Firing order/ spark plug wires - Chevelle Tech
 6Likes
post #1 of 19 (permalink) Old Mar 17th, 18, 11:08 AM Thread Starter
Dustin
2 part question.....
1) can anyone confirm if my firing order is correct? I know the numbers are correct by my #1 is right next to the battery hook up where 2 normally is. The reason I ask is because my distributor is st a weird angle (maybe off a tooth) and the car runs but is missing every once in a while.
2) the spark plug wires that were on the car when I bought it are very close to the headers and in a couple places melted. I'm trying to figure out if I should replace them with the exact same ones or if there is a better option.
Engine is a 396 out of a 67 Chevelle. I personally like the 90 degree plug ends but I am open to changing them if needed.
Thank you!
1955 Ford Thunderbird
1969 Triumph TR6
1972 Chevelle - 396, 4 Speed
1992 Acura Integra
2002 Yamaha R1
2004 Dodge Ram 1500
2012 Dodge Durango Citadel
Tegguy is offline
post #2 of 19 (permalink) Old Mar 17th, 18, 12:25 PM
Re: Firing order/ spark plug wires
On the last picture, is that a rubber coated metal band holding the wires together? If so get rid of it and use a plastic spacer and keep the wires from running together. Your could be getting inductance in the wires, creating a misfire condition.
Instructions...All I need is the exploded view.
Enganeer is offline
post #3 of 19 (permalink) Old Mar 17th, 18, 12:27 PM Thread Starter
Dustin
It's a standard rubber hose clamp just trying to keep the wires off the header. I have a nice spark plug wire holder that bolts to the valve cover but it's too long and contacts the steering column. I'll remove the clamp and find another option.
Sent from my SM-G935V using Tapatalk
1969 Triumph TR6
1992 Acura Integra
2002 Yamaha R1
2004 Dodge Ram 1500
Tegguy is offline
post #4 of 19 (permalink) Old Mar 17th, 18, 12:48 PM
You can make a wire loom with just plastic zip ties. Google "zip tie spark plug holder" and look at the images for ideas. You want as much of a gap between the wires as you can get, so they are not touching.
Firing order clockwise is 1-8-4-3-6-5-7-2. Trace the wires for each one to confirm.
Yes, your dist cap looks a little off from the normal placement but what really counts is the cap to rotor alignment.
Blown1932 likes this.
Enganeer is offline
post #5 of 19 (permalink) Old Mar 17th, 18, 1:06 PM Thread Starter
Dustin
Firing order is correct I'm just not sure were on the cap the #1 wire should fall is there an easy way to determine it other than finding tdc on the #1 piston? Maybe a better question is if all the wires were off and rotated 1 location would it even run?
1969 Triumph TR6
1992 Acura Integra
2002 Yamaha R1
2004 Dodge Ram 1500
Tegguy is offline
post #6 of 19 (permalink) Old Mar 17th, 18, 1:12 PM
You need the 45 degree ends for your plug wires because those headers are close. No one can look at an internet picture and go over your firing order with you.You'll just need to find # 1 and then finish 18436572.Your best bet is to get some wire dividers and put them on when you replace the wires.If you're not going to replace them right away you can temporarily "repair" the wire ends that melted with some Ultra Grey RTV.It's made of the same stuff the plug ends are made of and once it's dry it will insulate the plug from misfiring but you still would need to replace those wires eventually.
Also anything that's black,you know stuff like elec tape,radiator&vacumm hoses,that clamp you used, those kind of things makes a bad plug insulator as the black coloring is usually made of black carbon which is a great elec conductor.
Steve R likes this.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #7 of 19 (permalink) Old Mar 17th, 18, 1:38 PM Thread Starter
Dustin
Thanks for all the tips i wasnt looking for anyone to verify my firing order more so the #1 plug wire location because I'm not sure if I'm rotated by 1 location or not compared to diagrams. I'll just pull the plug and check the rotor location.
1969 Triumph TR6
1992 Acura Integra
2002 Yamaha R1
2004 Dodge Ram 1500
Tegguy is offline
post #8 of 19 (permalink) Old Mar 17th, 18, 1:46 PM
Usually # 1 is just to the left of the wiring square and the last one #2 ends up on the right side of the wiring square.
71 El Camino SS
71350SS is offline
post #9 of 19 (permalink) Old Mar 17th, 18, 1:49 PM Thread Starter
Dustin
Thanks that's how I have it setup but saw a diagram earlier with #2 to the left and #7 to the right. I'm going to get a new plug wire set and space them out and see if that makes it run better
1969 Triumph TR6
1992 Acura Integra
2002 Yamaha R1
2004 Dodge Ram 1500
Tegguy is offline
post #10 of 19 (permalink) Old Mar 17th, 18, 2:49 PM
Normally #1 and #2 is facing straight forward but it really doesn't matter which hole which wire is in as long as the vacuum advance doesn't hit on anything and the timing is correct.
It doesn't have anything to do with how the car runs.
If you want it o look like original, you can move the distributer a tooth or two but it's really fine the way it is.
post #11 of 19 (permalink) Old Mar 17th, 18, 4:00 PM
Marcus
Taylor has nice wires with 135 deg boots that fits good. I used both 76032 and 51063 can recomend both together with GM wire looms 12495502.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
post #12 of 19 (permalink) Old Mar 17th, 18, 4:05 PM
I use the woven socks on the end of the plug wires.
Slick87gn is offline
post #13 of 19 (permalink) Old Mar 18th, 18, 1:21 AM
To be sure where was #1 before you started replacing the plug wires,that's where it should be now.Moving the plug wire from one terminal to another means you'll have to reset the timing all over again.But if you put all the wires back where they came from you avoid all this muckity-muckity-muck. Best of Luck to you.
71 El Camino SS
71350SS is offline
post #14 of 19 (permalink) Old Mar 18th, 18, 1:34 AM
Al
I had clearance between my headers and boots and would still burn them out eventually. Got tired of that and went with ACCEL 45* ceramic boot wires, 3 years now and still going strong. https://smile.amazon.com/ACCEL-9002C...mic+boot+wires These work great with 454 Hooker Super Comp headers.
Still look brand new.
They are available in 90* boot also.
https://smile.amazon.com/ACCEL-9001C...KJCE88RV72EPKB
Start your car in the dark and watch your boots for arch or spark...quick tip.
Another tip...how to get the perfect looking spark wire routing...How-To: Cut and Loom Your Own Spark Plug Wires to the Perfect Length You don't need those fancy $ crimp pliers to do the job.
Here's the woven socks that work well too. $$$
DUTCH MAX HEADWORK is offline
post #15 of 19 (permalink) Old Mar 19th, 18, 6:42 AM Thread Starter
Dustin
Thank you everyone I did a temp fix on the boot with some RTV and made the zip tie spacer and it runs a lot better. Has back firing at higher RPM's that's either timing or the EFI needing to learn some more.
1969 Triumph TR6
1992 Acura Integra
2002 Yamaha R1
2004 Dodge Ram 1500
Tegguy is offline
This Thread is more than 676 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
