Re: Headliner install write-up
bubba,
if i could share one tip, instead of using your feet to push the bow into the clip take a visegrip and squeze the rod into the plastic clip. you won't push on your roof and new paint job and you won't believe how smooth it goes in. by the way your liner looks great ! i'm still fine tuning mine.
What i did was take a small piece of wood ..1x2 and measured it to length and made a simple lever -one easy push and it went right in ..
I also put a little heat in the car and closed all the windows ..and it was even easier to work with ..As stated great layout ...
