Choppy Cam - Chevelle Tech
 14Likes
  • 2 Post By 427L88
  • 1 Post By hydro462
  • 5 Post By BillK
  • 1 Post By 67camaro69
  • 2 Post By novadude
  • 3 Post By cuisinartvette
post #1 of 11 (permalink) Old Dec 12th, 18, 8:24 PM Thread Starter
Albert
Choppy Cam
Got another project in the works. 454 .030 over etc.. This for a friend of mines nova. He wants a mean sounding choppy camshaft. Nothing too crazy What would you guys recommend? I would like to stick with Howards or comp cams but any suggestion would be great. btw the other project came along great. the car performs better in the street. and I have brakes now. Thanks for the help.
1967 Camaro RS 396
1969 Camaro Coupe 427
67camaro69 is offline
post #2 of 11 (permalink) Old Dec 12th, 18, 11:27 PM
Vince
Re: Choppy Cam
Howards Cams, Hydraulic Flat Tappet Camshaft, Chev BB Mark IV 396-502, 237/[email protected] .050, .553/.553, 110 LS - Competition Products
VinceS427bb is online now
post #3 of 11 (permalink) Old Dec 13th, 18, 5:34 AM
Geoff
Re: Choppy Cam
The Comp Mutha Thumper cams are another option.
Gtogeoff is offline
post #4 of 11 (permalink) Old Dec 13th, 18, 5:55 AM
Re: Choppy Cam
Compression, gears, head config, useage, etc would be required information for a proper fit. For a wild azz guess any cam with a tight LSA will give some lope. Why not look at the Clay Smith cam designed for oem BBC heads: BBC 454 to 470 CID ?Old School? OEM 049/781 heads to a max of 5700 RPM - Clay Smith Cams
fr8dog and Crazychevelle67 like this.
post #5 of 11 (permalink) Old Dec 13th, 18, 7:17 AM
Re: Choppy Cam
I would use the better street performing, smooth camshaft and rig a solenoid to the vacuum advance, flip the switch when you want a lope..
novadude likes this.
hydro462 is offline
post #6 of 11 (permalink) Old Dec 13th, 18, 7:46 AM
Re: Choppy Cam
Summit 238/[email protected] .540/.540 114 LSA will have the idle you seek and will perform very well.
A good friend of mine runs this cam in a 8.9:1 compression 454 and it runs mid/low 12's on 87 octane w/3.42 gear in a 4000+ lbs. w/driver 69 Chevelle
mr 4 speed is offline
post #7 of 11 (permalink) Old Dec 13th, 18, 8:17 AM
Mr Bill
Re: Choppy Cam
Call Eric at Howards and ask him. Comp has their Thumper cams also.
Make sure your friend knows that "sounds good" usually does not equal "runs good" on a mild street engine.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #8 of 11 (permalink) Old Dec 14th, 18, 4:37 AM Thread Starter
Albert
Re: Choppy Cam
Street, Weekend warrior., closed chamber heads will add stronger springs, Manual 4 speed,
427L88 likes this.
1967 Camaro RS 396
post #9 of 11 (permalink) Old Dec 14th, 18, 11:09 AM
Re: Choppy Cam
This. Pick the right cam that matches Compression, Heads, Gearing, etc and don't choose a cam on sound. A car that runs well is much more fun than a car that only sounds like it runs well.
Molly's 70 and hydro462 like this.
novadude is offline
post #10 of 11 (permalink) Old Dec 15th, 18, 12:43 AM
Re: Choppy Cam
THumpr are poser cams, for stock low compression motors.
Plenty of cams that work that give good sound why waste his money?
Heck, the old Isky Mega cams work great, are cheap, sound great and pull hard. Wont go flat either
cuisinartvette is offline
post #11 of 11 (permalink) Old Dec 17th, 18, 7:15 AM
Re: Choppy Cam
The old Isky MegaCams are cut on a nice tight LSA ( lobe separation angle) as well. Between the cc heads and the tight LSA, it should have really good mid range pull. The Summit cams mentioned are use widely as well. Here are four cams fromt eh Summit catalog. I would choose the smaller grinds unless the engine is over 10:1, but any would work.
https://www.summitracing.com/parts/isk-396281
https://www.summitracing.com/parts/isk-396271
and in the Summit line: https://www.summitracing.com/parts/sum-1302
and the one mr4speed mentioned: https://www.summitracing.com/parts/sum-1303
And while I've never done the solenoid thing, I can;t see why the complexity of a solenoid is required when you can set the idle circuit "incorrectly" to lope rather easily.
And while many here consider the Thumpr's as posers cams, ( well it is a marketing schtick), they run rather well due to the crappy exhaust port of BBC heads, esp those old CC heads. I dont prefer them as there is no lift, but you get that overly choppy sound. This is the only one I;d recommend:
11-601-4 - Thumpr? Hydraulic Flat Tappet Camshafts
and my favorite street BBC cam from COMP I've NEVER run ( an academic recomemndation!) : XS274. 11-677-4 - XTREME Energy? Mechanical Flat Tappet Camshafts
This Thread is more than 574 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
