Starving for fuel? - Chevelle Tech
post #1 of 52 (permalink) Old Apr 23rd, 19, 9:33 PM Thread Starter
RT
Rich
Starving for fuel?
This past weekend, for the first time, after winding through the gears at 5000 rpm, the engine lost power in high gear. Feathering the pedal for awhile, it finally smoothed out and as long as I drove at a steady speed, it was fine. First thing I checked was the Russell in-line fuel filter. It's just a 3/4" disc of corrugated screening and it was clean, no dirt particles. I replaced the sending unit in the gas tank a few months ago and the rubber hoses are new. The fuel pump is an engine mounted mechanical stock style pump. Carb is a 780 Holley, engine is a 454, Edelbrock performer heads, hydraulic roller cam, 600 lift.
Any ideas what to do next?
Thanks,
Rich
Rich
'69 Malibu hardtop
'69 Malibu convertible
RT is offline
post #2 of 52 (permalink) Old Apr 23rd, 19, 9:45 PM
Re: Starving for fuel?
Thanks,
Rich
what is your timing set at? what is your fuel pressure? do you hear any pinging when in high gear?
1967 Chevelle Oshawa Built Car
-427 .60 over, Lunati 60211 Roller cam
-Super T10 2.64
-Dana 60 3.54 Posi
1967 chevelle is offline
post #3 of 52 (permalink) Old Apr 24th, 19, 8:24 AM Thread Starter
RT
Rich
Timing: 22 initial, add mech. adv. 36, add vac. adv. 48.
Fuel pressure, don't know.
Pinging, none that I can hear over the sound of the exhaust.
Rich
Rich
'69 Malibu hardtop
RT is offline
post #4 of 52 (permalink) Old Apr 24th, 19, 8:53 AM
Check the hose that comes from the tank tubing to the pump. There's a deep bend on some of them and the hose collapses there. I sleeved a piece of bent 3/8" tubing inside the hose and all my starvation issues went away..
hydro462 is offline
post #5 of 52 (permalink) Old Apr 24th, 19, 10:52 AM
Yes, that is a good fix too and a good possibility. I use a length of spring for that same section of fuel line to eliminate the possibility of collapse.
68elky396 is offline
post #6 of 52 (permalink) Old Apr 24th, 19, 1:09 PM
Greg.
Could have Vapour Lock
Need a Spacer under the Carb
This happen to me at the 1,000 ' on the Track when she would just flatten out/not Accelerate any more
Also happened with my newly built Engine (2017), as it now needed more/higher Fuel Pump
the old Mech Pump was just not enough/could not supply enough needed Fuel to the Engine at WOT
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #7 of 52 (permalink) Old Apr 25th, 19, 7:56 PM Thread Starter
RT
Rich
What fuel pump did you replace the old mechanical pump with?
And thanks for the tips on the rubber fuel line section to the pump. I had considered that, but I thought that the reinforced fuel line would be strong enough to resist flattening out. I'll work on that first.
Thanks,
Rich
Rich
'69 Malibu hardtop
RT is offline
post #8 of 52 (permalink) Old Apr 26th, 19, 11:18 AM
Greg.
Thanks,
Rich
AUG.16/18 Removed Mech Fuel Pump / Old Fuel Line & Old Gas Tank
Installed Holley EFI Sniper Fuel Tank https://www.jegs.com/i/Holley/510/19-105/10002/-1
+Dual Russell Braided Hose Fuel Lines (Feed & Return) https://www.jegs.com/i/Russell/799/632080/10002/-1
Aeromotive 340 lph Fuel Pump https://www.jegs.com/i/Aeromotive/027/11569/10002/-1
Holley # 12880 Fuel Pressure Regulator https://www.jegs.com/i/Holley/510/12-880/10002/-1
Russell Fuel PSI Gauge https://www.jegs.com/i/Russell/799/650350/10002/-1
Installed before the Fuel Regulator to Carb http://www.jegs.com/i/Earls/361/230106/10002/-1
Fuel FILTER way from Gas Tank to Front of Car in Frame Metal Fuel Filter NAPA https://www.napacanada.com/en/p/NGF3033
If you want to stay with a Mech Fuel Pump ;
Holley HP Series Fuel Pumps come complete with -8 AN inlet/outlet fittings installed.
has a free-flow number of 170gph / pre-set idle fuel pressure of 7.5 psi. No Regulator required
Holley 12-454-25 Hp series FP http://www.jegs.com/i/Holley/510/12-454-25/10002/-1 $ 323.95us
hydro462 likes this.
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #9 of 52 (permalink) Old May 15th, 19, 6:53 AM Thread Starter
RT
Rich
That mechanical fuel pump is a pricey item, I see most electric and mechanical pumps rated at 110 gph. First, I'd want to know if 170 gph was actually needed before I bought that one.
Thanks,
Rich
Rich
'69 Malibu hardtop
RT is offline
post #10 of 52 (permalink) Old May 15th, 19, 7:17 AM
Mr Bill
Rich,
I just noticed this thread for the first time. Have you run it up through the gears ok in the past ? Any chance you just got some crappy gas ? If not then I would check the float settings on the carb for starters.
Just for reference if your engine made 500 horsepower it would only require about 41-42 gallons per hour at wide open throttle under load. So unless you have a real piece of junk pump I doubt it is the problem. If you do decide to replace it a 110GPH pump would be way more than enough.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #11 of 52 (permalink) Old May 15th, 19, 7:34 AM Thread Starter
RT
Rich
Yes Bill, I have run it up like that in the past and it didn't have any problems. Could be the gas. Last weekend, I removed the (approx.) 10" length of black rubber fuel line from the frame line to the pump and replaced most of it with steel tubing (short rubber hose at the ends). That didn't change anything. I'm thinking maybe I'd do the same thing at the tank outlet.
I have a Russell inline filter from the pump to the carb that has a screen, checked that, it's clean.
The pump is not new, maybe it's just tired.
Thanks,
Rich
Rich
'69 Malibu hardtop
RT is offline
post #12 of 52 (permalink) Old May 15th, 19, 7:48 AM
Mr Bill
I would try and run some gas through it and get some fresh stuff in the tank first. Might not really be a problem at all other than the gas. Seems like it has gotten pretty crappy lately. I normally run Shell but about two weeks ago I was getting low in my S-10 so I stopped and filled it up at a non brand name type place. It started running crappy the next day It is getting low so I will fill it up tonight with Shell and see what happens. I am betting it was the gas I got.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #13 of 52 (permalink) Old May 15th, 19, 9:15 AM Thread Starter
RT
Rich
I just filled it up last night at Sheetz (93). I've used their gas for many years, never a problem, but who knows, could've been pulling from the bottom of their tank the last time.
Thanks,
Rich
Rich
'69 Malibu hardtop
RT is offline
post #14 of 52 (permalink) Old May 15th, 19, 10:54 AM
Thanks,
Rich
Did you duburr the steel tubing ends? If not, the tubing may have shaved off some of the interior of the short rubber lines, allowing fuel to pass under nominal driving but imposing a partial blockage with more fuel demand.
SSJohn is offline
post #15 of 52 (permalink) Old May 15th, 19, 5:37 PM Thread Starter
RT
Rich
De-burred, blown out, that part's good.
Rich
Rich
'69 Malibu hardtop
RT is offline
starving for air? under carbed boyd66k20 Engine 26 Feb 1st, 18 4:24 PM
Power steering pump is starving Shawn 1999 -- 5 Sep 23rd, 99 7:09 AM
