15x10 Convo Pro backspacing - Chevelle Tech
Sponsored by:Discount Tire
post #1 of 6 (permalink) Old Mar 30th, 03, 10:09 PM Thread Starter
Post
I know this is a redundant topic, but my research has given me mixed results on my ONE question: Will the 15x10 wheels fit with 5" backspacing on my 70 Chevelle? Or should I try to fit with 6" bs? I have already rolled the outer lip. Thanks.
1970 Chevelle 2dr, 400hp 383ci, 200-4r trans., locking 10bolt. "The importance of material things is invaluable if you loose the things essential to the spirit of life."
green70 is offline
post #2 of 6 (permalink) Old Mar 31st, 03, 12:25 AM
Daniel
Post
I have a 70 also and everything i have heard is that 5.5 is the magic number for backspace on a 10 in wheel.
Daniel
1970 Chevelle - Best time at the WCCG 12.749 @ 108.606, 2.011 60' on street tires!
427 BBC, 215 heads, 2.19/1.88 valves with some port work, 60212 Lunati Hyd Roller, 3310 Holley 750, Performer RPM intake, TH350 with shift kit, 3.55 gears 12 bolt posi, Pypes 3 inch kit, it's alive... again!!!
Stikman33 is offline
post #3 of 6 (permalink) Old Mar 31st, 03, 12:37 AM
Adam
Send a message via AIM to AdamLym
Post
5.5!
5 is too little, the tire will rub the fender lip
6 is too much, the wheel will contact your shock mount.
I run 10 inch wheels with 5.5" of backspacing on my '71 with 295/50-15 tires - no problems, but 5.5" of backspacing is crucial unless you want to do some sheetmetal, or other mods.
Adam Layman
1971 Chevelle
EFI Systems Manager
www.holley.com
AdamLym is offline
post #4 of 6 (permalink) Old Mar 31st, 03, 7:04 PM Thread Starter
Post
thanks for the info, Im just trying to make sure becuase I really like the way the convo pros look- any wheels similar to that?
green70 is offline
post #5 of 6 (permalink) Old May 7th, 03, 9:59 AM
Post
On my 70 SS, I have 15x10" rear rallys with 5 3/4" back spacing and 275-60x15 tires w/o any problems.
geeman574 is offline
post #6 of 6 (permalink) Old May 7th, 03, 9:01 PM
Clint
Post
I guess the $64K question now is can the Convos be bought with 5.5" backspacing? If not,I would find another wheel.
Clint44 is offline
This Thread is more than 5800 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
