Motor Mounts Solid Drivers/Polly - Chevelle Tech
 13Likes
  • 1 Post By 68Chevele
  • 1 Post By any4xx
  • 1 Post By Eddie K
  • 1 Post By SSJohn
  • 1 Post By MarkP
  • 1 Post By MYWAY
  • 2 Post By mr 4 speed
  • 1 Post By 427L88
  • 2 Post By Malibu ss 64
  • 1 Post By Stokerboats
  • 1 Post By NW68SSBBC
post #1 of 15 (permalink) Old Apr 4th, 19, 9:48 AM Thread Starter
I am getting ready to in install a new big block street/strip 68 car and trying to decide on motor mounts... I purchased solid and poly after research here. Looks like many run the solid drivers and poly passenger. Trying to understand the theory or science as to why, and after looking back and trying to find out why I notice several posts about bad vibrations running solid anywhere... just trying to get some insight so I can feel confident I am making an educated decision.
Thanks!
MYWAY is offline
post #2 of 15 (permalink) Old Apr 4th, 19, 10:02 AM
Re: Motor Mounts Solid Drivers/Polly
I have had solid mounts in my street car since the late 80's with some minor vibrations from time to time but it has not been a big deal.
MYWAY likes this.
68Chevele is offline
post #3 of 15 (permalink) Old Apr 4th, 19, 10:19 AM
Iím guessing that vibration is somewhat dependent on how well your engine is balanced. I had solids in one car that had been installed by the guy I bought it from. The vibration was horrible. I switched to Poly and it helped quite a bit. These days I figure itís easy enough to change mounts so itís stock rubber for me in all applications.
MYWAY likes this.
any4xx is offline
post #4 of 15 (permalink) Old Apr 4th, 19, 10:26 AM
Eddie
I run solid on driver side, stock mount on passenger side and stock on transmission. No vibrations whatsoever.
The reason is that when you step on the gas driver side extends and passenger side compresses. IMO having rubber on passenger side reduces the amount of vibration transmitted through the frame.
MYWAY likes this.
Eddie K is online now
post #5 of 15 (permalink) Old Apr 4th, 19, 10:31 AM
Iím running the same setup with the same results. No vibes here.
MYWAY likes this.
SSJohn is offline
post #6 of 15 (permalink) Old Apr 4th, 19, 10:48 AM
Mark
I'm running 600 ft*lb of torque, twin disc clutch, 4.10 rear gears, and a manual trans; and when I run sticky tires at the track, I figured a steel motor mount on the driver's side was a good idea because of the shock load on the mount. If I didn't have a performance engine, I would probably run poly mounts. I do get some very slight vibration in certain gears, but it is very small.
MYWAY likes this.
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is online now
post #7 of 15 (permalink) Old Apr 4th, 19, 11:35 AM Thread Starter
Thanks... With my motor at around 650tq I think I will stay with the solid divers and poly passenger. Like mentioned previously not the end of the world to change them out.
427L88 likes this.
MYWAY is offline
post #8 of 15 (permalink) Old Apr 4th, 19, 11:36 AM
Been using a solid on the drivers side and stock rubber on passenger side and on the transmission. Not a hint of vibration.And that's on 18+ years of drag racing and street driving my car.
And when I launch my car at the track,that gas pedal goes to the floor on the last yellow and my convertor flashes to 4,000
427L88 and MYWAY like this.
mr 4 speed is offline
post #9 of 15 (permalink) Old Apr 4th, 19, 12:00 PM
Switching back to a solid drivers side myself. 600+ ft lbs and a clutch. PS I didnt notice any reduction in NVH when I swapped the poly one back in some years back. I thought it would be "softer" Nope. Same. So solid goes back in.
MYWAY likes this.
post #10 of 15 (permalink) Old Apr 4th, 19, 1:29 PM
Marcus
Solid driver side rubber passenger and transmission no vibrations, Mike Lewis aka wolfplace balanced my rotating assembly.
427L88 and MarkP like this.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
57 3/4Ē wide 12 bolt: Eaton posi, Us gear 3.31, Toms KA 33 splines axles
Malibu ss 64 is online now
post #11 of 15 (permalink) Old Apr 4th, 19, 7:49 PM
As far as the Moroso brand. Which one for a big block Chevelle, the 62515 or the 62530 ?
Thanks Joe.
"... the very powerful and the very stupid have one thing in common. They don't alter their view to fit the facts, they alter the facts to fit their view." Dr. Who, 1977
NW68SSBBC is offline
post #12 of 15 (permalink) Old Apr 4th, 19, 8:27 PM
I have been running solid driver, rubber passenger with rubber trans mount with no issues at all. Highly recommended in fact.
I now switched the rubbers out to poly and will see if there is any difference. I honestly don't think there will be much difference, if any.
Youtube Channel.
Instagram:
Twitter:
-SS454- is online now
post #13 of 15 (permalink) Old Apr 4th, 19, 11:54 PM
Mark
Thanks Joe.
I just got a set of Lemon's headers, and he suggests a 62510. It is the same height as my Energy Suspension poly mount.
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is online now
post #14 of 15 (permalink) Old Apr 5th, 19, 12:44 AM
Solid mounts on both sides, no vibration except my teeth are worn now from chattering... JK JK
Pat_McNeil likes this.
'66 SS Chevelle
91 octane special
first day out
[email protected]
Stokerboats is offline
post #15 of 15 (permalink) Old Apr 5th, 19, 10:44 PM
I took a look at the Moroso website and can offer the following
62510 has a distance of 2 1/8" from the bolt hole to the block face surface
62515 is. 2 9/32"
62530 is. 1 3/4"
The 62500 is. 1 11/16" but the distance between the actual motor mount ears is 2 1/2" the other three are 2 3/8"
It's all on their site if my writing doesn't make sense
Thanks Joe
Nothingbut69 likes this.
This Thread is more than 426 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Solid Bench Seat Info Questions shawmon Wagons & Four Doors 6 May 30th, 17 8:11 AM
Failed ISKY EZ Roll bushing type solid roller lifter 540 RAT Performance 149 Jun 22nd, 15 1:24 AM
Solid Flat Tappet Questions Greg.H Performance 5 Feb 22nd, 15 11:42 PM
should i go solid cam? tchapps88 Performance 5 Jul 6th, 14 11:28 PM
Allstar solid motor mounts specs? ratengine Performance 5 Feb 17th, 13 4:54 AM
