Edelbrock Return Spring Bracket... - Page 3 - Chevelle Tech
 2Likes
post #31 of 48 (permalink) Old Dec 3rd, 18, 8:14 AM
jeff
Re: Edelbrock Return Spring Bracket...
I think it is the lower RPM he tested at and the large runner heads on the 377" engine.
What I found with the Comp cam ratings is that is about where they make Max HP.
My 268H on the wheel dyno made Max HP at 5700rpm and the 280H in the same 350" made max HP at 5870 RPM
I am limited a bit on cylinder head though 601 casting 305 head with 1.84-1.50 valves.
On my roller 357" the roller is 228 [email protected] .050 .495" lift on 110 LSA it made max HP at 5840 rpm but pulls hard to 7000+
I wonder if your AFR if way off or if maybe the engine is just built tight.
Mine are all on the loose side .0035" piston to wall clearance with cast pistons.
I was 1000 rpm down on a tight engine i had built years ago .0015" with cast pistons.. thing would not get out of it's own way is the way it felt to me..
I will not build another tight one.
But this is old school cast pistons with long skirts and 5/64" rings 620 grit cylinder wall finish.
jeff swisher is offline
post #32 of 48 (permalink) Old Dec 3rd, 18, 10:57 AM Thread Starter
Originally Posted by Tom Mobley View Post
are you dead sure you're checking the vacuum at manifold port, not ported?
something is not right about this.
I plug my vacuum gauge into the hose for the power brake booster. It goes straight to a fitting on the intake itself.
My Chevelle w/ open headers:
WakkoWarner is online now
post #33 of 48 (permalink) Old Dec 3rd, 18, 11:01 AM Thread Starter
I have had this engine since 2007 and it has about 50,000 miles on it. I have not idea if it is tight or loose. The shop that built it is no longer in business due to many customer complaints. When I punch it, it goes and pulls strong.
jeff swisher likes this.
post #34 of 48 (permalink) Old Dec 3rd, 18, 1:04 PM
jeff
It is loose by now.
The one I had the machine shop bore and hone I did not specify clearances..Heck I was new at having stuff bored out.
So I was running the 268H and ported and milled 76cc iron heads heads in a standard bore worn out 350" and busted the skirts but that thing pulled hard to 6500rpm.
I drove it 30,000 miles like that and pulled it apart and had it bored and honed.. was .0015" piston to wall and the thing with all the same exact parts except pistons rings now only revved to 5000 rpm after that it nosed over and felt weak.
After 30,000 more miles it was revving to 5500rpm and felt better. still 1000 rpm down from the loose deal.
Next one I built had .0045" then I did a .0035" and it felt just like the .0045".
I put many more miles on my stuff than you, one year I drove 70,000 miles as did the wife in another car.
Well I stopped count on hers at 65,000 miles in 11 months.
Lot of testing happening in a short time you know. Lot of oil changes also.
I found the 268H will rev cleanly to 6500 pretty easy without any feeling of nosing over. In fact at the track the 6500 or 5000 or 5500 or 6000 shift point resulted in only 2 tenths difference.
The 270H was 6900rpm sweet spot. 280H was 7200 sweet spot and 292H was 7400rpm.
This is with small chamber ported heads with 1.94-1.50 valves.
If using smaller intake valve RPM was less and if the port job was not done then you would be down 1000 rpm.
Good shaped intake runners make a huge difference I have found.
post #35 of 48 (permalink) Old Dec 3rd, 18, 2:42 PM Thread Starter
I do know that from the beginning this engine always pulled strong. The crank and rods are made by RPM (forged 4340 on the crank, and the rods are forged h-beam). The pistons are forged Probe SRS units (12cc dish). Does anyone know if using 1.6 rocker arms affects the overlap on a camshaft??
post #36 of 48 (permalink) Old Dec 3rd, 18, 5:39 PM Thread Starter
I am really wanting to like this Edelbrock, but it still has a slight stumble occasionally from part throttle. I did change out the step up springs this afternoon (I had to scramble to find one of the springs that hold the metering rods to the plunger, as it was already broken when I pulled the plunger out of the carburetor - a local auto shop had one and gave it to me - now I think I need to source one or two and take one to him so he has it).
