GDI engine problems for consumers. - Chevelle Tech
 2Likes
  • 1 Post By Enganeer
  • 1 Post By BillK
post #1 of 3 (permalink) Old Jun 21st, 19, 10:38 AM Thread Starter
Everything that I have learned from these new gasoline engines is this: Less fuel more power. Downside is that in a few miles carbon builds up on the valves. make sure you use top tier gasoline. I think the consumers might lose on this deal.
Slick87gn is online now
post #2 of 3 (permalink) Old Jun 21st, 19, 11:23 AM
Re: GDI engine problems for consumers.
The carbon build up on the GDI engine comes from oil drawn in from the crankcase ventilation system that settles on the intake valves. Since the GDI engines inject fuel direct into the cylinders rather than into the intake, there is no gas to wash past the valves to keep them clean.
I know alot of people are running oil / air separators on the crankcase ventilation line to keep the oil out of the intake.
Cam likes this.
Instructions...All I need is the exploded view.
Enganeer is offline
post #3 of 3 (permalink) Old Jun 21st, 19, 12:34 PM
Mr Bill
Actually on the GDI engines oil is probably more important than fuel. You absolutely have to use a top quality oil that meets all of the manufacturers specifications. It is oil vapor in the pcv/intake tract that is causing the buildup.
I have some pictures somewhere of some GM valves that were so loaded with carbon that its amazing that any air could get past them. I will try to find them and post them.
LeoP likes this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
