70 chevelle divorced choke position - Chevelle Tech
 4Likes
  • 1 Post By Tom Mobley
  • 2 Post By neaswa
  • 1 Post By surmin69
post #1 of 10 (permalink) Old Jul 2nd, 18, 2:32 PM Thread Starter
Hello forum-
I recently had my carb rebuild by a reputable re-builder and I'm not sure how to set the choke. When the engine is cold the choke spring pressure wants to keep the choke plate fully open. It seems like the choke spring, specifically where it holds the actuating rod, is not in the correct position for a cold engine (see attached pic). Is the choke spring adjustable?
neaswa is offline
post #2 of 10 (permalink) Old Jul 2nd, 18, 2:38 PM
Roland
Re: 70 chevelle divorced choke position
Originally Posted by neaswa View Post
Hello forum-
You need to step on the gas pedal and let off completely to set the choke to closed. The choke is "tripped" by the pedal, so to speak.
You should also put a plug on that vacuum "pipe" coming out of the carb by the choke if you don't have something on it that was removed for the pic. Leaving it open creates a manifold vacuum leak.
This might help verify the choke. Posted this last week.
"The man who lets a leader prescribe his course is a wreck being towed to the scrap heap."
-Ayn Rand
Buzzbomb is offline
post #3 of 10 (permalink) Old Jul 2nd, 18, 8:13 PM Thread Starter
Thanks Buzzbomb, I set the choke rod according to the video. The choke plate still stays full open after I step on and release the gas pedal. Any other suggestions?
neaswa is offline
post #4 of 10 (permalink) Old Jul 2nd, 18, 10:01 PM
Bart
The spring might just be worn out and not constricting (when cold) enough to pull the choke plate down. I had this problem on my 69. A new one fixed that problem. Just a guess.
69SS Daytona yellow
L35, M-20, 3.73
"AC's 2 by 75...... you roll'em down & drive
"Time treats everybody like a fool"
surmin69 is offline
post #5 of 10 (permalink) Old Jul 3rd, 18, 12:41 AM
how true it is.
post #6 of 10 (permalink) Old Jul 3rd, 18, 12:43 AM
be aware, the 6-cylinder spring looks the same but winds in the wrong direction when heated. Ignorant vendors sold these for V-8 parts for many years. decades?
Buzzbomb likes this.
post #7 of 10 (permalink) Old Jul 3rd, 18, 12:48 AM
pull the little tin shield off, use a heat gun or lighter or whatever to heat the spring. see which way it turns.
These damn things are the main reason I avoid fiddling with the divorced choke style whenever I can.
post #8 of 10 (permalink) Old Jul 3rd, 18, 9:27 AM
Mr Bill
Was the choke working properly before you had the carb redone ? If so the spring should not be the problem.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is online now
post #9 of 10 (permalink) Old Jul 3rd, 18, 3:13 PM Thread Starter
I don't think the choke was working correctly before the rebuild, but I didn't check it since there were other bigger issues with the carb which are now fixed with the rebuild. Anyway, I think I solved the problem. Apparently someone pigtailed the choke spring where the rod attaches in order to change the position of the rod or whatever reason. I straightened the spring with some pliers then tested its operation by putting it in the freezer then lightly hitting it with a torch. Also had to fabricate a slightly longer rod to accommodate a thicker carb gasket . Either way the choke appears to be working fine now. Thanks for all of your feeback.
Buzzbomb and LeoP like this.
neaswa is offline
post #10 of 10 (permalink) Old Jul 3rd, 18, 8:16 PM
Bart
Thank for posting an update to the problem.
billbonn80 likes this.
69SS Daytona yellow
L35, M-20, 3.73
surmin69 is offline
This Thread is more than 596 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
