Chevelle with Blade type wheels - Chevelle Tech
 6Likes
  • 1 Post By Kirk's67SS
  • 2 Post By NW68SSBBC
  • 1 Post By NW68SSBBC
post #1 of 15 (permalink) Old Nov 3rd, 19, 10:51 AM Thread Starter
Hello to everyone,
I'm looking to get some new rims/tires for my 68. I have 15" rally wheels on it now. Rears 275/60/15. Looking to go 295/55/15. I'd like to run a 10" rim but if that won't fit an 8 will have to work. I have plenty of room with the current tires but I'm not sure about which backspace I need, 4.5" with an 8" rim and 5.5" with a 10" ??
I'm also looking at "Blade" style rims but can't find any pictures of a Chevelle running them. Anyone have any pictures of a Chevelle with blade rims???
Thanks Joe
"... the very powerful and the very stupid have one thing in common. They don't alter their view to fit the facts, they alter the facts to fit their view." Dr. Who, 1977
NW68SSBBC is offline
post #2 of 15 (permalink) Old Nov 3rd, 19, 11:50 AM
Vince
re: Chevelle with Blade type wheels
have you thought about just getting some 15x10'' ralley wheels for the larger tires??
https://www.wheelvintiques.com/wheel...te-rallye.html
they have either a 5.0'' or 5.5'' backspace...
i'm running that same tire on a 15x8'' wheel; the backspace needs to be 5.0 to 5.25 with a 8'' wheel
with a 15x10 wheel the backspace could be 5.5''
my fender lip is rolled and the inner fender well is smoothed and rolled in; + the surface of the frame next to the tire is smoothed of bumps, weld spatter, sharp edges, to protect tire side wall from damage if it contacts it
VinceS427bb is offline
post #3 of 15 (permalink) Old Nov 3rd, 19, 12:39 PM Thread Starter
I didn't think about bigger rallyr wheels until now. Definitely a lower cost option
Thanks Joe
post #4 of 15 (permalink) Old Nov 4th, 19, 10:01 PM
Greg.
Re: Chevelle with Blade type wheels
Joe I have the same type of Steering Wheel in my Car
I have found these to be a very good Quality / priced Wheels
and have been running them on the Street & at the Track for years
https://www.jegs.com/p/JEGS/JEGS-Spo...31935/10002/-1 1 piece Alum & use ET Style Lug Nuts
Fronts = https://www.jegs.com/i/JEGS/555/66062/10002/-1 15 x 7 with a 4" BackSpace Price = $ 95.us
Rears = https://www.jegs.com/i/JEGS/555/66086/10002/-1 15 x 10 with a 5.5" BS for my 67 Price = $ 123.us
since you have a 68 Chevelle and it has a Stock Width Rearend of 61" Wide the a 15 x 10 Wheel with a 5.75 to 6" BS would be better
The Size of Tires on them are
FRONT = 205 / 70R / 15 Cooper
REAR = 295 / 55R / 15 M/T
They also come with Black Centers
https://www.jegs.com/i/JEGS/555/66162/10002/-1 $ 106.us
https://www.jegs.com/i/JEGS/555/66185/10002/-1 $ 104.us
71350SS likes this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #5 of 15 (permalink) Old Nov 4th, 19, 11:01 PM Thread Starter
Your car looks great! Where do you measure from face of the axle to axle or backing plate. I don't have a stock 12 bolt. Its a QP 9 but it supposed to be stock width
Here is how it sits with the 275/60/15
Thanks Joe
oldcutlass and dell72 like this.
post #6 of 15 (permalink) Old Nov 5th, 19, 5:49 PM
Greg.
If you want to see if you have room for a 295/55/15 Tire and 15 x 10 Wheel with what BackSpace needed
Measure as follows ;
1. for the Width of the Rearend Measure from the Wheel/Tire Mounting Face Pad of the Rear Drum/Disc Brake on DR side to Pass side
2.OUT SPACE from inside Lip of outside Fender to Face of Rear Drum/Disc Brake Hub/Wheel Mounting Pad
DR Side = “ PASS Side = ”
3.IN SPACE from Face of Rear Drum Brake Hub/Wheel Mounting Pad to Frame/Inner Fender
4.Total Wheel Well Space = # 2 + # 3 measurements #s
if one side is less then use it as the applicable number or make sure the Rearend is centered properly
Important things to NOTE;
A. the Rear Lower Shock Mount Bolt may interfere with the Wheel’s Rim
B. and yes your car's exhaust may interfer with the Tire on a 10" Wide Wheel
C. Type of Brake system on rearend, Drum or Disc ! as the Disc setup is usually wider than a Drum setup
D. Is Rearend centred ?
E. Has the car been Lowered ?
F. Side Wall/Section Width of the Tire = ?
G. Diameter Height of Tire = ?
H. Size of Wheel you wish run ?
Measure twice and you will only need to buy once the Wheels/Tires
you need to fit within your car’s Fenderwells .
Supply the above info and then I can calculate for you !
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #7 of 15 (permalink) Old Nov 5th, 19, 7:38 PM
I like the look of that 68 now. Is that a dark green color? anymore pictures.
dell72 is offline
post #8 of 15 (permalink) Old Nov 5th, 19, 8:54 PM Thread Starter
That sounds like a good plan. I'll get the measurements this weekend
I appreciate the help !
Thanks Joe
Kirk's67SS likes this.
post #9 of 15 (permalink) Old Nov 5th, 19, 8:57 PM Thread Starter
It's black. I'll get a few more on here
Thanks Joe
post #10 of 15 (permalink) Old Nov 10th, 19, 8:30 PM Thread Starter
Thanks Joe
Here are the measurements
I thought it was easier to draw it out
post #11 of 15 (permalink) Old Nov 10th, 19, 8:43 PM Thread Starter
Thanks Joe
Here are a few more
It's going to be a long winter!
ID:	607518   Click image for larger version
ID:	607520   Click image for larger version
post #12 of 15 (permalink) Old Nov 11th, 19, 1:59 AM
Greg.
Joe based on your Measurement #s of
OUTSPACE = 5.75"
INSPACE = 7"
TOTAL Wheel Well Space = 12.75"
A. 10" Wide Wheel with a 5.5" BackSpace and a 295/55/15 Tire that has a Side Wall Width = 12.2"
5.49" will be on the Outside less 5.75" OUTSPACE = .26" Room/Clearence from the FenderLip
6.71" will be on the Inside less 7" INSPACE = .29" Room/Clearence from the Frame
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #13 of 15 (permalink) Old Nov 11th, 19, 7:00 AM Thread Starter
OUTSPACE = 5.75"
INSPACE = 7"
Are mine typical measurements, seems like not enough room to me. I will be modifying the exhaust either way as it needs more room with the 275/60/15's
post #14 of 15 (permalink) Old Nov 11th, 19, 3:28 PM
Greg.
My 67 with Drum Brakes and a 60" Wide Rearend has the following #s
OUTSPACE = 5.92"
INSPACE = 7.08"
TOTAL Wheel Well Space = 13"
I run the M/T ET Street S/S # 3454 295/55/15 Tire ( 12.2" SideWallWidth)
on JEGs Sport Star#555-67072 1 pce cast alum A-356alloy 15"x 10" with a 5.5" BS
and have Outside Room/Clearance of .43" & Inside Room/Clearance of .37"
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #15 of 15 (permalink) Old Nov 11th, 19, 7:39 PM Thread Starter
OUTSPACE = 5.92"
INSPACE = 7.08"
I'm going to double check the outspace. That's where I'm coming up short.
Thanks for the help