The accelerator pump is in the middle position. I do have a rebuild kit on the way, so it will get a new plunger (that may be what is causing the issue, since it sat without fuel in it for about a month before I bought it). Once I get that and get the top off, I can check the float levels, put new needles and seats in, and see if there is any crap in it.
I really like the way it pulls at WOT - it just seems to be better than the Speed Demon. 1967 chevelle malibu (Gary) let me bring it by his house last weekend to get a second set of eyes on it to see how the throttle shafts were. When they are open, there really isn't any play in them. So, I think it is just a matter of doing some tuning on it to get it where it should be. The 1411 is 2% leaner than the 1407, according to Edelbrock. If I can't get the slight stumble at part throttle tuned out, would a jump up in squirter size help??
post #37 of 48 (permalink) Old Dec 4th, 18, 4:19 AM
Geoff
Once float level has been verified, use a met rod with a richer power step for the part throttle stumble. Go at least 0.005" richer [ preferably 0.010" ]. If this fixes the stumble, lean out the power step on the rods until you have the rods just rich enough to remove the stumble.
You may also need to increase the nozzle size on the acc pump nozzle. Increase in 0.002" increments. This would be a last resort.
Remember, ALL these carbs are 'universal' fit & it is unrealistic to expect a carb to bolt onto every engine & work perfectly without modification/tuning.....
Gtogeoff is offline
post #38 of 48 (permalink) Old Dec 6th, 18, 2:40 PM Thread Starter
It is also backfiring on acceleration from idle occasionally. I wish that the tuning kits weren't so much money. They really should be about half of what they charge for them.
post #39 of 48 (permalink) Old Dec 7th, 18, 7:45 PM Thread Starter
I got a kit today and put it in - including a new accelerator pump assembly. The floats are adjusted correctly. I found something that was contributing to the throttle not returning to the idle position and corrected that. But, once I got it fired up and took it for a drive, it really isn't any better than it was. It has an off idle stumble that irritates me (it has 35 size squirters in it). So, I am done with it. I will put the Speed Demon back on tomorrow and call it good. I just don't have the patience to keep tinkering with the Edelbrock to make it work. Plus, I am done spending money on it. It will get emptied out and sit on a shelf in my shed.
post #40 of 48 (permalink) Old Dec 7th, 18, 10:28 PM Thread Starter
I took a short video this afternoon with a vacuum gauge hooked up to the manifold vacuum port on the carburetor, just so you can see what the vacuum is at idle in gear.
https://www.dropbox.com/s/2hcu1nsgno...55332.mp4?dl=0
post #41 of 48 (permalink) Old Dec 8th, 18, 8:09 AM
gary
Does it return to idle with the new kit?
post #42 of 48 (permalink) Old Dec 8th, 18, 10:40 AM Thread Starter
The problem I found was with the s hook on the accelerator pump rod. It was twisted and compressed a little, which was causing the primary
throttle blades to stay open. It seems to return to idle for the most part, but occasionally it will be about 150 RPM higher than it should.
I just don't have the patience to deal with it anymore and I don't want to spend any more money on it. I will just put the Speed Demon
back on today and put the Edelbrock in the shed.
post #43 of 48 (permalink) Old Dec 8th, 18, 11:31 AM
jeff
Man that sucks.. sure looks like a low idle vacuum. I had one car that pulled 5" at idle and I had to add a lot of jet to it to make it happy.
[email protected] .050 cam and 9.0 compression and afr 210cc heads on a 355".
post #44 of 48 (permalink) Old Dec 9th, 18, 3:38 AM
which of the scales on that gauge are you reading? I can't bread the labeling much.
seems like it would have about 12-13 vac at idle.
post #45 of 48 (permalink) Old Dec 9th, 18, 11:04 AM Thread Starter
If you look at where the needle is pointing, you will see the 0 - 5 - 10 area - that is the vacuum portion of the gauge.
I have decided, however, that I will try the Edelbrock one more time. It just seems to pull harder than the Speed Demon does. I will adjust the accelerator pump rod to the top hole and see what happens. If the off idle stumble goes away, then I will mess with the step up springs to see if I can eliminate the part throttle issue (feels like it loses power). The mileage with the Edelbrock was still around 6.5, but I was getting on it more (because it actually pulls harder when I am in second gear than the Speed Demon did)
I just want to get it sorted out and leave it alone - the Speed Demon seems to develop issues every year (but at least it has no off idle stumble).
