Rear Main Leaking Again - Page 2 - Chevelle Tech
post #16 of 19 (permalink) Old Jan 11th, 18, 9:27 AM Thread Starter
blm
Re: Rear Main Leaking Again
Originally Posted by Chevycollecter View Post
Are you sure you are not installing the seal backwards. That will make it leak for sure.
I am positive that I installed the seal correctly and even used rtv in the areas that Philip showed in the picture that he submitted.When I go through the effort of removing the engine, then the oil pan, windage tray, oil pump and bearing cap, which is a big job by one guy in his garage, I made sure what the correct installation procedeure was before I ever started the job.
It has been maybe 4 or 5 years since i removed the seal installed during the engine rebuild and installed the new seal. Guess I could go back through my receipts and find out when I did this swap.
The car sees limited use, however it didnt leak originally after I changed the seal, so I thought I had the leak licked. It only reappeared after some use. That has me wondering what some other possibilities could be.
So to review I used a good quality seal. I believe it was a Fel Pro.I did not install it backwards, I used fresh rtv in all the spots required, I offset the seal into the halves and I covered the face of the seal with assembly lube after installation, torqued the bearing cap bolts/windage tray studs and oil pan bolts to correct torque upon reinstallation.
blm is offline
post #17 of 19 (permalink) Old Jan 11th, 18, 1:35 PM
TKG
Terry
You have two post going on in this forum, oil leak and a crooked flywheel. Is it possible that the flywheel is the cause of this problem?? Vibration???
TKG
64 Malibu Coupe
283, Fitech
2004r, 4w discs
TKG is offline
post #18 of 19 (permalink) Old Jan 11th, 18, 1:58 PM Thread Starter
blm
No the post about the flywheel is with a brand new flywheel. The engine has never been run with that flywheel on it. Until a few days ago my engine had it original 69 GM flywhell on it. As a matter of fact that is how I confirmed where the oil was coming from when I removed the original flywheel to install the new flywheel.
blm is offline
post #19 of 19 (permalink) Old Jan 11th, 18, 3:47 PM
TKG
Terry
OK back to clueless
TKG
64 Malibu Coupe
283, Fitech
2004r, 4w discs
TKG is offline
This Thread is more than 747 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
