Sad day. - Page 2 - Chevelle Tech
 5Likes
post #16 of 18 (permalink) Old Dec 11th, 18, 8:51 PM Thread Starter
Albert
Re: Sad day.
Originally Posted by 71350SS View Post
Did you ever get to run it for about a half hour or so ? from what I read from your posts it souds like you never started it up.If so, it sounds like the timing isn't allowing it to start and run long enough to break in the cam and/or to find out what's wrong with the engine.
Yea I did start the engine for about 25 minutes. I just switched carbs and adjusted the timing it started right up..
1967 Camaro RS 396
1969 Camaro Coupe 427
67camaro69 is offline
post #17 of 18 (permalink) Old Dec 11th, 18, 8:54 PM Thread Starter
Albert
Re: Sad day.
Originally Posted by shovelrick View Post
I'd ask your machine shop to inspect the engine but you'll have to pull it and bring it to them, did you get it to run for cam break in? cam would be a good idea to take a close look at it now also for flat lobe or anything abnormal if you didn't get it broke in
Originally Posted by Rich-L79 View Post
Could incorrect to damaged gaskets allow oil to get in the water?
BTW, a 454 and 427 block are functionally the same. Your 427 rotating assembly would drop right in as long as the block is bored the same amount as your 427 block is.
I'm going to talk to my machine shop today and see what are my options. Thanks. I haven't taken out that cam yet but ill inspect it when I do.
1967 Camaro RS 396
post #18 of 18 (permalink) Old Dec 11th, 18, 9:18 PM
Freddy
Re: Sad day.
Hope all is well with your motor...
Steve R likes this.
Freddy
Freddy Mercado is offline
