ET streets on the street? - Chevelle Tech
 15Likes
  • 1 Post By VinceS427bb
  • 2 Post By Kirk's67SS
  • 1 Post By oldcutlass
  • 1 Post By Autoengineer_
  • 1 Post By Kirk's67SS
  • 1 Post By ak 67SD
  • 1 Post By cuisinartvette
  • 6 Post By mr 4 speed
  • 1 Post By Jasons 69 Chevelle
post #1 of 11 (permalink) Old Feb 20th, 20, 8:53 PM Thread Starter
I'm currently running Mickey Thompson 295/50R15's Sportsman S/T Radial's on 5.5" backspacing. The traction is pretty much non-existant. My first gear is useless at anything beyond half throttle. I think the rubber on these tires may have hardened over time. They are about 7 years old. Maybe too many burnouts glazed them in a way?
I'm really thinking about trying something like this...
https://www.jegs.com/i/Mickey-Thomps.../3454/10002/-1
Its a little higher, but I think I'll be OK as long as I dont put too much weight in the back seat.
Anyone running these on the street? My car is not a daily driver in the summer, but I am running to family functions and day trips so they would see some expressway time.
'72, 385 sbc, Voodoo roller, 219/227; .515/,530 lift; AFR 180cc Eliminators, RPM Air-Gap, 770 Avenger, TH350 trans, 12 bolt 3.42's, Eaton Posi, TCI 2000 stall, Pypes 2 1/2" X-pipe system w/Race Pro's
Vehicle weight: 3390 lbs
Autoengineer_ is offline
post #2 of 11 (permalink) Old Feb 20th, 20, 11:50 PM
Vince
Re: ET streets on the street?
that is the latest tires on rear of my 68.
they are shoehorned in the wheel wells; 72 cars have bigger area to fill..
they act/feel like a good radial tire on the road/highway.
my ride is running 2'' lowering springs in rear for reference.
shovelrick likes this.
VinceS427bb is offline
post #3 of 11 (permalink) Old Feb 21st, 20, 11:42 AM
I ran the older version on my car pretty much all year last year. Definitely more traction than the 295 ST's that I normally wear. When I had 3.31s, there was a noticeable reduction in RPM's at the end of the 1/4, I barely would get into 4th gear. Obviously will change your speedometer too.
Never drove in the rain, so I can't comment on wet weather traction but I am sure it's pretty bad.
Youtube Channel.
Instagram:
Twitter:
-SS454- is online now
post #4 of 11 (permalink) Old Feb 21st, 20, 12:39 PM
Greg.
Yes 7 years for a Tire is pass their Safe to run Date
I have the 295/55/15 M/Ts #3454s as my Track Tires on 15"x 10" with a 5.5" BS and are great for Launching the Car at the Track
Drove another pair of them on the Dry Street with no problems
do not know how they would be in the Rain
The only problem with them is they do not last long as they wear out quickly driving them on the Street
I ran this Tire on the Street for 7 years, after they were too old/getting Spider Cracks on the sidewalls
but they gave me 1/2 decent Traction on the Street and even got a new Best at the Track with them one late Fall Day
M/T S/R # 6641 https://www.jegs.com/i/Mickey-Thomps.../6641/10002/-1
on a 15"x 8" Wheel with a 4.25" BS
I will be buying a new pair of them for the Street this Spring
and they will go on a 15"x 10" Wheel with a 5.5" BS
Clint44 and jeffs68 like this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #5 of 11 (permalink) Old Feb 21st, 20, 1:19 PM
I'm not a fan of drag radials on the street. Very expensive, suck in the rain, and they don't last long.
dell72 likes this.
oldcutlass is offline
post #6 of 11 (permalink) Old Feb 21st, 20, 9:28 PM Thread Starter
Those S/R radials might be a good in-between option. Thanks. I need to check to see if the slightly larger diameter would be a problem.
Kirk's67SS likes this.
post #7 of 11 (permalink) Old Feb 22nd, 20, 10:52 AM
Greg.
They are only 28" Tall and should be okay unless your 72 is lowered to much
A 8" Wide Wheel with a 4.5" BS also works in my 67
with the smaller Wheel Well Space as my car in the Back is at Stock Height
Pics of the S/Rs on a 15"x 8" Wheel with a 4.25" BS
Pics of the Track 295/55/15 # 3454 Tires on a 15"x 10" Wheel with a 5.5" BS
-SS454- likes this.
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #8 of 11 (permalink) Old Feb 29th, 20, 10:59 AM
I've run the ET street bias plys on the street. I'm sure the radials will have better manners. The ETs I used were noticeably soft and felt like jello in the back... but at the same time it was fun to have traction and a good tradeoff for a Sunday cruiser! I did get caught in the rain, but it was slippery, you'd have to feather the throttle and limp it home.
ak
VinceS427bb likes this.
ak 67SD is offline
post #9 of 11 (permalink) Old Mar 17th, 20, 11:37 AM
youll love them... I run their (equiv) 275/50/15 full time doesnt feel mushy at all?
Driven in the rain too..they are fine just take it easy on the throttle....if its heavy rain may wanna cancel plans they can hydro plane
M and H makes one with deeper tread.
7 is pretty old
cuisinartvette is offline
post #10 of 11 (permalink) Old Mar 17th, 20, 11:44 AM
Try driving around in an 11 second street car on Polyglas tires!!
mr 4 speed is offline
post #11 of 11 (permalink) Old Mar 21st, 20, 8:46 AM
Jason
That’s the tire I use. I love them, but they will last around 5000 miles
I don’t drive much so it’s not a issue. Car don’t go outside unless there is no rain chance. They would suck in rain if image.
Jasons 69 Chevelle is offline
