Roller camshaft end play - Chevelle Tech
 5Likes
post #1 of 19 (permalink) Old May 23rd, 19, 9:22 PM Thread Starter
JOHN
Smile Roller camshaft end play
Hey, Guys I building a 396 ci BBC . I was wondering how to check the the camshaft end play with a roller cam . What type of timing cover to use , it will be going in a 67 chevelle so it will be a short water pump . What type gear set , type of thrust bearing and cam button . Thank you in advance for any help !
samsonace is offline
post #2 of 19 (permalink) Old May 23rd, 19, 9:31 PM
Re: Roller camshaft end play
I have not done this on a big block but I will this time. On my small block the 1st time out the car went really well then slowed down for no apparent reason I looked and found the cam button pushed the cam forward so here is what I did. I took a piece of angle iron and welded a solid washer on it, then I drilled holes on both sides to match the timing cover. I used threaded rod and nuts on either side to adjust it so when I put pressure on the cover the with my dial indicator set the cam so it only moved .005, it worked perfect so I used it on all the cams I ran in that engine. I will do the same thing on mu big block although the cover is stronger on the big inch engines. I guess you can always buy a fancy cover for like $200 but I like to put my money in other areas of the car. Since you have a short water pump it even easier, just stuff a feeler gauge until you get the cam to go fore and aft .005 then find a washer and epoxy it to the rear cover of the water pump, huh may have to try that if I use the shorter pump.
68Chevele is offline
post #3 of 19 (permalink) Old May 24th, 19, 1:09 AM
Marcus
Have you bought the cam?
Maybe buy and use a gen6 step nose cam.
Is block drilled an tapped in the front for a retaining plate? If not and not machined yet maybe have the macineshop drill and tap for one. Then you dont need a button a retaining plate hold the camplay like on the last picture.
Whats the plan? Just a nice street cruiser the ho 454/502 or zz502 cam will fit nice. With matching timing set
If you already bought parts or want the retro style with button or block is not drilled and tapped and you dont want to drill and tap. I have used cheap cast alu covers and comp nylon button with short pump. Check endplay at the back removing camplug and using dial indicator.
Dial indicator set up to check play
dyno jonn likes this.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
post #4 of 19 (permalink) Old May 24th, 19, 10:42 AM Thread Starter
JOHN
thank you all for the help
post #5 of 19 (permalink) Old May 24th, 19, 11:02 AM
Hi John, if you have the option of using the stepped-nose (MK-VI) cam by all means take advantage of using this setup. It will make your life much easier and require almost no "special" tools to assemble.
Just about all our "streeters" and "street/strip" builds no longer get cam buttons. We stopped using them a few years back.
Around the same time we began replacing all our roller cam inventory and our timing sets over to the stepped-nose setup, we now even do the early SBC's on the same platform, no cam buttons!
Our high-end builds usually get belt-drives so no buttons there either!
Thanks, Gary in N.Y.
P.S. With respect to the photo above showing the mounted plate, I would really recommend using the OEM mounting screws instead of that type bolt pictured. Too many times we've seen the rear side of the cam gear make contact with those larger bolt heads. If not at least check it during the mock-up period?
Name:	BBC Cam Thrust Plate OEM Mtg Screws.jpg
71350SS and blue_69_malibu like this.
Jan. 2016 - New York Street Ride 7.56 @ 190 @ 3800#
GOSFAST is online now
post #6 of 19 (permalink) Old May 24th, 19, 11:19 AM
Marcus
Around the same time we began replacing all our roller cam inventory and our timing sets over to the steeped-nose setup, we now even do the early SBC's on the same platform, no cam buttons!
They are the screws included with gm timing set 12371053 the heads are low profile probably used 10 sets with no problems but those button head screws are pictured if I check the part nr on summit. Maybe they have changed or the picture is generic?
post #7 of 19 (permalink) Old May 24th, 19, 11:36 AM
Hi Marcus, couldn't edit the post any longer, rules??
(Add) Pay attention to Tom below here, he's "dead-on"!
