Weld Draglites lug nuts ?? - Chevelle Tech
 9Likes
  • 1 Post By HKalin
  • 2 Post By shovelrick
  • 1 Post By shovelrick
  • 1 Post By Jim Mac
  • 2 Post By HKalin
post #1 of 11 (permalink) Old Feb 25th, 20, 1:20 PM Thread Starter
rick
I cant search from my phone but I got a nice set of 15" wheels with MT 295/55/15 drag radials but my 1/2" studs are either too short or do I need special lug nuts? and a big Thank You to Tom TC member 72moneypit 👍😀
shovelrick is offline
post #2 of 11 (permalink) Old Feb 25th, 20, 2:10 PM
Greg.
Re: Weld Draglites lug nuts ??
https://www.jegs.com/p/Weld-Racing/W...46346/10002/-1
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #3 of 11 (permalink) Old Feb 25th, 20, 2:36 PM
Hank
The lugs do use washers and because of the thickness of the wheel center you either have to go with a longer lug or replace the studs with longer ones. The lug should engage the studs by no less than the stud diameter. I had a set of Weld Draglites and later a set of Rodlites and I put longer studs in the rear axles on my Camaro
indymanjoel likes this.
HKalin is offline
post #4 of 11 (permalink) Old Feb 25th, 20, 4:43 PM Thread Starter
rick
Thanks for the link Kirk and Hank thanks for your heads up on what you did, Im going to order lug nuts with a 1.30-1.38 shank, hope I can get them for 1/2" studs but really dont see why not
HKalin and Kirk's67SS like this.
post #5 of 11 (permalink) Old Feb 26th, 20, 8:13 AM Thread Starter
rick
Here's a few pics, 295/55r15" MT DR next to 255/50r17" radial, had about 1/2" between tire & 3" exhaust at the closest spot
ID:	617712   Click image for larger version
ID:	617714   Click image for larger version
ID:	617716   Click image for larger version
Kirk's67SS likes this.
post #6 of 11 (permalink) Old Feb 26th, 20, 6:48 PM Thread Starter
rick
Ordered Weld 601-1416 lug nuts
post #7 of 11 (permalink) Old Feb 26th, 20, 8:12 PM
if you cut a lug nut lengthwise, you'll see how small amount of metal there is where shoulder meets the shank. That's why I swapped to 3 inch studs on my 70. jim
shovelrick likes this.
Jim Mac is offline
post #8 of 11 (permalink) Old Feb 26th, 20, 8:18 PM Thread Starter
rick
I spoke with a guy at Summit and he said open or closed ends? I said closed and he said these are the ones I need...? never had Welds
post #9 of 11 (permalink) Old Feb 26th, 20, 9:38 PM
Hank
The ones you ordered should be fine because your studs sit inside the wheel hub. If you had long studs the stud might bottom out on the end of the stud threads. Another thing you will notice about the Weld Wheels the center section will squeeze down a bit because it seems like the inner core of the center section looks almost like a spacer.
Kirk's67SS and shovelrick like this.
HKalin is offline
post #10 of 11 (permalink) Old Feb 26th, 20, 9:57 PM Thread Starter
rick
The guy said the 1.38 shank was what I needed so should be good to go, I'll post when I gettem
post #11 of 11 (permalink) Old Feb 28th, 20, 12:54 AM
I just ordered a new set of McGard lug nuts for my Weld Pro Stars. They are made in the USA. Beware of the Chinese knock off lug nuts. I stripped out a few lugs last time I went to the track when I was swapping the drag radials. The part numbers for the front lugs 7/16'-20 closed end are 63015. The rear lugs 1/2"-20 open end are 63004. Good Luck
1967 Chevelle 496BB/TH400/Strange S-60 (Show and Go)
1967 El Camino 388SB/700R4/12-bolt posi (Rat Muscle Parts Hauler)
2015 Harley Davidson Road Glide Special (Cruiser)
2007 Harley Davidson Road King Custom (Bar Hopper)
2018 Chevy Silverado LTZ Duramax (Daily Driver)
My Chevelle:
C & D Performance
North Texas Chevelles
Motorhead62 is offline
