Block for inline or staggered started and starter options - Chevelle Tech
post #1 of 18 (permalink) Old May 5th, 19, 2:47 PM Thread Starter
I'm looking to upgrade my starter, I've been looking at mini starters but I'm open to suggestions. My current start is staggered bolt pattern, but I noticed my block appears to have bolts for inline as well. Any advice would be great
1970 Chevelle
327/TH350, Bear 13" front, 12" rears, UMI upper/lower A arms, UMI front 1.25 sway bar, UMI rear upper/lower control arms, Ridetech drop spindle, Viking coilovers front/rear, 12 bolt, work in progress
Tony70Chevelle is offline
post #2 of 18 (permalink) Old May 5th, 19, 3:08 PM
Re: Block for inline or staggered started and starter options
This one is cheap and works great. https://www.ebay.com/itm/New-Starter...53.m2749.l2649
aimhard is offline
post #3 of 18 (permalink) Old May 6th, 19, 10:38 AM
Staggered pattern from the factory was the 168-tooth flywheel/flexplate - straight was the 153-tooth.
1975TypeS-3 is offline
post #4 of 18 (permalink) Old May 6th, 19, 10:52 AM
Most mini starters are straight pattern and work just fine. I wouldn't care which pattern it uses as long as it starts the car.
Ray
bracketchev1221 is offline
post #5 of 18 (permalink) Old May 6th, 19, 12:49 PM
if you buy a mini starter,make sure you get the correct bolts as the bolts from the "full size" starter are NOT good for a mini/PMGR starter.
I have a few of those $36 mini starters in my cars. They work work great and only weigh about 4 lbs.
mr 4 speed is offline
post #6 of 18 (permalink) Old May 6th, 19, 2:28 PM Thread Starter
Will that block work with a straight pattern starter? I removed a staggered pattern starter when I pulled the motor but it appears to have a bolt pattern for both.
post #7 of 18 (permalink) Old May 6th, 19, 2:29 PM Thread Starter
What starter are you running? and where's the best place to get the correct bolts?
1970 Chevelle
post #8 of 18 (permalink) Old May 6th, 19, 2:40 PM Thread Starter
Thats really all I'm looking for, was having a lot of issues with the prior starter so decided to junk it. But the one I pulled was a staggered bolt pattern and the block looks like it has holes to except a straight pattern. Was trying to figured that out first prior to buying a starter
1970 Chevelle
post #9 of 18 (permalink) Old May 6th, 19, 3:02 PM
Here's some bolts that will work for the above starter . https://www.ebay.com/itm/GM-OEM-Star...53.m2749.l2649
aimhard is offline
post #10 of 18 (permalink) Old May 6th, 19, 3:24 PM
Jon N.
Block will work with either straight or staggered pattern starter.
Jon N.
dyno jonn is online now
post #11 of 18 (permalink) Old May 6th, 19, 3:40 PM
Greg
You will have to change bolts and you will have to shim it so get a shim kit but the difference is night and day once you get it setup right.
2cool is offline
post #12 of 18 (permalink) Old May 6th, 19, 3:52 PM
Cory
Are they Metric or SAE threads?
dream66 is offline
post #13 of 18 (permalink) Old May 6th, 19, 5:37 PM
sae threads
aimhard is offline
post #14 of 18 (permalink) Old May 6th, 19, 5:49 PM
Since my block suffered a broken starter mounting ear years ago I went with the Powermaster XS series and use all 3 mounting holes. A little pricey but works great. Did not use the bolts that came with it.
https://www.summitracing.com/parts/pwm-9526
oldcutlass is offline
post #15 of 18 (permalink) Old May 7th, 19, 3:42 AM
no, not SAE threads, that's fine thread. These bolts are USS coarse thread. Fine threads are not normally used in cast iron.
Starter removal frizgolf Electrical & Wiring 15 Jul 15th, 18 4:58 PM
Starter Solenoid Story - Check your grouding surfaces. Lew540 Electrical & Wiring 1 Jul 14th, 16 11:31 PM
Starter Isn't Playing Nice hpycoconut Troubleshooting 5 May 28th, 15 8:28 AM
Heat soaked starter or??? smokes Performance 44 Feb 27th, 14 9:51 AM
Performance starter woes and frustration venting Heckeng Performance 11 Oct 14th, 12 11:15 AM
