Roller cam choice - Page 2 - Chevelle Tech
 3Likes
post #16 of 27 (permalink) Old Jul 5th, 19, 6:48 PM
Take a look at these. Summit has them too but Jegs has more info on them
http://www.jegs.com/i/Manley/660/22410-16/10002/-1
68Maliblue is offline
post #17 of 27 (permalink) Old Jul 6th, 19, 10:11 PM
Re: Roller cam choice
If you like your Comp XE cam they have a hydraulic roller line as well.
406 SBC, 9:1, AFR 195s, TH400, Coan converter, 3.50
ProCharger D1SC, 10 psi., AIS meth injection, Carb Shop 750 (Sniper EFI conversion 2019)
1.319 60', [email protected] on pump gas
Greg Owens is offline
post #18 of 27 (permalink) Old Jul 10th, 19, 4:28 PM Thread Starter
Justin
Spoke to Howard’s cams and they said that I could shim my current valve springs to work. I need an installed height of 1.800” mine are currently at 1.850. Here’s the valve spring specs currently on the heads:
1.250 Hydraulic Valve Spring – CC 981,
100 lb Closed, 300 lb Open,
1.850 Installed Height,
.525 Maximum Lift
JF74chevelle is offline
post #19 of 27 (permalink) Old Jul 10th, 19, 6:58 PM
I'd think about some better springs. How high do you want to spin it?
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #20 of 27 (permalink) Old Jul 10th, 19, 7:43 PM Thread Starter
Justin
I agree I’m not comfortable running those springs. I’d like to go about 6k or so.
post #21 of 27 (permalink) Old Jul 10th, 19, 9:39 PM
I'm at 165/420 I go to about 6500. First set was 140/380 Eric thought he saw some evidence of float after I dynoed it.
77 Monte
post #22 of 27 (permalink) Old Jul 10th, 19, 9:57 PM
Ryan
Give Chris Straub a call and tell him what you have and what your goals are. He can recommend you a semi custom cam designed to work specifically with the flow characteristics of your heads. That’s what I did and my 383 made 505 hp at 6k rpm with 200 cc Edelbrock etec 200 heads(which are ok but not great). Chris knows his stuff.
1970 Malibu
383, 10.3:1, etec 200 heads, isky 280 mega, holley 770,
th350, 2600 stall,
12 bolt, 3.55 eaton posi
no time slip yet
just got out of paint
ppg arrival blue metallic
black SS stripes w/ blue pearl
2/75NastyNewbs is offline
post #23 of 27 (permalink) Old Yesterday, 9:09 AM
Lew
Springs are relativley inexpensive and should be based on the cam you buy. I would get that along with the correct retainers. Remember if you shim .050 you loose that in lift capacity as the max lift is probably based on some coil bind number. so your 525 max lift becomes 475 max lift.
Lew540 is online now
post #24 of 27 (permalink) Old Yesterday, 11:57 AM Thread Starter
Justin
Okay, I spoke to Chris (awesome customer service) and he said he has a roller cam that fits the bill. He said “That GTA cam of mine has made north of 400/400 in similar projects and will give you both power and reliability.” What do you guys think? Whole kit would come with proper valves springs and lifters etc.
These are the specs.
Lift is with 1.5 Ratio Rocker
Adv. Dur. Int/Exh 280/294
Dur. at .050" Int/Exh 221/235
Valve Lift Int/Exh .510/.510
Center Lines Int/ Exh 104/112
LSA 108
post #25 of 27 (permalink) Old Yesterday, 9:59 PM
Ryan
I think that’s pretty spot on for a nice street cam. 221 duration on the intake is in the ball park for a 350 and the 108 will make your power come on strong and give you a good rumble. You should have pretty good vacuum numbers too. I ordered the lifters from Chris also. Nice Morel hydraulic rollers. I ordered the matching clay smith springs after the fact. I had the motor apart at the time so I had the local machine shop set up the heads. Came out at 420 lbs over the nose of the cam. Called clay smith and they said it was fine. I’m rambling at this point. Let us know how it runs when you get it back together. I think it will be a very nice running small block with a very usable powerband on the street.
1970 Malibu
th350, 2600 stall,
no time slip yet
post #26 of 27 (permalink) Old Today, 12:28 AM Thread Starter
Justin
Would this cam really benefit from using 1.6 rockers?
post #27 of 27 (permalink) Old Today, 6:26 AM
Don't cheap out on the springs. I used the AFR 8019 springs. I swapped mine out before running the engine and used a Lunati .535/.550 231/[email protected] hydraulic roller in my 355 with 195 AFR heads.
bracketchev1221 is offline
