Quadrajet - Page 2 - Chevelle Tech
 8Likes
post #16 of 28 (permalink) Old Apr 10th, 19, 4:29 PM
Re: Quadrajet
It could be like one of these.
https://encrypted-tbn0.gstatic.com/i...EdwIOorKG58OtA
http://www.carburetor-parts.com/asse...20pulloffs.JPG
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #17 of 28 (permalink) Old Apr 10th, 19, 7:18 PM Thread Starter
Todd
Re: Quadrajet
cool, I understand, I will give it a try
Thank You guys for your help!
tday815518 is offline
post #18 of 28 (permalink) Old Apr 10th, 19, 7:25 PM Thread Starter
Todd
Yes, it is exactly like that 👍
post #19 of 28 (permalink) Old Apr 10th, 19, 7:45 PM Thread Starter
Todd
What does the secondary pull off do . Do j need to check that also or just the primary pull off, how do I adjust if needed?
post #20 of 28 (permalink) Old Apr 10th, 19, 9:49 PM
Re: Quadrajet
Originally Posted by tday815518 View Post
my neighbors think i'm crazy getting on it to test.
lmao!
67 Chevelle SS:
original paint, M20, & 3:31 posi.
Unrestored, but dreaming of doing so
guitargeak99 is offline
post #21 of 28 (permalink) Old Apr 10th, 19, 9:56 PM
Gary
Re: Quadrajet
qjets in the late 70s 80s used 2 vacuum breaks. basically it just pulled the choke open a little further than the primary after a little delay.
gnicholson is online now
post #22 of 28 (permalink) Old Apr 10th, 19, 10:02 PM
Re: Quadrajet
Check the one that's connected to the secondaries. Can you post a pic of your carb?
77 Monte
post #23 of 28 (permalink) Old Apr 11th, 19, 6:20 AM
Geoff
Re: Quadrajet
Check the basics first, which would be float level. Should be 1/4". No gaskets reqd if you are careful removing the air horn to check.
Gtogeoff is offline
post #24 of 28 (permalink) Old Apr 11th, 19, 8:10 AM Thread Starter
Todd
That is the one that I purchased from jegs
post #25 of 28 (permalink) Old Apr 11th, 19, 8:15 AM Thread Starter
Todd
Jegs on line carb number is 561-36003
Q-jet BB Chevy. Modified
post #26 of 28 (permalink) Old Apr 11th, 19, 1:42 PM
Re: Quadrajet
Some of those rear pull-offs have a dual setup. there's two slotted links coming out of the plunger on the pull-off. they have two links, one goes into the choke mechanism, the other connects directly to the secondary air valve. (big flapper on top) I personally prefer the front pull-off mostly because that's how most of them are.
Those who know me know I've more than just a few Qs, one of the best I've ever had was a later style 13 screw top 800CFM with a rear pull-off. Thing was like EFI, instant response, good manners cold and hot. Got 14-15 around town, 20 on the hiway. This was a 406 roller, aluminum heads, Eddie Perf RPM Q-jet, prepped HEI, 200-4R, 3.73. ran 131MPH for 10 miles across a new fwy here in the desert.
77 cruiser, LeoP and 72BB Nova like this.
post #27 of 28 (permalink) Old Apr 14th, 19, 6:39 PM Thread Starter
Todd
Re: Quadrajet
I have a rear pull off and it take a under 3 seconds to return once a push the pod in probably about 2.5 seconds. I adjusted the set screw tightened more now it seem worse . i am going to back off 1 turn and try that
post #28 of 28 (permalink) Old Apr 20th, 19, 2:01 PM
Re: Quadrajet
Did it work?
77 Monte
I think I want to try a good quadrajet v8440 Performance 53 Apr 8th, 19 2:15 PM
Quadrajet questions sunrise7 Engine 14 Feb 20th, 15 9:30 PM
1969 Chevelle SS Quadrajet Questions BigDogCaine Chevelle Tech 25 Jul 24th, 14 7:28 PM
New Quadrajet, idling problems Adam G Engine 12 Sep 23rd, 13 2:12 PM
Quadrajet Tuning 70-SS454 Engine 1 Sep 5th, 13 3:38 PM
