Quadrajet - Chevelle Tech
 8Likes
post #1 of 28 (permalink) Old Apr 9th, 19, 11:47 AM Thread Starter
Todd
Quadrajet
I installed a 800 cfm stage 3 from jet quadrajet carburetor on my 454 last year before I put the car away for winter, on 3/4 to full throttle the engine would bog down a little then kick in like a rocket, I was told to adjust the secondary plates, that they may be opening to soon causing quadrabog. The engines runs awesome. I need to adjust Allen head with set screw. Is this the way to get rid of the quadrabogging and will it be eliminated. I can tell that it wants to go
Thanks, Todd
tday815518 is offline
post #2 of 28 (permalink) Old Apr 9th, 19, 1:26 PM
Re: Quadrajet
There is no guarantee that "tightening" the secondary air valve will stop the bog. BUUUUUUUUUUUT, this is a very likely cause of your bog. I would recommend tightening the spring tension a little at a time, drive, repeat. If the spring tension on the secondary air valve is too loose, then this is very possibly the cause of the bog.
427L88 likes this.
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #3 of 28 (permalink) Old Apr 9th, 19, 1:39 PM
Jon N.
Re: Quadrajet
I'd check into how the mechanical advance is working too, and where it is kicking in.
Jon N.
dyno jonn is online now
post #4 of 28 (permalink) Old Apr 9th, 19, 2:15 PM Thread Starter
Todd
The advance check out good, the engine advances to about 30 degrees when I bring the rpms up, set at about 10 degrees btdc
post #5 of 28 (permalink) Old Apr 9th, 19, 2:18 PM Thread Starter
Todd
I will adjust set screw more
post #6 of 28 (permalink) Old Apr 9th, 19, 4:50 PM
Re: Quadrajet
Hold the tension screw when you unlock the set screw. Or know exactly how many turns it has before it unwinds ! BTDT... when Tom says " a little" , we're talking 1/8-1/4 turn here; its a very subtle setting.
71350SS likes this.
post #7 of 28 (permalink) Old Apr 9th, 19, 5:43 PM Thread Starter
Todd
Re: Quadrajet
ok, I will give it a try
post #8 of 28 (permalink) Old Apr 9th, 19, 6:21 PM
von
Lifetime Founding Member
Von
Re: Quadrajet
The choke pull-off release time also plays a big part in the opening rate of the secondary air valves (flaps). The ideal release time is between one and two full seconds. Push the plunger in and let go and time it. The are ways to slow it down if too fast. It must not be defective either (must hold vacuum). This and about 3/4 turn of the air valve adjustment screw should yield smooth opening of the secondaries if your jetting is close and ignition timing good.
427L88 likes this.
[img]
von is offline
post #9 of 28 (permalink) Old Apr 10th, 19, 6:53 AM Thread Starter
Todd
That sounds logical. It's a brand new carburetor, I got it from jegs on line . Jet builds it. It has a ver strong suction at idle, I guess this is normal. I will check into the plunger but not exactly sure how to adjust it.
post #10 of 28 (permalink) Old Apr 10th, 19, 8:41 AM
Re: Quadrajet
Your experience mirrors mine, although I have had combinations and carburetors that liked a looser secondary valve. 3/4 turn seems to be about right for most.
novadude is offline
post #11 of 28 (permalink) Old Apr 10th, 19, 9:59 AM Thread Starter
Todd
I did turn the set screw a total of 3/4 of a turn took 3 tries so far, it is better. Should I keep turning more, a little at a time?
My neighbors think I'm crazy getting on it to test.
guitargeak99 likes this.
post #12 of 28 (permalink) Old Apr 10th, 19, 1:24 PM
Re: Quadrajet
Have you checked the release of the time of the vacuum can?
Did the timing stop advancing at 30? Could used a little more timing unless you're into pinging.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #13 of 28 (permalink) Old Apr 10th, 19, 1:44 PM Thread Starter
Todd
Not sure what you mean vacuum can???
Is that on the carb? can advance it more, no pinging
post #14 of 28 (permalink) Old Apr 10th, 19, 2:55 PM
Gary
Re: Quadrajet
the choke pull off or vacuum break is on the right side of the carb airhorn assy.installed with 2 screws on the airhorn. it has a rod that attaches to a slotted lever on the airvalve shaft. usually vacuum can refers to the vacuum adv on the dist
gnicholson is offline
post #15 of 28 (permalink) Old Apr 10th, 19, 3:03 PM
von
Von
Re: Quadrajet
I think he means the choke pull-off release time. The choke pull off is the round pod on the pass side of the carb with a vacuum line attached. The air valve (flaps) tension is set by turning the screw slot in the end of the flaps shaft. That adjusts the spring tension holding the flaps shut. First you loosen the small allen head set screw under it then adjust the spring tension by turning the flap shaft (with a screwdriver) so the flaps are barely held closed by the spring tension. Then turn the shaft clockwise against the spring tension an additional 3/4 turn or so and while holding there with screwdriver, tighten the allen head set screw. To check the choke pull off release time, with engine off push the plunger in all the way that comes out the back of the pull off. Time how long it takes for the plunger to come out all the way on its own.
LeoP likes this.
[img]
von is offline
I think I want to try a good quadrajet v8440 Performance 53 Apr 8th, 19 1:15 PM
Quadrajet questions sunrise7 Engine 14 Feb 20th, 15 8:30 PM
1969 Chevelle SS Quadrajet Questions BigDogCaine Chevelle Tech 25 Jul 24th, 14 6:28 PM
New Quadrajet, idling problems Adam G Engine 12 Sep 23rd, 13 1:12 PM
Quadrajet Tuning 70-SS454 Engine 1 Sep 5th, 13 2:38 PM
