65 Chevelle torque thrust wheel size help - Chevelle Tech
 3Likes
  • 1 Post By Steve R
  • 1 Post By 64SS427
  • 1 Post By Kirk's67SS
post #1 of 10 (permalink) Old Jun 27th, 20, 1:27 AM Thread Starter
Pat
Does anybody know if you can fit 15" torque thrust wheels on a 65 Chevelle f&r and if so what size tires would fit without rubbing. Also, the suspension is all stock. Thanks
55pat is offline
post #2 of 10 (permalink) Old Jul 1st, 20, 8:40 PM
Greg.
Re: 65 Chevelle torque thrust wheel size help
Is the car Lowered ?
To only buy the Wheel/Tire Combo once that will fit within your Car's Wheel Wells you will need to do/take some Measurements
Every car is different from Driver side to Passsenger side and taking measurements of your car's Wheel Fender Wells etc
is the key to what Wheel / Tire Combo size will fit without rubbing or hitting anything ;
BACK SPACING & WHEEL WELL / Shock Mount Room https://www.rsracing.com/tech-wheel.html
First with the Wheels/Tires removed from Both DR & Pass sides, one side at a time or all same time measure the following;
1. Rear End Width – Face of Brake Drum/Disc / Wheel Mount Pad Driverside to Face of Drum/Disc / Wheel Passengerside = ??“
2.OUT SPACE from inside Lip of outside Fender to Face of Rear Drum/Disc Brake Hub/Wheel Mounting Pad
.... DR Side = ??“ .... PASS Side = ??”
3.IN SPACE from Face of Rear Drum Brake Hub/Wheel Mounting Pad to Frame/Inner Fender
4.Total Wheel Well Space = # 2 + # 3 measurements #s DR Side = ??“ ....PASS Side = ??”
if one side is less then use it as the applicable number or make sure the Rearend is centered properly
Important things to NOTE;
1. the Rear Lower Shock Mount Bolt may interfere with the Wheel’s Rim
2. and yes your car's exhaust may interfere with the Tire on a 10" Wide Wheel
3. Type of Brake system on rearend, Drum or Disc ! as the Disc setup is usually wider than a Drum setup
4. Is Rearend centred ?
5. Has the car been Lowered ?
6. Side Wall/Section Width of the Tire = ?
7. Diameter Height of Tire = ?
8. Size of Wheel you wish to run ?
Measure twice and you will only need to buy once the Wheels/Tires
you need to fit within your car’s Wheel Wells .
Supply the above info and then I can calculate for you !
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #3 of 10 (permalink) Old Jul 1st, 20, 10:41 PM
Devin
Depends on what you want. I put Americans under my car a few years ago. 15x4.5 front, 15x6 rear. 165R15 tires front, 215/75R15 rear tires. Fits nice, no rubbing looks good to me.
Early cars are difficult to put a large tire under, I got tired of fighting it. Drives do wn the road just fine this way.
Devin
Just an El Camino
Son's build:
My never-ending project:
64SS427 is offline
post #4 of 10 (permalink) Old Jul 2nd, 20, 2:09 AM
Marcus
15x6 with 185/15 Front 15x8 With 275/60-15 rear on my 64. With 275’s you need perfectly centered rims.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #5 of 10 (permalink) Old Jul 2nd, 20, 2:49 AM
The problem with torque thrusts is they are a cast wheel, not all of their offerings are optimal, especially for a car like the 65 Chevelle that has small rear wheel wells. You will most likely be limited to a 15 x 7 in the rear. If someone says a larger size torque thrust fits, look at the pictures they provide and pay attention to the ride height.
Steve R
Kirk's67SS likes this.
Steve R is offline
post #6 of 10 (permalink) Old Jul 4th, 20, 8:48 PM
Greg.
Early cars are difficult to put a large tire under, I got tired of fighting it. Drives do wn the road just fine this way. Devin
And the Back Spaces were ??
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #7 of 10 (permalink) Old Jul 4th, 20, 8:50 PM
Greg.
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #8 of 10 (permalink) Old Jul 4th, 20, 11:32 PM
Devin
Good question. I'd have to pull them and measure. However, with wheels this skinny, unless the offset it crazy, it's not going to cause a problem.
Devin
71350SS likes this.
Just an El Camino
Son's build:
64SS427 is offline
post #9 of 10 (permalink) Old Jul 5th, 20, 12:55 AM
Marcus
My backspace wont help the thread starter since my rear is narrowed, I wanted to be able to run wheels with more backspace since I like the look better.
However I havnt change anything else so I know 275’s will fit on 8” wide rims in oem rear wheel houses if perfect centered.
But belive 5-5.25” backspace is what most run on 64-65 with oem widht rears and 8” rims of they want to fit the widest possible tires.
post #10 of 10 (permalink) Old Jul 5th, 20, 12:58 PM
Greg.
Marcus I forgot you have the Narrowed Rearend
if the 64 to 65s have a 60" Wide Rearend then a 8" Wide Wheel with a 4.5" BackSpace is about it for Drum Brakes
and if Disc Brakes then a 4.75" to 5.00" BackSpace for a 8" Wide Wheel is about it also
And they have to watch out for the Bottom of the Rear Shock Mount Bolt on a 14" or 15" Diameter Wheel
Malibu ss 64 likes this.
Born 283 / PG / A51
60' = 1.664
60' = 1.547
