Aeromotive 18404 - Aeromotive Gen II Stealth Fuel Tanks - Page 3 - Chevelle Tech
 12Likes
post #31 of 65 (permalink) Old Nov 3rd, 18, 3:23 PM Thread Starter
Alex
Re: Aeromotive 18404 - Aeromotive Gen II Stealth Fuel Tanks
What year are you putting it in?
Originally Posted by petey1549 View Post
I decided to try one of these tanks as well. It's a nice piece, but I'm finding that the fuel fitting area isn't recessed anywhere close to enough to let the tank fit up close to the floor. Even without the fuel lines connected the fittings are hitting the trunk floor long before the tank is fully raised. All the fancy features in the world are pretty much useless if the damn thing doesn't fit properly in the car. Looks like either fashioning some spacers for the tank to rest up against or beat a cavity in the front of my freshly painted trunk floor (the latter isn't really an option that's on the table).
Sent from my SM-G930V using Tapatalk
1969 Chevelle SS --- 468 FTI Level 4 TH400 AFR 290cc's
1997 S10 SS ---LQ9/4l65e
Chevymec is offline
post #32 of 65 (permalink) Old Nov 3rd, 18, 6:43 PM
Putting it in a 70 Chevelle (or at least trying to). Looks like it's all coming down to about a 1/2 inch. No way to lower the fuel fittings on the tank and no way to raise that area of the floor pan, so it looks like the tank is gonna have to sit about a 1/2" low in the front on some urethane spacers. At least for a little evaluation and until I speak with the folks at Aeromotive on Monday.
petey1549 is offline
post #33 of 65 (permalink) Old Nov 3rd, 18, 8:43 PM Thread Starter
Alex
@petey1549 ,
Please let us know what they say.
Chevymec is offline
post #34 of 65 (permalink) Old Nov 3rd, 18, 9:24 PM
Lew
I am going to try one of these. I have their Gen 1 nice but can see advantages of the Gen 2. They indicated on mine (1965 Chevelle) that the outlet was located in the front just like the factory. I can see from the above there is not a lot of room for the fittings. We shall see how far in the front mine is.
Lew540 is offline
post #35 of 65 (permalink) Old Nov 6th, 18, 7:01 AM
I spoke with tech support at Aeromotive yesterday about the fuel fitting clearance issue I have. I'm not sure if I should call out anyone by name so I'll just say that the gentleman I spoke with was friendly and genuinely concerned about my issue. In the end, it was determined that no similar issues have been reported by other customers and the issue is likely unique to my project. As much as I'd like to say that's a canned response used for everyone, I do have a knack for encountering unique problems
All kidding aside, this tank seems like a nice piece so far. I'm sure if anyone else runs into any problems with one, the folks at Aeromotive will absolutely help resolve it.
Chevymec likes this.
post #36 of 65 (permalink) Old Nov 6th, 18, 11:22 AM Thread Starter
Alex
@petey1549 , does your car have the original trunk pan?
Chevymec is offline
post #37 of 65 (permalink) Old Nov 6th, 18, 7:15 PM
Bernard
I called Aeromotive also concerning @petey1549 issues since I am preparing to install my tank within the next week. The tech indicated that they actually test fitted the tank to a 1970 Chevelle and had no problem with fitment. He did mention there was one call earlier inquiring about the same topic. Good question regarding the floor pan.
burn6si is offline
post #38 of 65 (permalink) Old Nov 8th, 18, 11:13 AM
Yes, all original trunk pan, braces, etc. In excellent condition as well so no warps, dents or other deviations.
post #39 of 65 (permalink) Old Nov 8th, 18, 12:20 PM
Are your body mount bushings collapsed?
70 Camino...Roller
Tommy the Cat is offline
post #40 of 65 (permalink) Old Nov 9th, 18, 8:43 AM
Since the tank fastens only to features of the trunk floor, body mount bushing condition is irrelevant to clearance between the tank/floor. That being said, all bushings are new. This car is a full restoration build. The only work required on features related to tank installation/trunk floor was new body mount cage nuts welded in to the trunk floor outer braces. The inner braces (which the tank actually rests against) were flawless.
ID:	578434   Click image for larger version
post #41 of 65 (permalink) Old Nov 9th, 18, 9:09 AM
The tech at Aeromotive also let me know that the hat/fitting assembly on these tanks can be loosened and rotated up to +/-90deg. That may help some folks as the fittings; being splayed apart from each other, do come in contact with stamped features of the trunk floor that exist to add geometric rigidity to the floor and close the gap between the tank and floor in some areas. I'm going to look over my install and see if I can get any benefit from rotating the fitting assembly.
post #42 of 65 (permalink) Old Nov 9th, 18, 9:16 AM
Lew
I know the tank on the 1965 comes with a 1/16 of an inch cushion (like hard tar paper) piece that's goes along rail / top of gas tank there that prevents tank rattle. Not sure if had put that on, but maybe glue like 2 or 3 together so you get like another 1/8 - 3/16 more clearance. No sure how far off you are.
Lew540 is offline
post #43 of 65 (permalink) Old Nov 9th, 18, 9:32 AM Thread Starter
Alex
I hope they aren't leaving the R&D to the consumer.
Chevymec is offline
post #44 of 65 (permalink) Old Nov 9th, 18, 9:37 AM
Yeah, I ended up cutting down some extra urethane body bushings to capture between the front of the tank and floor. I'm ok with this method as; like you say, it'll give some cushion to the tank. Needed 1/2" longer hangar bolts to get the straps installed. Checking to see if the exhaust will safely pass the front edges of the tank now. If so, it can live this way.
post #45 of 65 (permalink) Old Nov 9th, 18, 12:49 PM
Yeah, duh. I just had the tanks out of my C20 and the cab was really close to them until I replaced the cab mounts. Got my cars mixed up. Guess I can't offer any advice but I'll be watching for an update on your situation. I'd like to order one of these for my '69 but not if it's going to be a hassle.
70 Camino...Roller
