Chevelle Tech - View Single Post - Mali2ude going together for Power Tour 08
post #14 of (permalink) Old Feb 28th, 08, 1:13 PM Thread Starter
camcojb
Re: Mali2ude going together for Power Tour 08
Originally Posted by 68SS2 View Post
On the frame mods, where was the center section cut and narrowed? Were the spring / shock mounts just moved inward the same amount? I have a boxed frame that I am probably going to narrow also.
if you look at the pics you can see where he cut and sectioned the area around the tire, moving it in a couple inches or so, then boxed all the areas in. He had to re-locate the body mount area to line up with the factory mount on the body. The body mount on the body is stock location (I think), he just moved it on the frame to match after sectioning.
Jody
camcojb is offline
