Wheel Wobble (Video) - Page 3 - Chevelle Tech
 15Likes
post #31 of 44 (permalink) Old Feb 14th, 20, 9:22 PM
Randy
Re: Wheel Wobble (Video)
I bought a used 69 Camaro many years ago, and some rube had shortened the driveshaft and welded the yokes about 45 degrees out from each other. Yeah, it vibrated.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #32 of 44 (permalink) Old Feb 14th, 20, 10:07 PM Thread Starter
I have a couple more videos and some run-out measurements I'll post tomorrow. I noticed that there isn't much wobble on the axle flange, but it is there with the brake drum.
I measured the back rim of the drum and the low spot was .065 back from 0 and the high spot .010. That's a change of .075 which is basically an inch.
I bought these from either Of Reilly's or AutoZone about 10 years ago. I don't see any balancing weight on the drums.
Could this be the cause of my problems?
Mike Smith
72 Chevelle, LS 6.0 LQ9 4l80e
smitty454 is offline
post #33 of 44 (permalink) Old Feb 14th, 20, 11:01 PM
Another question to you. You said it happened before you did the drive shaft, do you remember exactly when it started, and what kind of work was done at that time? A lot of times a symptom occurs right after some kind of repair or modification. Two other areas to think of since you said theres no vibes in the steering wheel, but through the floor and body. I would consider the shock bushings or maybe pinion bearing may be out of tolerance (any chance this arose after your track pass? The other thing would be to make sure the wheel bearing preload was not excessive.
Stevieb54 is offline
post #34 of 44 (permalink) Old Feb 14th, 20, 11:08 PM
David
Did you check your rear control arm bushings?
Uppers and lowers - 8 bushings total.
Stevieb54 likes this.
66 Malibu......back to life with a 427 BB & 4 speed
RAIDER SS is offline
post #35 of 44 (permalink) Old Feb 15th, 20, 12:48 PM Thread Starter
Yeah they are all newer UMI stuff.
Mike Smith
post #36 of 44 (permalink) Old Feb 15th, 20, 6:38 PM
The drum is close to the axle's center line so for it to be the cause of the out of balance the weight would have to be really heavy. Whereas a tire is further from the axle's center line so any out of balance with a tire is much more noticeable.
In other words the tire brings a much longer lever to the game than the drum does. The drum could still be a balance problem even though it's doubtful.Try swapping the drums from left to right.If you were closer to NY I'd lend you an extra set of rear drums I have.
You could put any wheels/tires on there that have a 4 3/4 bolt circle so maybe borrow a set of tires and take a test drive.
You could also have a tire shop with a road force tire balancer check the tires for an out of round condition too.A road force balancer will hylight the tires high/heavy spot and the rims heavy spot and then the shop can reposition the tire on the rim so it has the best balnce possible.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #37 of 44 (permalink) Old Feb 15th, 20, 7:27 PM Thread Starter
Makes sense on the drums. I think its unlikely as well, but its a possiblity. Ive read on here that other people have had problems with unbalanced drums. I ordered some new AC Delco balanced drums from Rock Auto anyway. We'll see what happens.
I bought the wheels and tires in November and had them mounted with the road force balancer at Discount Tire.
Mike Smith
post #38 of 44 (permalink) Old Feb 15th, 20, 7:30 PM Thread Starter
The problem is I built this car and didnt drive it hardly at all for years. Now Im finally really getting it on the road and doing some serious driving and all the bugs are starting to appear. I definitely learned my lesson on that.
The car vibrated all the way to the track, so it wasnt the race. It vibrated before the new wheels and tires so I dont think its that either.
Ill check on the shock bushings, pinion bearing is suspect. What does a pinion bearing vibration feel like?
Mike Smith
post #39 of 44 (permalink) Old Feb 15th, 20, 7:32 PM Thread Starter
Heres some vids:
Mike Smith
post #40 of 44 (permalink) Old Feb 16th, 20, 1:31 AM
November 2019 ? Take the car or the tires back and explain to them about your problem.I think they will be more than happy to recheck their work,and recheck the balance of the tires.The usual warrantee is 6 months or 6000miles.You're under both.
If a FNG had done the work on your tires theres a good chance that it wasn't done right.
As for that axle run-out video you really need a dial indicator at a turned by hand slow speed to measure that run-out.
71 El Camino SS
71350SS is offline
post #41 of 44 (permalink) Old Feb 16th, 20, 8:16 AM
Uhhhmmmm......I'm afraid to ask what a "FNG" is
BillyGman is offline
post #42 of 44 (permalink) Old Feb 16th, 20, 12:05 PM Thread Starter
Ok ill do that.
I did check the runout on the axle flange and it appears to be in spec with only maybe a couple thousands of runout measuring from the top of the flange and not the face of it. I couldnt get a good measurement of the face of the flange with the studs being in the way.
What is the allowed runout of the axles themselves? I got .025 runout pushing the axles in and pulling them out.
Mike Smith
post #43 of 44 (permalink) Old Feb 16th, 20, 12:40 PM
had that issue with some pacer rallyes and M/T runout was horrible on both. Fortunately summit took care of it
Well the tires anyway....pacer wheels werent even round!
Lots of tire shops will slap a bunch of weights on and say its in spec or balanced but if its out side/side its still going to give you that weird harmonic
Welds were better but still out quite a bit. Keep us posted
cuisinartvette is offline
post #44 of 44 (permalink) Old Feb 16th, 20, 2:32 PM
Ok ill do that.
I'm not sure of those kind of specs off the top of my head but it's not uncommon to see 1/32 by eye at the axle flange. As far as the in and out axle spec if that is too much I think there are different sizes of "C" clips available to take up that play.I'm sure the specs must be listed somewhere ? Though I doubt .025 is past the allowable spec.
BUT if any movement at the axle is up and down then the axle bearing is worn out and needs that side bearing replaced maybe with axle replacement too and you won't know about the axle till you take it apart and see.
71 El Camino SS
71350SS is offline
