Wheel backspace for 69 Chevelle - Chevelle Tech
 2Likes
  • 2 Post By Dave427
post #1 of 6 (permalink) Old Jun 20th, 12, 3:51 PM Thread Starter
Cory
I have a 69 chevelle, ive got a mt 295/55/15 radial i want to use, Im wondering which width wheel and wheel backspace to use, and pics would help too, Thanks.
coryz28 is offline
post #2 of 6 (permalink) Old Jun 20th, 12, 5:06 PM
Dave 383 now
Re: Wheel backspace for 69 Chevelle
You can either use a 8 or a 10" rim.
If you use the 8" rim you need 4.5" backspacing, using a 10" rim you will need 5.5" backspacing.
The 10" rim will look the best.
Steve R and hydro462 like this.
Dave427 is offline
post #3 of 6 (permalink) Old Jun 20th, 12, 5:33 PM
Billy Glenn
I have a 295/50/15 on a 10" rim with 5" backspace that works for me. A 10" rim will look much better.
1969 Chevelle SS396
1971 Camaro Z28 (Under Construction)
1972 El Camino SS454 LS5
1999 Camaro Z28 LS1
1998 Silverado 1500
2006 Silverado 2500HD LBZ Duramax
Get In, Sit Down, Shut Up and Hold On!!! Oh Yeah...Don't Tell Your Mother.
bglennss396 is offline
post #4 of 6 (permalink) Old Jun 20th, 12, 6:53 PM
When first got the car it had 275/60-15 on 10" rims with 5" BS. Had slight rubbing on outside surface of tire (bulge). Since then have ran 8" rms with anywhere from 4.5" to 4" BS without issue. Unless the car sits higher than stock, 10" rim with 5.5" BS works best. Not much choice in wheels, but if you can find them, 9" wide rim with 5" BS would be spot on.
Status: Car-Less
GRN69CHV is offline
post #5 of 6 (permalink) Old Aug 1st, 19, 6:31 PM
I am thinking about buying some 18. X 9.5 and it has a 5.5 backspace how do y'all think good idea or not please let me know
post #6 of 6 (permalink) Old Aug 1st, 19, 8:59 PM
Greg.
Welcome to Team Chevelle
What year of Chevelle ?
If a 69 then you should be okay
However to be sure you should measure the Space in your car's Wheel Wells
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
