PM
Re: Correct Oil?
14088548 casting number is not a roller motor.
