Electric Choke does not move choke plate? - Page 2 - Chevelle Tech
 8Likes
post #16 of 19 (permalink) Old Mar 7th, 18, 4:53 PM
Re: Electric Choke does not move choke plate?
Terrible (extremely incomplete) advice. It's almost like Holley doesn't know how a choke is supposed to work. Holley is allergic to mentioning the proper function of a choke pulloff, or why you'd want to adjust one. Their electric-choke add-on kits don't even mention a pulloff adjustment.
Adjusting Automatic Chokes: A Semi-Universal Approach
You're turning the choke cap, and the blade doesn't shut? DO YOU HAVE THE THROTTLE OPEN enough so the fast-idle cam clears the fast-idle screw?
Schurkey is offline
post #17 of 19 (permalink) Old Mar 7th, 18, 6:44 PM Thread Starter
I did have the throttle open. Maybe it wasn't open far enough? Don't know. But, it appears at this point to work. Plus, the cap spring was not on the bar that it should go on to.
HKalin likes this.
cyclerider is offline
post #18 of 19 (permalink) Old Mar 7th, 18, 6:58 PM
Allan
good for you, thats how i looked at it, i re attached the spring , set the cap in center position, and it worked,
thats what matters, it works. yeah
HKalin likes this.
Allan
66 SS396 325 HP M20
al1950 is offline
post #19 of 19 (permalink) Old Mar 7th, 18, 7:26 PM
Glad you figured it out..even in Ca I do miss having an electric choke. When set up right it feels too similar to EFI.
HKalin likes this.
cuisinartvette is offline
This Thread is more than 690 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
