I’m not up to date on the Gen V and 6 454’s. I understand that they went to a roller cam and 1 piece rear main seal at some point. In what models and years could these be found?
Devin,
I am pretty sure 1991 was the first year of the new Big Blocks. Main difference is the one piece rear main seal crankshaft and different water passages in the heads.
I prefer the Gen 6, started in 1996. Priority main oiling, OEM hydraulic roller cam/lifters, less rear main seal leaks. I'm hoarding them, I snatch up every one I find at the right price.
The Gen 5 blocks have no provision for a fuel pump and no place to mount the z bar in a clutch application. I was talking about them the other day with a guy and he said all they are good for is pumping water " well engine" I agreed completely. Too many issues to be worth messing with. Stick with gen 4 and gen 6 blocks.
Most Gen 6's don't have fuel pump provisions, either. Once in a while you see one that was a crate engine, those have it. Most of the production blocks don't.
So we’re looking at a Gen 6 454 that a former coworker has in his early 70’s K10. What is required to drop it into my son’s 65, other than the obvious headers? I know it will need a short water pump setup, what about the oil pan? Is the flexplate different with the 1 piece rear seal? Anything else?
If it's a GMPP crate engine (either 454 HO or ZZ454) I'd think twice about it. See run, drive it if you can. There were issues with the Mexican-built crate engines.
Flexplate is different, changed the bolt pattern with the 1-piece rms.
Make sure you know if it does or doesn't have provision for fuel pump, get that handled before you drop it in.
Nothing wrong with the Gen V's or 6 's. Ive used both and run a Gen 6+ 427 ( home built not ZZ ) in my Camaro now .
If you want to use factory iron heads , hey whatever, you'll need a different gaskets. Its not an issue with aftermarket heads. If you also run a mechanical fuel pump you cant with the Gen 5. I havent run one in decades so it saves me from buying a blockoff plate. The boss is there for a clutch shaft pivot ball . Drill and tap. 20 minutes you'll never get back. No big deal.
I do prefer the Gen 6 architecture tough. The hydraulic roller setup is pretty nice and double roller chains are available. Bosses for knock sensors...check. I run Holley HP injection and the knock sensor capability is there without any shenanigans. The Gen 6+ ZZ blocks have everything. I havent sonic tested them though . GM says .060" overbore is max although I think they said that with the Mark 4 blocks too.
Do not buy the Canton pan. It sits well below the crossmember on chevelles and camaros and you WILL impact if the car is lowered. Ask me how I know. Use the Moroso kickout pan ( with a mini starter ) and use right stuff sealent on the front and rear main where the pan seals against the caps and you'll be good to go for leaks for life.
As someone else mentioned the bolt pattern is the same on the cranks as the old Mark 4 . If you are having an engine built or doing it yourself you are going to balance the assy anyway so it doesnt matter. Just pick one format and stay with it and NEVER let them add or remove metal from the flywheel/flexplate. I use a Mark IV 23 lb flywheel on my 427. No issues since its internally balanced anyway.
Thank you for your personal experience. Would you have the part number for the Moroso pan that fits? I've been looking and not found one made by them yet.
Related Threads
Team Chevelle
5.1M posts
115.6K members
Since 1998
