Tire fitment - Chevelle Tech
post #1 of 4 (permalink) Old Today, 12:38 PM Thread Starter
Tire fitment
Hi I have 72 chevelle stock ride height. I'm keeping 14 inch rally wheels on car. How big can I go with 14 inch bfg without rubbing on stock rim's? Thanks
Mark Sheldon is offline
post #2 of 4 (permalink) Old Today, 2:51 PM
Re: Tire fitment
Honestly, you probably can't find a non drag slick that is too big either in height or width.
225/70 is a common "normal" size with some width to it. And there are wider options, but most are also shorter overall.
Pioneer4x4 is offline
post #3 of 4 (permalink) Old Today, 3:48 PM
Greg.
Re: Tire fitment
The Width of the Wheel and it's BackSpace and the Space in the Car's Wheel Wells
is what determines how Wide/Tall of a Tire will fit within a Car's Wheel Wells !
Measure everything and let us know the Data so we can Cal and advise
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #4 of 4 (permalink) Old Today, 3:54 PM
Greg.
Re: Tire fitment
Measuring your car's Wheel/Fender Wells on both sides will provide us with the #s
that will enable us to cal the Max sized Tire and the proper Wheel BackSpace
Take the following measurements with the Wheels/Tires off the car;
1. TOTAL SPACE of Wheel/Fenderwells, from Frame/Fender on the INside
TO the OUTside Inner Lip of the Outside Fender = ?
..... DR side = ?? and Passenger side = ?? as they can be different
2. The OUTSpace for/from the Outside Fender Inner Lip
TO the Face of Rear Brake Drum/Hub = ?
3. The INSpace from the Face of Rear Brake Drum/Hub to the Inner Fender / Frame = ?
NOTE there can be interference from the Lower Shock Mount Bolt if the Wheel is to Wide
and the Exhaust Piping may also rub on the Sidewall of a Tire that is to Wide
plus Ride Height plays into how Wide a Tire will be allowed to be used
Born 283 / PG / A51
60' = 1.664
60' = 1.547
