HP/Torque ? - Chevelle Tech
 7Likes
  • 1 Post By BRN2RUN
  • 1 Post By 427L88
  • 1 Post By 12stones
  • 1 Post By 427L88
  • 2 Post By 1975TypeS-3
  • 1 Post By Janih
post #1 of 9 (permalink) Old May 28th, 19, 12:49 PM Thread Starter
HP/Torque ?
Hi guys, I recently installed this motor in a 69 Chevelle and was wondering what kind of HP/Torgue it puts out. I didn't build it for racing but the throttle response and power are exactly what I wanted . So it got me thinking about the numbers ! You guys have tons of experience so I am sure you'll be pretty close.
Looking for flywheel numbers !
454 30 over . 461
PP 236 Heads
XE 268 H Comp Cams
Comp Cams Roller Rockers
TRW Forged Flat Top Pistons
1 3/4 Summit Headers
Edelbrock Performer 2-0 Intake
Holley 3310
HEI Dist.
I know this build is NOT a crazy high HP build , but it sure feels good cruising 1!
Janih likes this.
BRN2RUN is offline
post #2 of 9 (permalink) Old May 28th, 19, 1:29 PM
Re: HP/Torque ?
Hey, it has that early flat TQ curve that makes it fun! Whats in a number anyway!?
BRN2RUN likes this.
post #3 of 9 (permalink) Old May 28th, 19, 1:54 PM Thread Starter
Re: HP/Torque ?
So true...but go ahead let it fly, I won't be offended !
BRN2RUN is offline
post #4 of 9 (permalink) Old May 28th, 19, 3:25 PM
Re: HP/Torque ?
This link will provide an estimate, if you know the compression.
Rough Engine Horsepower Determination Program
BRN2RUN likes this.
70 LS5 convertible
12stones is offline
post #5 of 9 (permalink) Old May 29th, 19, 10:42 AM
Re: HP/Torque ?
Flat tops and 236PP heads = what compression?
BRN2RUN likes this.
post #6 of 9 (permalink) Old May 29th, 19, 11:25 AM Thread Starter
Re: HP/Torque ?
We were thinking 9 to 1 or so , the original were ditched and somewhere in the neighborhood of 7.8 .
BRN2RUN is offline
post #7 of 9 (permalink) Old May 29th, 19, 11:31 AM Thread Starter
Re: HP/Torque ?
These are the new pistons.
BRN2RUN is offline
post #8 of 9 (permalink) Old May 29th, 19, 1:14 PM
Re: HP/Torque ?
Flattop and open chamber heads get you 7.8:1 - the original with a dish would get you 7.3:1 even though it was advertised at 7.8:1 - bad habit GM has used over the years, either rate the compression with a smaller dish (or flattop) piston than what is actually used, or rate with a smaller chamber than what is used.
The standard 350 used in the 1970's and early 1980's was rated at 8.5:1 when the actual compression was 7.8:1. My 1982 Corvette was rated at 9:1 (actual 8.5:1), 1969 Grand Prix 400 rated at 10.5:1 (actual 10:1), 10.25:1 Olds 455 is actual 9.5:1..... you get the idea.
Your open chamber heads depending on where you get your information are listed as either 113cc chambers or 118cc chambers - most actually measure around 121cc chambers. If you use a .025" stock deck clearance using a flattop piston and about a .025" shim gasket you come up with a whopping 7.8:1 compression (real world). If you want 9:1 you need to go with about 100cc chamber head.
Steve R and BRN2RUN like this.
1975TypeS-3 is offline
post #9 of 9 (permalink) Old Jun 17th, 19, 4:59 PM
Jani Heino
Janih is offline
