Flywheel removal - Chevelle Tech
 8Likes
  • 2 Post By BillK
  • 1 Post By Busted Knuckles
  • 2 Post By Robinls5
  • 1 Post By DZAUTO
  • 1 Post By HKalin
  • 1 Post By 72LS3Z27
post #1 of 9 (permalink) Old Apr 22nd, 19, 8:40 PM Thread Starter
Flywheel removal
Hi Guys
does anyone have an easy way to remove the flywheel. it's a press fit on the crank and Im struggling to get it off. Thanks for the advise .
SteveDeluxe300 is offline
post #2 of 9 (permalink) Old Apr 22nd, 19, 9:05 PM
Re: Flywheel removal
what
What are you working on the flywheel should not be a press fit?
Chevys#1 is offline
post #3 of 9 (permalink) Old Apr 22nd, 19, 9:06 PM
Mr Bill
Steve,
It is not a press fit. It is tight and most likely stuck a little from old age. If it is a stick shift just get a big rubber hammer and start smacking it. it will come loose eventually. If you can get behind it try to pry between the flywheel and the crank flange. Leave a couple of the bolts in a few threads so when it comes loos it wont fall off
LeoP and buenymayor like this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #4 of 9 (permalink) Old Apr 22nd, 19, 9:20 PM
^ the man speaks from experience, especially the part about leaving a couple of bolts in place, that can save a headache!
You also might try some PB Blaster or other rust solvent, that might help.
Once it's broke loose, it'll be much easier.
LeoP likes this.
Gary Adrian
Busted Knuckles is offline
post #5 of 9 (permalink) Old Apr 22nd, 19, 11:17 PM
After you have been " BITTEN " by a ring gear. @#%$&**@#$%[email protected]###@$^, Your thinking will change, TRUST ME !
OLDED and LeoP like this.
Robinls5 is offline
post #6 of 9 (permalink) Old Apr 22nd, 19, 11:37 PM
Steve,
^The above is exactly correct. I've experienced "stuck" flywheels (and flexplates) a few times. Use a little PB Blaster, hammer, wiggle, pry (of course, with 2-3 bolts partially screwed in) until it loosens up--------------------then with a good grip, carefully pull it off----------------it WILL come off.
LeoP likes this.
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #7 of 9 (permalink) Old Apr 23rd, 19, 8:44 AM
Hank
Just in case you never did it before once you do get it loose and work it off the end of the crank you will notice it gets real heavy real fast so be ready for it.
LeoP likes this.
HKalin is online now
post #8 of 9 (permalink) Old Apr 23rd, 19, 9:11 AM
However,the harmonic balancer in the front is press fit.
Just thought Id put that out there.
HKalin likes this.
'67 Malibu,468 w/TH400
Project-
72LS3Z27 is offline
post #9 of 9 (permalink) Old Apr 23rd, 19, 11:59 AM
Vern
Try using a little heat around the bolt area. It will expand away from the crankshaft. Don't turn it red. But as mentioned above, back off a couple bolts but leave them in place.
suntreemcanic is offline
Flywheel 1967 chevelle Transmission & Driveline 5 Mar 27th, 18 11:09 AM
Crankshaft To Flywheel Tolerance blm Engine 27 Feb 10th, 18 2:46 PM
Mystery noise. TC or flywheel s_crumb Transmission & Driveline 3 Oct 10th, 17 10:45 PM
Hays Flywheel Centerforce Clutch setup, Help please brandon706 Transmission & Driveline 0 Feb 1st, 15 2:01 AM
11 1/2" 168 tooth flywheel 66nut Transmission & Driveline 4 Jan 15th, 14 9:53 PM
