Chevelle Tech - View Single Post - Headliner install write-up
post #60 of (permalink) Old Feb 29th, 08, 4:33 PM
Importtech
Jack
Re: Headliner install write-up
Excellent writeup Chris... I did upholstery work of all types for many years and do the chevelle top very similar to what you do. Only thing I wanted to add is I feel the best glue to use on headliners is Landau Top glue made by Weldwood. (I'm sure there are others... I feel it is the best strength glue you can use. I spray it on when I do the modern type headliners but it works well brushed on too. Also if you guys do your own you will probably get a few small wrinkles but don't sweat it too much as most will come out after a few days in the sun.
Importtech is offline
