BBC spark plugs 🤣🤣 - Chevelle Tech
post #1 of 9 (permalink) Old Jun 12th, 19, 5:04 PM Thread Starter
BBC spark plugs 🤣🤣
Well, if my hunch is right I think Iíve seen it all. I had to remove my right side header to install my tubular upper a frame. So I thought I should remove the plugs first so I wouldnít break one. I was surprised to find they were all only finger tight 😳😳. I removed them and the header, installed the a frames. Put the header back on and worked on the disc brake installation. Went to put the plugs in and screwed them in finger tight got my socket to tighten them. WOW, the socket only spun around the plug 🧐. I unscrewed one and took a couple of pics. I think the squirrel I bought the care from had 13/16 plugs screwed into a hole for a 5/8 tapered seat plug 🤣🤣🤣 someone please verify and tell me what plug I need for a 502 big block with a 750 dual line Holley. Pics attached. Can get more
ID:	595542   Click image for larger version
ID:	595544   Click image for larger version
ID:	595546   Click image for larger version
suprdave1 is offline
post #2 of 9 (permalink) Old Jun 12th, 19, 5:38 PM
Cory
Re: BBC spark plugs 🤣🤣
Common mistake since some BBC heads are machined for washer seats and some for taper seats. Without knowing the vintage and/or casting number of the head and if the parts counter or website supplies plugs for the year of the car...the result can be as you discovered.
YOUR PICTURED HEAD appears to have tapered seat but that's no guarantee the other head is the same.
dream66 is offline
post #3 of 9 (permalink) Old Jun 12th, 19, 5:58 PM Thread Starter
Iíll definitely check LOL. I couldnít believe it ran as well as it did with the plugs only finger tight. So I need an AC43T?
post #4 of 9 (permalink) Old Jun 12th, 19, 6:16 PM
Cory
R43T may be a better choice. Resistor plugs help to eliminate radio static.
I think that R44T (hotter than R43T) was the proper heat range for street driven cars but your modifications and usage may need a different heat range.
dream66 is offline
post #5 of 9 (permalink) Old Jun 12th, 19, 9:49 PM Thread Starter
Yea left off the R. Thanks
post #6 of 9 (permalink) Old Jun 13th, 19, 9:17 AM
Mr Bill
Dave,
You need to try and tell how long the plug threads need to be. Some of them use the long reach plugs and some use the short reach. If you had your head casting number it would make things a lot easier. Is this a GM crate engine 502 ?
I have a set of Mercruiser 502 heads here in the shop that have NGK BR6FS plugs in them. Taper seat short reach.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #7 of 9 (permalink) Old Jun 13th, 19, 7:24 PM Thread Starter
Not sure. Just got the car and making safe to drive first. He claimed it was a 502, but I cry liar liar pants on fire 🔥
post #8 of 9 (permalink) Old Jun 13th, 19, 8:01 PM
rick
If you post the block and head casting numbers someone here will know what you really have
shovelrick is offline
post #9 of 9 (permalink) Old Jun 13th, 19, 8:06 PM
SFD
Dave,
That’s a good plug, I’ve run those in my inboard with good results.
SFD is offline
