"Support truck" engine build, 350 or 383? - Chevelle Tech
 5Likes
post #1 of 18 (permalink) Old Mar 17th, 19, 12:48 AM Thread Starter
Richard
Question "Support truck" engine build, 350 or 383?
It looks like I may need to rebuld the engine in my 81 C3500 "Support truck".
Currently a Goodwrench 350 but seems to be missing compression on three cylinders.
Had hoped it might just be another flat-cam, but no such luck.
So I will do a leak-down test on Sunday.
Doubt it is a heads/valves issue.
So if I'm into a rebuild anyway, pro's and con's of a 383 conversion kit?
This is a one-ton flat-bed truck used to carry or tow cars and parts.
No high compression or radical cams needed!
I liked the mileage of the 350 but sometimes wished for F.I. or a Turbo when climbing steep grades.
Never wanted am 8-mpg 454, but maybe a mild 383 would not kill me in gas while giving me the torque I need for crossing the Sierra's?
A 383 kit can be done for only about $800 more than a standard 350 if I stay away from go-fast goodies.
At these gas prices I want it 100+ octane, leaded, and my windshield washed!
Richard/SIA is offline
post #2 of 18 (permalink) Old Mar 17th, 19, 2:09 AM
Re: "Support truck" engine build, 350 or 383?
Id find a later model 350 block, preferably one that has Vortec heads, make sure it has provisions for a factory hydraulic roller camshaft and use that as the foundation.
Steve R
Blown1932 likes this.
Steve R is online now
post #3 of 18 (permalink) Old Mar 17th, 19, 5:42 AM
My vote goes for the 383 since it is mainly a towing vehicle. Use a cam that focus' more on low end torque than HP. I doubt mileage would suffer much since fuel mileage has more to do with engine load than it does displacement or speed.
buenymayor is offline
post #4 of 18 (permalink) Old Mar 17th, 19, 7:56 AM
Dont want to sound like a jerk, but would you consider an LS swap? It would run you more for a non rebuilt mill, for sure, but.... and then there is the 12 valve Cummins. The PERFECT light tow/ work truck mill.
Otherwise I'd vote for the most stroke/bore and smallest runners I could. To Brians point MPG may not be effected if the TQ and throttle position of the 383 are better suited. Roller cams are nice, but you can probably get buy with such gentle spring pressures for a 4500 rpm mill....?
If you weigh the kit against rebuilding the rods and crank, hanging new slugs, its a no brainer.
77 cruiser likes this.
post #5 of 18 (permalink) Old Mar 17th, 19, 12:10 PM Thread Starter
Richard
Current engine is not the original.
Labeled as a "Goodwrench" but that is all I know.
Need to keep this as simple as possible since this robs funds from El Camino build.
What years/markings would be corrrect for a Vortec head roller cam engine?
Do center bolt valve covers mean Vortec?
Yah, I'm mostly "Old School" and pay no attention to almost anything made after the 70's.
This truck is as new as I can stand to own, has disc front brakes, IFS, and NO COMPUTERS!
But I REALLY miss my old '57.
LS and diesel, never.
Diesel, double never.
427L88 likes this.
post #6 of 18 (permalink) Old Mar 17th, 19, 12:19 PM
Banned
Cory
I concur. Not that I'm a expert but it's just the right thang ta do.
dream66 is offline
post #7 of 18 (permalink) Old Mar 17th, 19, 12:59 PM
They came in late-90s trucks, carburetor manifolds are readily available.
post #8 of 18 (permalink) Old Mar 17th, 19, 2:12 PM
TBI heads were also center bolt and not worth bothering with.
70 Camino...Roller
Tommy the Cat is offline
post #9 of 18 (permalink) Old Mar 17th, 19, 3:55 PM Thread Starter
Richard
OK, so how to identify a Vortec head equipped engine?
Local Pick & Pull has lots of late 80's Chevy trucks, about $200.00 for a long block.
Do I go by the type of FI, will it have VORTEC marked in some manner?
I will want to use my old distributor too, no computers!
I'm sure some of you wonder how I could not know all this already.
Simple, I stopped paying attention to the new cars and trucks when the Fed. Gov. took over design in the 70's.
post #10 of 18 (permalink) Old Mar 17th, 19, 4:01 PM
Gary
the vortec blocks are great but it wont have a provision for a mech fuel pump so you will have to either go with an electric pump or use an older block. definitely use the vortec heads. i would use a 3 3/4 or even 3 7/8 stroke crank. keep the cam small and tight for low end torque. 260 on 106 to 108. you will have 500 ft lbs at 2k
gnicholson is online now
post #11 of 18 (permalink) Old Mar 17th, 19, 5:50 PM
The Vortec heads came on '96 and newer trucks. I don't know the casting numbers offhand and there's enough places selling them ready to bolt on that you would probably be time and money ahead to buy them built. I think they need modified for lift over about .450 and screw-in rocker studs. I've never used Vortecs but I think those are a couple of things that need addressed.
Vortec engines have a multi port looking intake, not the two barrel thottle body.
70 Camino...Roller
post #12 of 18 (permalink) Old Mar 17th, 19, 6:21 PM
gary
Some of the early roller lifter blocks did have mechanical fuel pump provision.
post #13 of 18 (permalink) Old Mar 17th, 19, 9:19 PM Thread Starter
Richard
So, in poking around the web it seems the Vortec heads have a "Sawtooth" casting on the ends, ^^^.
With that found it becomes reasonable to pop the covers and look for the casting number.
Now, to identify a roller-cam block?
Looks like those started in 1998?
post #14 of 18 (permalink) Old Mar 17th, 19, 10:05 PM
Justin
Pull the valve cover and find the casting number to see if they’re Vortecs. And you can find a casting number on the back of the block to see if it is a roller block or look through the pushrod holes to see what lifter are in it
JF74chevelle is offline
post #15 of 18 (permalink) Old Mar 17th, 19, 10:14 PM Thread Starter
Richard
Can the roller lifter "Spider" be seen without pulling the intake?
This Thread is more than 478 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
What engine should I build? 1966_L78 Bench Racing 23 Sep 24th, 18 12:46 PM
L34 350 HP 396 Build VORTECPRO Performance 12 Jul 16th, 15 8:55 AM
350 bored .40 over Build Help Clayton A Performance 18 May 4th, 15 10:44 AM
Identifying unknown 383 engine block boulonman Engine 8 Nov 10th, 13 3:25 PM
99 350 into a 383??? bynxr 1999 -- 5 Mar 15th, 99 4:45 PM
