Stock 1978 454, Air Gap Intake, Quadrajet? - Chevelle Tech
 27Likes
post #1 of 20 (permalink) Old Feb 14th, 19, 9:53 AM Thread Starter
Would it be worth it to swap to the Air Gap intake manifold on a stock 1978 454 motor.. I like the look of them and was wondering If it would add any performance over the stock Quadrajet intake. I would be using the Quadrajet carb, it runs perfectly.
I'm trying to make my 454 look like a 427 in my 69 el Camino SS396. Maybe Tri Power would be a better way?
Thank you..
hydro462 is offline
post #2 of 20 (permalink) Old Feb 14th, 19, 10:18 AM
Re: Stock 1978 454, Air Gap Intake, Quadrajet?
Swapping to the Air Gap will certainly help out in adding a little bit of HP and torque,even with it being stock.
IMHO,if you want the "427 look" add a reproduction GM "163" casting high rise square port intake and you can use a square bore to spreadbore adapter with your qjet.
Of course, a vintage Holley 3310 would really hit it out of the park..but qjets do work well.
Chevy 70 SS vert likes this.
mr 4 speed is offline
post #3 of 20 (permalink) Old Feb 14th, 19, 10:36 AM
Marcus
Edelbrock or no other I know of make air gap intake that has spread bore bolt pattern for the BBC of course you can use an adapter.
Edelbrock rpm 7164 is the regular rpm q-jet version.
Steve R and 71454Chevelle like this.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
post #4 of 20 (permalink) Old Feb 14th, 19, 10:53 AM
If the 1978 454 is truly stock, it has "peanut port" heads - and a very tiny cam! This was done to make lots of low end torque at the cost of higher RPM power. If you want an aftermarket manifold for that the Edelbrock Performer 2-O would be a better choice as it is a "peanut port" intake. The Air Gap is made for Large Oval Ports.
Steve R likes this.
1975TypeS-3 is offline
post #5 of 20 (permalink) Old Feb 14th, 19, 10:57 AM
It will help, but I would swap the carb with an Edelbrock as well.
ZEN357 is offline
post #6 of 20 (permalink) Old Feb 14th, 19, 10:58 AM
I would look at the weiand 8122 if it has peanut port heads, and you want a spreadbore manifold.
https://www.summitracing.com/parts/wnd-8122/overview/
fr8dog likes this.
novadude is offline
post #7 of 20 (permalink) Old Feb 14th, 19, 11:02 AM
Last bone stock,untouched 1978 454 I worked on was a 361959 casting with 781 heads.
dell72 and shovelrick like this.
post #8 of 20 (permalink) Old Feb 14th, 19, 11:17 AM
Darren
I was under the impression that they went to peanut port heads in 77.
Darren
1971 Chevelle
496
10.5 scr
CFM Ported Victor Jr / Pro Systems Venom VX 1050
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Moser axles
30x12.5 ET Street Radial
525+++ rwhp
71454Chevelle is offline
post #9 of 20 (permalink) Old Feb 14th, 19, 11:20 AM
I agree with Mr. 4 speed, I also had an untouched 78 vintage 454 with 781 heads.
mr 4 speed likes this.
dell72 is offline
post #10 of 20 (permalink) Old Feb 14th, 19, 11:24 AM
I have seen them with 236 peanuts and 781 ovals.
last one I touched had 781 heads
either way, the RPM or RPM Air gap will wake up a stock 454
and IMHO and experience,the carb you chose is a personal choice.
I personally love the 3310 on my big block...runs in the 11's and I can drive it anywhere. Lights the tires up at highway speeds. And I haven't touched the carb in many years (I bought it 18 years ago)
That's reliability and performance in my mind.
..and a Qjet works well on a 454. A fellow member here got his numbers matching all 100% stock (except for Hooker headers) 1974 454 4 speed Corvette into the mid/low 13's
post #11 of 20 (permalink) Old Feb 14th, 19, 11:41 AM
Marcus
X2 on the 3310 but a well build qjet will also work very good.
post #12 of 20 (permalink) Old Feb 14th, 19, 10:08 PM Thread Starter
The passenger side head under the valve cover has these numbers.
336781
GM12T
E8078
Can you tell what heads these are?
71350SS likes this.
hydro462 is offline
post #13 of 20 (permalink) Old Feb 14th, 19, 10:18 PM
Gary
they are 781s. last 3 digits of the casting number. good heads
gnicholson is offline
post #14 of 20 (permalink) Old Feb 14th, 19, 11:55 PM
Bruce
It would be easier and more authentic-looking to dress the 454 up look like a 350 horse 396 -- you could keep your Q-Jet.
blue_69_malibu and hydro462 like this.
Our You Tube Vids:
NickeyChevelle is offline
post #15 of 20 (permalink) Old Feb 15th, 19, 6:19 AM
von
Lifetime Founding Member
Von
FWIW a regular Performer RPM looks a lot more like the GM 163 intake than the Air Gap IMO.
shovelrick likes this.
von is offline
454 (.030), 10:1cr, Air Gap, Brodix 270 RRO, Clay Smith 229/241 65cayne Performance 159 Yesterday 8:19 AM
stock engine parts search, 1973 454 V8 jguadiana RockAuto 0 Apr 21st, 17 11:43 AM
Stock iron intake Vs performer RPM Dyno and ET jeff swisher Performance 23 Nov 4th, 15 6:36 PM
Carb Flooding- Stock Quadrajet yanktanks Troubleshooting 13 Dec 7th, 13 3:27 PM
1966 SS With 454 Intake Suggestions countryroad82 Performance 9 Dec 12th, 12 12:46 AM
