Overheating sbc - Page 3 - Chevelle Tech
 34Likes
post #31 of 149 (permalink) Old Apr 24th, 19, 3:56 PM
Re: Overheating sbc
Thumper cams, with narrower lobe centers, cause the exh valve to open later, keeping the combustion heat in the block as opposed to letting it out the exh system sooner. It makes it a little harder to cool
70GS455 is offline
post #32 of 149 (permalink) Old Apr 24th, 19, 4:52 PM
Re: Overheating sbc
If you have a digital dial back timing light and the RPM is 3950 at idle then you set the timing light up wrong.If you have a dial back timing light you can use it but make sure to keep it set at its base 0 degree setting. Then just use the light to read the base timing off of the stock timing indicator that's on the timing chain cover.
A dial back timing light will get confused by a Multi-spark (MSD) box if you have any of these then just use a basic timing light to set timing.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #33 of 149 (permalink) Old Apr 24th, 19, 4:53 PM Thread Starter
Gerrett
My distributors part number on jegs is part number 121-8365 ...MSD Ignition Pro-Billet Distributor GM HEI
Bosch-Actron Digital Timing Light Designed with Advanced Features
Mrfresh352 is offline
post #34 of 149 (permalink) Old Apr 24th, 19, 9:24 PM
Re: Overheating sbc
Use your laser temp sensor on the thermostat housing, hoses and the radiator if it isn't shiny aluminum. Going into drive or OD only says that you have a wiring issue. You are either really overheating and putting it in drive gives you a false reading where somehow you are getting a ground through the electronics of the transmission or you are not overheating and your gauge is wrong when not in gear.. Check your grounds as a priority with a meter from the chassis, cowl, engine and from the gauge itself to the battery. It should be 0 ohms or just a hair higher. Nothing above a couple ohms is acceptable and really it shouldn't be higher then .5 ohms. AND WHEN YOU LAST MODIFIED THE CAR DID YOU DISCONNECT THE BRAIDED WIRE FROM THE COWL TO THE VALVE COVER?????
LeoP likes this.
Billdini is offline
post #35 of 149 (permalink) Old Apr 25th, 19, 12:25 AM
Al
Re: Overheating sbc
Your MSD HEI distributor is not a multi spark unit if you are still running it with the module that came with it. https://www.jegs.com/i/MSD-Ignition/121/8365/10002/-1 The timing light you have should work. Your timing light will not work properly with a multi spark ignition system or module. If you're still getting funky readings, try it on another car and see how if it works.
https://actron.com/sites/default/fil...lish_16313.pdf
Make sure you set the 2/4 button so the 4 is lit up on the face. If the 2 is lit up, toggle the button 2/4 until the 4 lights up. Your car is a 4 stroke. Make sure your pick up lead is isolated from other plugs and wires.
I could have sworn you said you had a mechanical water temp gauge. There are no wires that go to your sending unit, right? Just a tube that runs to the sending unit that can't be removed or cut.
DUTCH MAX HEADWORK is offline
post #36 of 149 (permalink) Old Apr 25th, 19, 6:28 AM
Geoff
Re: Overheating sbc
Narrower lobe centre causes exh valve to open sooner, not later.
Gtogeoff is offline
post #37 of 149 (permalink) Old Apr 25th, 19, 6:39 AM
Geoff
Re: Overheating sbc
Ignore my post above, it is wrong.
Gtogeoff is offline
post #38 of 149 (permalink) Old Apr 25th, 19, 3:26 PM
Re: Overheating sbc
Originally Posted by Gtogeoff View Post
Ignore all my posts, most are wrong.
We try to but its hard since you post alot of bs.
How is the Chevelle working?
Chevelle 1969 is offline
post #39 of 149 (permalink) Old Apr 25th, 19, 6:30 PM
Re: Overheating sbc
Where is the vacuum advance line going? Is it into a ported or manifold vacuum source? If it's ported(high up on the carb) I would put in on the port on the baseplate of the carb which is full vacuum....
72 SS 402/4 speed/Straub roller and a bunch of Duramaxes.....
jrkrace is offline
post #40 of 149 (permalink) Old Apr 25th, 19, 8:19 PM Thread Starter
Gerrett
Initial timing is 19 but advance timing stops at 30 and doesn’t keep going to 36. Do I need springs for my curve? Took it for a drive and it doesn’t do much at wot like it use to. Still responsive but I didn’t hear the roar that I use to. Temp went up to 240 again and as soon as I was going to shut it off it drops to 185 and stays there.
I put the initial at 16 but it still wouldn’t climb to 36 any lower on the initial and it shakes and is about to shut off. Vac advance is ported from the carbs small port top left corner if your facing the carb from the front. It’s a Holley 650 with out the fuel float bolt. I can do a video if anyone wants me to upload it to YouTube.
post #41 of 149 (permalink) Old Apr 25th, 19, 10:19 PM
Move vacuum to bottom port
Using Long Chevy water pump ?
Are you setting timing w/vacuum advance plugged ?
Forget idle timing.
Use distributor springs for about 3400, you can see this on dial back light.
Assuming you run at least 91, set timing for 36 @ 3400.
If starter kicks back, work w/dist bushings, put a good starter on or wire separate ignition switch.
Be sure your carb isn’t lean @ idle or jetted lean. Try 68 & 70 just to start.
You should be able to hold 160.
Good luck
Reelysalty is offline
post #42 of 149 (permalink) Old Apr 26th, 19, 1:48 PM Thread Starter
Gerrett
Okay I will Switch it this weekend. Yes my water pump is long. And yes I plugged vac advance when setting the timing.
post #43 of 149 (permalink) Old Apr 26th, 19, 11:32 PM
Re: Overheating sbc
If you say it's only overheating or changes when you go into drive or OD then its electrical. If you are overheating sitting in traffic or running it hard then you might have a timing issue. Putting it in gear shouldn't immediately change your temp gauge. Can you clarify what the problem is again! I do not understand your initial post?
Billdini is offline
post #44 of 149 (permalink) Old Apr 27th, 19, 2:39 PM Thread Starter
Gerrett
Okay I’ll try and explain it again. I’ve turned it on yesterday and it takes a while for it to fully warmup about 7-10 mins. Once it get to 160 it will stay there for about 5 mins and then it starts to climb slowly. 180, 200, 230, once it hit 240 for 2 minutes it immedialty starts to drop.
I did this without changing the gear. Still in park. It drops to 185 and stays there. I will provide a link to my YouTube to get more help later. I’ve never seen this so it’s hard for me to explain.
post #45 of 149 (permalink) Old Apr 27th, 19, 2:53 PM
Re: Overheating sbc
Sounds like it is low on coolant. If it gets that hot and then finally cools down, I would assume the cooling system is capable. Or something like thermostat upside down. I'd have to go back and re-read the thread.
Pioneer4x4 is offline
68 SBC W/ remote reservoir pump dell72 Brakes, Suspension & Steering 0 Mar 26th, 19 1:07 PM
406 sbc overheating jgang19 Engine 45 Aug 22nd, 16 11:36 AM
Is AC r44TS correct for this SBC? JPS Engine 9 Jul 14th, 15 11:55 AM
Sbc overheating with 4 row aluminum radiator 1969ChevelleMalibuSS Heating & Cooling 20 Aug 10th, 13 10:57 PM
