69 bbc oil filter relocation ideas - Chevelle Tech
 6Likes
post #1 of 17 (permalink) Old Nov 5th, 18, 10:06 AM Thread Starter
Paulie
Hey guys the search doesnít bring back many references so Iím asking where you have relocated the oil filter on a BBC in a 69. Pictures would be great. I bought the plate, fittings and a single mount. But not happy with any positions other than forward someplace.
Paulie
BigBlockPaulie is offline
post #2 of 17 (permalink) Old Nov 6th, 18, 5:40 PM
Re: 69 bbc oil filter relocation ideas
Paulie, be real careful with that stuff. check the ID of every fitting, hose and the plate itself. Guys have lost engines over 1/2 NPT fittings with 5/16 holes in them. Street elbows are a big loser.
OLDED, fr8dog and lucifershammer like this.
post #3 of 17 (permalink) Old Nov 6th, 18, 6:27 PM
Do you have interference issue to run the stock block mounted oil filter?
I ran a remote oil filter setup on a Pontiac, back in the 80ís. Broke in a new motor and wouldnít you know it, one of the lines burst spraying hot oil on my red hot headers. Needless to say I had one helluva fire. Iíd do everything I could to not run a remote filter, but if you must, run the best quality AN hose and fittings. Aircraft Spruce has some really good FAA/TSO approved AN hose and fittings.
OLDED likes this.
Video:
fr8dog is offline
post #4 of 17 (permalink) Old Nov 7th, 18, 8:48 AM Thread Starter
Paulie
Jeff and Tom, yes Iíd have to unbolt the drivers header to change the oil. Granted, synthetic and a Royal purple filter, I wouldnít change it often but yes, definitely a no go on stock location. So the Ďbestí I got so far is aeroquip 90 degree 8an push on fittings off the block plate tucked against the block forward, under the power steering to the frame / inner fender up into the left cubby hole by the backside of the left inner head light
or the other route is between the bottom core support and frame to attach to the front core support behind the bumper. The hose and fittings are the speedway neoprene push on kit. Iíve never used a blue push on hose, always braided steel or pro classic black. Iíve used a rubber hose and clamps on transmission coolers but not engine oil. I have plenty of 8an fittings to change to the Pro Classic hose set up if the push on is too iffy. Just have to get hose. People are happy with the push on stuff, but Iíve had no experience with it. Good or bad.
fr8dog likes this.
Paulie
post #5 of 17 (permalink) Old Nov 7th, 18, 7:01 PM
Have you thought about different headers for more clearance? Just out of curiosity, what brand headers are they?
Video:
fr8dog is offline
post #6 of 17 (permalink) Old Nov 8th, 18, 12:25 AM
look at these
https://www.ebay.com/itm/BARNES-ALUM...UtI:rk:14:pf:0
mounts filter horizontally on the block, no hoses.
post #7 of 17 (permalink) Old Nov 8th, 18, 8:16 AM Thread Starter
Paulie
Thank you for that link, I checked it out. I had 2Ē Dougís headers before that I could forcibly squeeze past. These are new 1 7/8Ē coated from Jegs. They fit the car better but at the expense of the filter. Always something.
Paulie
post #8 of 17 (permalink) Old Nov 8th, 18, 11:18 AM Thread Starter
Paulie
Here a shot down the side of the motor where the filter goes. You can see the AN
nipples. Thanks but I donít see an option. Itís more about the push on hose, Iíll get some fire sleeve and mount it up front.
Paulie
post #9 of 17 (permalink) Old Nov 8th, 18, 11:41 AM
Guy
Paulie,when I went with a remote filter on my BBC Monte my buddy and I made a couple of brackets mounted to studs in the oil pan rail.The brackets secure the hoses in place so they aren't flopping around and possibly touching the headers.Heres a picture;
Name:	DSC_0250 (2016_04_18 13_36_38 UTC).jpg
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is online now
post #10 of 17 (permalink) Old Nov 8th, 18, 11:45 AM
Man... sounds like youíve already swapped headers. Iíve had to run remote filters twice and both times I spent too much of my time trying to get everything to stop leaking. I put Hedman Elite headers on my Ď68 BB and I can easily run the tall oil filters. But that doesnít really answer your question. Have you considered running it inside the frame rail under the driverís door?
any4xx is offline
post #11 of 17 (permalink) Old Nov 8th, 18, 12:55 PM
what size are the holes in those fittings?
post #12 of 17 (permalink) Old Nov 8th, 18, 6:54 PM Thread Starter
Paulie
Wow nice parts on that motor! I see the brackets you guys made, held it great I bet Iíll have to make up something like that too.
GuysMonteSS likes this.
Paulie
post #13 of 17 (permalink) Old Nov 8th, 18, 6:59 PM Thread Starter
Paulie
Yeah, thatís funny cause I laid under there thinking all the places I could run it too. Itís just each areas is busy, a bad idea or hot.
Paulie
post #14 of 17 (permalink) Old Nov 8th, 18, 7:09 PM Thread Starter
Paulie
Tom; itís all Aeroquip 8 AN fittings and hose. I just ordered Thermo-flex heat barrier tubes, and stainless zip ties for underneath the headers just to play it safe. Excessive? maybe.
Paulie
post #15 of 17 (permalink) Old Nov 8th, 18, 7:35 PM
Guy
Thanks for the compliment,Mike Lewis was a huge help with parts selection.
And those brackets have been working very well for a number of years now.
I believe that I used the same Thermo Flex stuff to wrap my lines too
Guy
'86 Monte SS,
513 Stroker,
9 inch rearend,
TC Member # 4921
