What HEI to get - Chevelle Tech
 3Likes
post #1 of 25 (permalink) Old May 16th, 19, 12:15 AM Thread Starter
What HEI to get
I’ve been looking at the summit HEI to replace my old points style. They seem to have pretty good reviews and a reasonable price. Any thoughts or recommendations? Not looking to break the bank though. Also do they need an additional harness?
Also what plugs do you guys recommend for a mildly built 327?
Tony70Chevelle is online now
post #2 of 25 (permalink) Old May 16th, 19, 1:01 AM
Randy
Re: What HEI to get
ACDelco 93440806 GM Original Equipment Ignition Distributor, $167.99 at Summit.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #3 of 25 (permalink) Old May 16th, 19, 7:41 AM
Re: What HEI to get
That's what I have in my 327. good so long as you weren't after a small body HEI.
Dansk is offline
post #4 of 25 (permalink) Old May 16th, 19, 8:35 AM
Re: What HEI to get
Do not do what I did. I bought a CHEEEEEPPPP H.E.I. and I was BROKE down all the time. Three times in one year and it ate modules.
Then I bought a new G.M. --H.E.I., Now and then I look to see if it is still in the engine. 39.000 miles in my 468 and many years of PERFECT service.
For a cruiser ,,driver or any hot rod.
A New G.M. --H.E.I. its the KATZ AZZ !
Also:
Wires that are black and fit PERFECT,, I used B.Block Suburban wires from
G.M. Pre made in correct lengths for a B.B. Looks dang near stock!
Robinls5 is offline
post #5 of 25 (permalink) Old May 16th, 19, 9:06 AM
Re: What HEI to get
I have whatever the stock HEI that came with the ZZ4 back in 1996. It may even still have the same cap from then on it. Currently has somewhere around 33,000 miles on it over 20+ years. I plan on putting a small cap computer HEI from the 1990 donor truck I got the serpentine setup from, and having my FiTech control it.
Pioneer4x4 is offline
post #6 of 25 (permalink) Old May 16th, 19, 10:00 AM
Re: What HEI to get
Im running Pertronix' in my two BBs.
Been a couple years now,no problems yet.
'67 Malibu,468 w/TH400
Project-
72LS3Z27 is offline
post #7 of 25 (permalink) Old May 16th, 19, 10:19 AM
Re: What HEI to get
I have a summit HEI in my car its seems to be fine . I have also switched to a pertroninx in my old jet boat and LOVED it ! I have a good friend that is pretty knowledgeable and He really likes the DUI HEI .
72 Malibu Family Fun Car
Seven2bu is offline
post #8 of 25 (permalink) Old May 16th, 19, 5:17 PM Thread Starter
Re: What HEI to get
Great thanks for the help guys, I think I'll look into getting the ACDelco. I don't think I need a small body HEI, its a 327 with double hump heads, edebrock intake and carb
Any recommendations for plugs? Ive seen people run ACDelco as well or platinum plugs
Also, do I need the addition hardness for wiring?
1970 Chevelle
327/TH350, Bear 13" front, 12" rears, UMI upper/lower A arms, UMI front 1.25 sway bar, UMI rear upper/lower control arms, Ridetech drop spindle, Viking coilovers front/rear, 12 bolt, work in progress
post #9 of 25 (permalink) Old May 16th, 19, 5:36 PM
Re: What HEI to get
Run a power wire from the IGN terminal on your fuse block to the positive on the HEI - that's pretty much it. It's all self contained, so hook up is easy. As for spark plugs, I would just run whatever GM called for on your engine originally and gap them no more than .045 (.035 - .040 works on my 377).
OLDED likes this.
My Chevelle w/ open headers:
WakkoWarner is offline
post #10 of 25 (permalink) Old May 16th, 19, 6:04 PM
Re: What HEI to get
I've had a used GM distributor from a ? (my parts stash) for around thirty years in my 69 396. I did replace the cap and rotor several years ago.
Probably hard to find a junkyard one these days though.
Also:
Was that the one that got all the bad reviews?
post #11 of 25 (permalink) Old May 16th, 19, 11:13 PM Thread Starter
Re: What HEI to get
Ok thank you. How about wiring a tach?
1970 Chevelle
post #12 of 25 (permalink) Old May 17th, 19, 12:06 AM
Re: What HEI to get
A tach is pretty straight forward - hot, ground, tach lead (from tach output on HEI), and light. Hook the light lead to the LPS terminal on your fuse block.
post #13 of 25 (permalink) Old May 17th, 19, 12:09 AM
Re: What HEI to get
Theres a spot for a tach wire on the cap next to the power wire terminal...
72 SS 402/4 speed/Straub roller and a bunch of Duramaxes.....
jrkrace is offline
post #14 of 25 (permalink) Old May 17th, 19, 1:23 AM
Pertronix III for a couple of years now in my stock points distributor, zero issues runs great.
yanniziomas is online now
post #15 of 25 (permalink) Old May 17th, 19, 10:36 PM
Re: What HEI to get
I got a procomp one as a gift brand new from family, they are not car people but herd I was looking for a new dist. It did fine at first then had a random misfire after sitting for a month. I took it apart went through it and the housing was real nice, the vacuum canister was adjustable and did work fine. The pick up that came with it ohmed weird and was all over the place, I took a old computer controlled HEI off the shelf and stripped it used the gear and pic up from that Hei. Basically I had to rebuild the new unit with GM factory parts from a distributor I had on the shelf to get it to function to my liking. I have several OEM HEI's on the shelf, some work some are wore out but I have parts when I need them.
I have used the summit brand before and never had a problem with it, sold the car it was in so no long term use.
As for small cap I always us the cardon brand, their pickup can ohm funny though at times so have had to exchange one or 2 but they are life time warrenty and they are all just rebuilt factory units, not sure who makes their pickups though.
78 Malibu, 402, eddy heads, 174 B&M blower, th350, holley sniper EFI, 9" 3:70, 26X8.50-15 slicks.
96 chevy 1500, tow vehicle.
03 yz85 fun bike.
04 scion XB daily driver.
Jebchevelle is offline
Real world HEI spark plug gaps Dave Ray Electrical & Wiring 24 Aug 25th, 18 1:25 PM
Converting from HEI back to points distributor 658Chevy Engine 11 Nov 11th, 17 8:13 PM
HELP- HEI install Questions rs1060 Engine 17 Sep 3rd, 17 2:18 AM
HEI reviews and highlights imp-oster Performance 43 Jun 2nd, 14 9:10 PM
msd hei vs mallory hei vs hei and other ignition questions 1978chad454 Performance 13 Jan 6th, 13 9:44 PM
