Small Block Vortec Heads questions - Chevelle Tech
post #1 of 10 (permalink) Old May 14th, 19, 10:55 AM Thread Starter
As far as the Vortec head goes, is there a better head casting to use and what is a good source to get a pair of them. I have never used a set of Vortec heads in my life personally. I built a few boat engines at the machine shop that used them as original equipment, this shows how long ago. I am building a relatively stock 355 for my 80 Malibu and I think it would be worth going the Vortec head path for a power gain. Thanks.
Ray
http://s30.photobucket.com/albums/c3...t=DSC01615.jpg
bracketchev1221 is offline
post #2 of 10 (permalink) Old May 14th, 19, 11:22 AM
Mr Bill
Re: Small Block Vortec Heads questions
I would either buy new GM castings if they are still available or one of the aftermarket versions. About 40% of the used ones I see have cracks in them somewhere or another. The aftermarket versions have a lot thicker deck and are available with both intake bolt patterns too.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Enginerepairshop.com
Team Chevelle #100
BillK is online now
post #3 of 10 (permalink) Old May 14th, 19, 2:32 PM Thread Starter
I was thinking that too. I see Summit has a set of vortec reproductions. For what I want to do, I don't think I could cover the machine shop costs for the cost of the new heads.
Ray
post #4 of 10 (permalink) Old May 14th, 19, 2:34 PM
I have used the EngineQuest Vortec CH350C - it is a stock replacement for the Vortec head with thicker decks and better water jackets.
1975TypeS-3 is offline
post #5 of 10 (permalink) Old May 14th, 19, 2:37 PM
Both the 906 and 062 heads flow close to the same, but there are some differences. The exhaust seats are different between the 2 castings and I have a set of 062's that have a thicker deck. Don't but the new Mexico Vortec's they are not as nice as the factory ones. There are a lot of them left to buy used. Last set cost me $50.
68Chevele is online now
post #6 of 10 (permalink) Old May 14th, 19, 8:35 PM Thread Starter
Can I ask the dumb question of what they came on to find good ones?
Ray
post #7 of 10 (permalink) Old May 14th, 19, 8:51 PM
Mr Bill
I really would not waste any money on used ones. If you insist they came on 96 - 2002 trucks and old body style Tahoe's and Suburbans. 5.7 Vin R My 99 2dr Tahoe has that engine in it.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is online now
post #8 of 10 (permalink) Old May 14th, 19, 10:24 PM
Mexican casting have smaller runners then the earlier 906/062 castings.
CNC BLOCKS N/E is offline
post #9 of 10 (permalink) Old May 15th, 19, 2:32 PM
Here is David Vizzards Vortec head video. My friend Matt said David is one smart cookie.
https://youtu.be/d55UGoxl8IQ
post #10 of 10 (permalink) Old May 15th, 19, 3:28 PM
https://www.summitracing.com/parts/nal-12558060
Better than buying junkyard castings and finding you need guides, valves, or have a cracked head. Swap springs on these and you are good to go.
IMO, GM quality is likely to be better than a lot of the aftermarket stuff. I am using a set of these (though they were only ~$600 / pair when I purchased) with beehive springs and Comp 787-16 retainers. Mine went 227 cfm @ 0.450" lift on a calibrated flowbench with no porting.
Mine are Mexican castings, but OLDER Mexican castings. I've heard rumors that new ones have smaller ports and don't flow as well. Not sure whether this is true or not?
novadude is online now
any drop in valve springs/retainers for vortec heads.. novaderrik Engine 11 Feb 4th, 16 2:43 PM
454 Big Block questions matteoknows56 Engine 11 Apr 6th, 15 10:14 PM
Dart SHP Small Block Chevy Aluminum Cylinder Heads on a 383? 383bigcar Performance 10 Sep 1st, 14 1:48 PM
make big block tcs selenoid out of small block one truttahunter Restoration Corner 1 Nov 3rd, 12 7:35 PM
Q&D cost analysis of converting to Vortec heads Pat Kelley 1999 -- 6 Apr 17th, 99 7:55 PM
