Another cam question - Chevelle Tech
 7Likes
post #1 of 20 (permalink) Old Sep 19th, 18, 8:37 PM Thread Starter
Hi I am new here. I have been a long time reader on here but never registered til just yesterday. I have a cam question! Yes I know not another one?? Well if have been doing a lot of reading. In fact I read an old post on here from 2007 ! In the thread someone mentioned putting a comp cam xm270h cam in a stock 325 horse 396 with oval port heads. They said it ran awesome. Thats exactly what I want to do same cam and the same motor a stock 325 horse 396. I have the whole kit springs and everything even a set of nice crane gold roller rockers. Has anybody else run this cam before?? Is there anything I need to watch for any modification I need to do. Valve clearance be okay???? Thanks Brad
Shbradford is offline
post #2 of 20 (permalink) Old Sep 21st, 18, 5:29 AM Thread Starter
Anyone????????
post #3 of 20 (permalink) Old Sep 21st, 18, 5:44 AM
Geoff
Re: Another cam question
Are you talking about the Comp Cams 270H Magnum hyd flat tappet cam?
If so, that is a nice shelf grind with good manners for a mild engine.
Gtogeoff is offline
post #4 of 20 (permalink) Old Sep 21st, 18, 6:48 AM Thread Starter
No it’s actually the xm270h marine grind
post #5 of 20 (permalink) Old Sep 21st, 18, 7:09 AM
That cam should run pretty well in any 396-427-454,specs are 226/[email protected] .544/.547 112 LSA
mr 4 speed is offline
post #6 of 20 (permalink) Old Sep 21st, 18, 7:14 AM Thread Starter
I shouldn’t have any valve clearance issue should I ??? Everything I have read makes me think it shouldn’t have any problems!
post #7 of 20 (permalink) Old Sep 21st, 18, 7:19 AM
To be sure, get some clay, and run a set of valves with clay, sans head gasket, and then measure clearances + head gasket thickness. Only one way to know for sure. You should be fine.
post #8 of 20 (permalink) Old Sep 21st, 18, 7:38 AM
FWIW, years ago I had a 396 +.030 with rebuilder .180 tall domed cast pistons and 215 closed chamber heads.
Cam was Crower solid lifter, 240/[email protected] .517/.530 114 LSA and there were NO piston to valve clearance issues.
More than likely you'll be fine but you should check to be sure.
post #9 of 20 (permalink) Old Sep 21st, 18, 8:20 AM Thread Starter
Wellllllll!!!! I know I should that is always the proper thing to do 😳but this is a cam swap and I do not want to pull the heads sooooo 🤞
427L88 likes this.
post #10 of 20 (permalink) Old Sep 21st, 18, 8:36 AM
A fellow TC member recently installed a 228/[email protected] .540/.540 114 LSA Summit cam into his 396/325 HP and he had no clearance issues,car runs great.
Not sure if the thread is in the engine or performance forum.
FWIW...
post #11 of 20 (permalink) Old Sep 21st, 18, 8:40 AM Thread Starter
Awesome thank you !!!!!!
post #12 of 20 (permalink) Old Sep 21st, 18, 9:00 AM
Going to hit this out of the park in regards to piston to valve clearance: back in the day, (I have the vintage magazine article-circa 1969) there was a feature about hopping up a 396 using the L88 cam.
The article states the small domed pistons in 325 and 350 HP engines had no clearance issues with that cam but taller domes in the L78 engines had to be clearanced.
The L88 cam is 264/[email protected] .560/.580 112 LSA
427L88 and the heckler like this.
post #13 of 20 (permalink) Old Sep 21st, 18, 9:57 AM
simply run the engine around by hand after install Bradford, and pay attention! Like said, you ought be fine. New flat tappet cam run in procedures are what needs a bit of nervous anxiety focused on. Never a guarantee with a rat.
mr 4 speed likes this.
post #14 of 20 (permalink) Old Sep 21st, 18, 10:03 AM
..what Gene said..also,make sure all the lifters spin freely in their bores.
427L88 likes this.
post #15 of 20 (permalink) Old Sep 21st, 18, 10:08 AM
kevin
almost identical specs to the Engle HL-25/26 I have had in my closet for over 20 years.
the heckler is offline
This Thread is more than 397 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