P.S. Here's G.M. the part number for the OEM screws, 14093637, we have a couple hundred on the shelf. We supply them in the tooling kits to do the SBC early block mod for the stepped-nose setup! This is why we have so many on hand.
post #8 of 19 (permalink) Old May 24th, 19, 11:37 AM
use the thrust plate setup if at all possible. all BBCs have the bosses, some are drilled and tapped some are not. those that are not can be. This is vastly superior to any button deal.
post #9 of 19 (permalink) Old May 24th, 19, 12:19 PM
I get them here
https://www.mscdirect.com/product/details/67121608
Mike (Wolfplace)
VISIT US AT
+4axis CNC block machining+
----John Wayne----
Wolfplace is offline
post #10 of 19 (permalink) Old May 25th, 19, 12:23 PM
I am also using a roller for the first time on my 454. CC sold me a thrust bearing (#3110TB) and a cam button (#205) to go along with their cam. After reading this thread I called them about using a thrust plate instead but they said they didn't have a part number for my application.
They recommended a wear plate (#203) to be used with the thrust bearing I already bought. Wear plate going against the block and then the thrust bearing going on next. The cam button wouldn't be used. With this setup CC said there was no need to check end play.
Does all of this sound right?
Thanks.
1970 SS396 Chevelle
468 ci, TH 400, 3:73 posi
SS468 is offline
post #11 of 19 (permalink) Old May 25th, 19, 1:27 PM
Originally Posted by SS468 View Post
I am also using a roller for the first time on my 454. CC sold me a thrust bearing (#3110TB) and a cam button (#205) to go along with their cam. After reading this thread I called them about using a thrust plate instead but they said they didn't have a part number for my application. believe they don't have the correct timing set (with the shim/Torrington for the stepped cams) but they are available. We use them always here!
Thanks.
Hi Chris, cant use that shim with a "conventional;" timing set without machining either the front of the block (.030") or the backside of the cam gear, same amount (.030").
Follow along up here on some of these posts about cam thrust surfaces and if possible tell Comp you want to change to the stepped-nose setup if it's not too late! You'll never regret it, no end-play, no buttons, no shims!
That 205 button isn't going to work either unless you have the OEM "tin" cover, aluminum covers generally use the 200 or 202?
About 99% of our BBC roller builds no longer get cam buttons, the thrust plate setup is not only easier, but a lot faster on ass'y!
P.S. If you stay the course with the conventional MKIV cam snout just order the timing set for it with either the shim (already installed on the gear) or the Torrington equipped one, no machining for either with the correct numbers! Not sure Comp has either, we don't use Comp's timing sets generally.
post #12 of 19 (permalink) Old May 25th, 19, 3:34 PM
Marcus
If you can change it for a gen 6 cam no big deal. I used the #205 nylon button several times with different covers just trim the lenght with a belt sander. Pretty easy to set the end play and a nylon button with alu cover will live for a very long time.
post #13 of 19 (permalink) Old May 27th, 19, 9:39 PM
Thx for the advice. I'll call CC tomorrow to see if I can get a stepped-nose cam in the size I am using. That sure sounds like an easier option.
I had already asked them about a timing set with the built-in Torrington bearing and they don't offer it.
1970 SS396 Chevelle
SS468 is offline
post #14 of 19 (permalink) Old May 28th, 19, 3:15 PM
Good news, CC sells the same cam I have in a step nose. Bad news is the matching timing set costs 5 times as much as the set I bought and they don't have the retaining plate (which is surprising). If I return the cam, timing chain, thrust bearing and button then purchase the new cam and chain it will only be a total of $150 more. Probably worth it to avoid checking the end play and messing with the thrust bearing/button.
1970 SS396 Chevelle
SS468 is offline
post #15 of 19 (permalink) Old May 28th, 19, 3:24 PM
Marcus
Depending on camspec this timing set might work it comes in zz502s even think gm use it in the 572-620 hp hyd roller engine, its cheap and comes with plate and bolts.
https://www.summitracing.com/parts/nal-12371053/
12 Bolt Rear End Play Lew540 Transmission & Driveline 9 Apr 27th, 17 10:54 PM
Need to check cam end play on a Gen VI? RSSS1967 Performance 22 Feb 19th, 13 5:57 PM
Oil Restrictors with Solid Rollers RLM66SS Performance 33 Nov 3rd, 12 11:00 AM
Were Atlanta Braves ripped off? "infield fly rule" Agree VS Disagree YankeeRodder Bench Racing 29 Oct 9th, 12 12:29 PM
thrust collar and crank shaft end play problem!!! Mr. D 1999 -- 6 Dec 16th, 99 9:13 AM
