Rim size for slicks - Chevelle Tech
 6Likes
post #1 of 19 (permalink) Old Jul 3rd, 20, 10:17 PM Thread Starter
mark
Rim size for slicks
Picked up a sets of MT 30x9x15 slicks.. Thinking of trying them on my 70 buy not sure of what back spacing or size rim to use. Not tubbed but outer wheel well looks like it was cut and folded in about an inch.. thanks. Mark
70 SS LS6
LIC #73
TC #3594
wannarun70 is offline
post #2 of 19 (permalink) Old Jul 4th, 20, 5:37 PM
Greg.
Re: Rim size for slicks
How much Wheel Well Space do you have ?
Has the car been Lowered ??
How wide is the Rearend that is in the car ???
What Size/Details of the #s of the Tire eg. Diameter / Side Wall Width / Part # ????
Every car is different from Driver side to Passsenger side and taking measurements of your car's Wheel Wells
is the key to what Wheel / Tire Combo size will fit without rubbing or hitting anything ;
If you want to do it right and only need to buy the Wheels / Tire Combo once that will fit get out your Measuring Tape
and I can supply you how to do the Measurements
With the Wheels/Tires removed from Both DR & Pass sides, one side at a time or all same time measure the following;
1. Rear End Width – Face of Brake Drum/Disc Driverside to Face of Drum/Disc Passengerside = ??“
2.OUT SPACE from inside Lip of outside Fender to Face of Rear Drum/Disc Brake Hub/Wheel Mounting Pad
.... DR Side = ??“ .... PASS Side = ??”
3.IN SPACE from Face of Rear Drum Brake Hub/Wheel Mounting Pad to Frame/Inner Fender
4.Total Wheel Well Space = # 2 + # 3 measurements #s DR Side = ??“ ....PASS Side = ??”
if one side is less then use it as the applicable number or make sure the Rearend is centered properly
Important things to NOTE;
1. the Rear Lower Shock Mount Bolt may interfere with the Wheel’s Rim
2. and yes your car's exhaust may interfer with the Tire on a 10" Wide Wheel
3. Type of Brake system on Rearend, Drum or Disc ! as the Disc setup is usually wider than a Drum setup
4. Is Rearend centred ?
5. Has the car been Lowered ?
6. Side Wall/Section Width of the Tire = ?
7. Diameter Height of Tire = ?
8. Size of Wheel you wish run ?
Measure twice and Supply the above info and then I can calculate for you !
Cam likes this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #3 of 19 (permalink) Old Jul 4th, 20, 5:53 PM
Greg.
Is this the Tire you are talking about ?
https://www.jegs.com/i/Mickey-Thomps...3060R/10002/-1
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #4 of 19 (permalink) Old Jul 4th, 20, 7:23 PM Thread Starter
mark
No. Its a MT ET drag
70 SS LS6
LIC #73
TC #3594
post #5 of 19 (permalink) Old Jul 4th, 20, 8:33 PM
Greg.
JEGs does not list a ET Drag Slick with those #s 30x9x15 that I can see
Do you know the Mfg. # ?
Type of Compound ??
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #6 of 19 (permalink) Old Jul 4th, 20, 9:31 PM Thread Starter
mark
No mfg# looks like a mfg date of 11407. Maybe not made anymore. Don't know compound.
70 SS LS6
LIC #73
TC #3594
post #7 of 19 (permalink) Old Jul 4th, 20, 9:41 PM
Vince
i have run 30-9/15'' slicks on corvette ralley wheels 8x15 w/4.25 bs on my 68..
lots of room...
VinceS427bb is offline
post #8 of 19 (permalink) Old Jul 4th, 20, 9:50 PM Thread Starter
mark
Sounds good Vince. Gonna use the measuring tips that Greg gave me and see what happens..
Kirk's67SS likes this.
70 SS LS6
LIC #73
TC #3594
post #9 of 19 (permalink) Old Jul 5th, 20, 12:50 AM
Greg.
The thing is dependant on the Mfgr. the Tires Side Wall Width can vary
a M/T # 3056 = 29.5"x 9" x 15" Bias-ply Tire needs a Tube + Screws and is only 11.4" Side Wall Width on a 8" Wide Wheel
While a Hoosier # 18200D05 = 30"x 9" x 15" Bias-Ply Tire needs a Tube + Screws and is 11.8" Side Wall Width on a 8" Wide Wheel
a M/T # 3060R = 30"x 9" x 15" is a Radial Tire and is 12.5" Side Wall Width on a ??" Wide Wheel
Mark, how old is the Tire ? , I would worry about the Date that Slick was Made
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #10 of 19 (permalink) Old Jul 5th, 20, 10:31 AM Thread Starter
mark
11407 looks like the date.
70 SS LS6
LIC #73
TC #3594
post #11 of 19 (permalink) Old Jul 5th, 20, 1:10 PM
Greg.
Are those the #s beside the DOT ?
I can not find any meaning for/of a 5 Digit Date Code
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #12 of 19 (permalink) Old Jul 5th, 20, 1:53 PM Thread Starter
mark
Does not say DOT anywhere on the tire.
70 SS LS6
LIC #73
TC #3594
post #13 of 19 (permalink) Old Jul 5th, 20, 7:29 PM
Greg.
Yeh that is for Street Ties likely
You need to know how old those slicks are before you spend any $$ on them so you can mount them to the car
11407 could be for something else or if for Date then
11 year Mfg / 40 week / 7 ??
07 year Mfg / 40 week / 11 ??
I would be worried of putting them on a car that will be going down the Track at a High Speed
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #14 of 19 (permalink) Old Jul 5th, 20, 8:29 PM Thread Starter
mark
It has FUHL in a box like the date is on regular tires like the 11407 is. Made in England and a MOULD NO 02625M. Don't know what any of that means... I'll post a photo tomorrow.. Thanks.
70 SS LS6
LIC #73
TC #3594
post #15 of 19 (permalink) Old Jul 12th, 20, 11:09 AM Thread Starter
mark
sorry for the delay Greg.
70 SS LS6
LIC #73
TC #3594
