Tune up specs for a 454... - Chevelle Tech
 3Likes
  • 1 Post By BillK
  • 1 Post By 1975TypeS-3
  • 1 Post By gnicholson
post #1 of 6 (permalink) Old Apr 18th, 19, 9:01 AM Thread Starter
I want to tune my totally stock, low mileage 1978 454 in my 69 el Camino.. It has #336781 heads that have never been off. The engine has about 30,000 miles on it..
I use 87 octane, it has a Turbo 400 with a 2:87 rear end. It is 100% street driven...
It has a factory HEI distributor and I am using Atlas C36R4 plugs these cross with Autolite 25 plugs...
What would be good specs to tune it to?
It runs real nice now, doesn't ping at all and I want to keep it that way.. Thank you..
hydro462 is offline
post #2 of 6 (permalink) Old Apr 18th, 19, 9:38 AM
Mr Bill
Re: Tune up specs for a 454...
If it is running fine now, why would you want to "tune" it ???? Whatever it is set to now you should leave it alone.
Only thing I would do different is use a set of AC Delco plugs, but that is my personal preference for GM engines.
lucifershammer likes this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #3 of 6 (permalink) Old Apr 18th, 19, 5:48 PM
Not that it would make a whole lot of difference, but what did the 1978 454 come out of? I mention this because the 3/4 ton trucks used a dish piston and the Suburban and 1/2 ton trucks used a flattop piston. The difference is the dish piston with 781 heads has a 7.3:1 compression and the flattop piston has 7.8:1. Either way you can easily run on 87 octane, but the dish piston engines can take a little more timing advance.
hydro462 likes this.
1975TypeS-3 is offline
post #4 of 6 (permalink) Old Apr 19th, 19, 4:12 AM
Gary
i would start with the advance curve try 36 degrees all in at 3400. make sure the mech advance isnt frozen up and the vac adv works. just bumping the timing up to 12 degrees initial will help
gnicholson is offline
post #5 of 6 (permalink) Old Apr 19th, 19, 7:59 PM Thread Starter
The engine came from a demolished Carnegie library Book-Mobile van.. They were these big trucks that carried books to different neighborhoods.. The truck had under 100 miles on it when it was in an bad accident..
My el Camino has a lot of balls, its hard to believe it only has 8:1 compression. I stayed neck and neck with a new Challenger one time. I don't race this one..
I enjoy tuning motors but like to have a base to start at.. In the past I have gotten additional power just from tweaking the mechanical timing..
Thanks for the input!
hydro462 is offline
post #6 of 6 (permalink) Old Aug 20th, 19, 9:26 AM Thread Starter
This is with the stock 1978 HEI distributor. The engine has less then 15,000 miles..
I've disconnected the vacuum advance and rasied the initial from 12 to 22. It runs so much better!! It starts very easily when hot. But I still have all that mechanical advance, I think its around 20 fully advanced.. I didn't try full throttle but I'll bet it pings.
I'm thinking the mechanical in these HEIs put 20 in. So I'm going to have to limit the mechanical to 10-14ish..
It runs so much better mainly in the part throttle and just off idle..
What's the maximum advance without any vacuum advance you would run? This is a low compression 1978 454 factory stock. I switched the thermostat to 160 and have the under hood cleared pretty well. I removed that big HVAC box, compressor, etc. I am running a Champion 3 core rad with a 160 thermostat.
It runs pretty good but there always room for improvement.. It idles much better. Part throttle cruise without the vac advance is dead smooth with a nice mellow throaty tone. I no longer have to keep correcting the gas..
hydro462 is offline
Holley 800 Baseline Tune? bbc Gorrillasnot Performance 8 Mar 12th, 16 2:27 PM
Looking for local Knowledge to tune 454 6-71 Blower Referenced Carbs-2 brettallen59 Engine 0 Sep 14th, 15 9:38 PM
LS7 454 piston specs deadpool1988 Performance 3 May 25th, 14 6:27 PM
454 parts interchangable with other 454 regardles of year?? desert-rat Engine 1 Feb 8th, 13 10:34 PM
Ls5 engine specs stevenb8 1999 -- 2 Aug 23rd, 99 2:29 PM
