Sent nice email to Coker - Chevelle Tech
 27Likes
post #1 of 33 (permalink) Old Oct 27th, 19, 7:17 PM Thread Starter
About my BFG lettering continuously turning brown a few days after I wash them. We'll see if they respond. Spent a lot of money on these specifically for the RWL look. If I don't get at least a sorry and an admission of a defect, I'll be switching to another tire brand next spring.
'72, 385 sbc, Voodoo roller, 219/227; .515/,530 lift; AFR 180cc Eliminators, RPM Air-Gap, 770 Avenger, TH350 trans, 12 bolt 3.42's, Eaton Posi, TCI 2000 stall, Pypes 2 1/2" X-pipe system w/Race Pro's
Vehicle weight: 3390 lbs
Autoengineer_ is offline
post #2 of 33 (permalink) Old Oct 27th, 19, 8:54 PM
RonO.
Re: Sent nice email to Coker
Been dealing with this for several years on a couple of different sets, from different suppliers. From what I've read its rubber compounds seeping through the white lettering. I have found a product that deals with it pretty well, but its a maintenance issue. 2-3 times per year. Interested to hear what Coker has to say, please follow up.
1970 Chevelle 517 cid, TH400, best ET mid 9's. #19.
70SSTHUMPER is offline
post #3 of 33 (permalink) Old Oct 27th, 19, 9:00 PM
We have 2 sets and they both turned brownish yellow. I considered getting white decals made, but after watching the installation video, they clean the letters using acetone. So I gave it a shot and they came out pretty good.
ID:	606466   Click image for larger version
Team Chevelle Member (20 years and counting...
72soft-top is offline
post #4 of 33 (permalink) Old Oct 27th, 19, 10:35 PM
This is not a new problem, when I worked in automotive 20+ years ago there were several products designed to either bleach the white on the tires or paint the white portion of the tires. They are both still available, one was Bleche-Wit and the other was named White Tire Paint, located next to them on the shelf were the products to paint your tires black.
Steve R
Steve R is offline
post #5 of 33 (permalink) Old Oct 28th, 19, 12:36 AM
Kim
this stuff was always the best, works awesome on BFG RWL, hopefully they didn't change the formula.
shelteredv is offline
post #6 of 33 (permalink) Old Oct 28th, 19, 6:26 AM
Yep, I've used tons of that stuff back in the 80s. Also, a Brillo pad works wonders.
71350SS, 69SS454, hydro462 and 1 others like this.
Pioneer4x4 is offline
post #7 of 33 (permalink) Old Oct 28th, 19, 8:20 AM
Lacquer thinner works well too.
hydro462 and 71350SS like this.
mr 4 speed is offline
post #8 of 33 (permalink) Old Oct 28th, 19, 8:32 AM
I like how Diamond back smooths sidewalls to look like the old tires..
https://www.bing.com/images/search?v...x=2&ajaxhist=0
Pete 67 likes this.
hydro462 is offline
post #9 of 33 (permalink) Old Oct 28th, 19, 8:33 AM
I use this all the time, shake up the bottle and use a stiff bristle floor brush to get the job done, try not to inhale the fumes when spraying, it's an irritant and will cause a coughing fit.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #10 of 33 (permalink) Old Oct 28th, 19, 9:42 AM
Yep, you can smell the chlorine in it. Probably similar to Fantastic or Formula 409 really.
We always referred to it as "Blech White" like "Yuck" due to the funky spelling.
post #11 of 33 (permalink) Old Oct 28th, 19, 9:53 AM
Stan
120 grit hard foam drywall sanding block. Try it!
surmin69 and 1775SS like this.
stanski is offline
post #12 of 33 (permalink) Old Oct 28th, 19, 11:42 AM
Al
BAR KEEPERS FRIEND CLEANSER AND POLISH cleanser mild scrub brush, water hose, and cleanser. Try to keep any tire treatments off the white letters as they seem to help the black leach into the white.
DUTCH MAX HEADWORK is offline
post #13 of 33 (permalink) Old Oct 28th, 19, 10:40 PM
This thread reminds me of 45-50 years ago when a Brillo pad and Comet was the go-to product for whitewalls/ RWL along with brake fluid for tire dressing.
spoffie1962 is offline
post #14 of 33 (permalink) Old Oct 31st, 19, 10:01 AM
Any update from Coker? I think some are missing the issue here. We all know chow to clean the white letters, but the BFG T/As lettering seems to turn yellow quickly even without any/many road miles. My thought is the white pigment compounds have changed (probably due to mfg cost).
I used wesleys bleachwite in the 80s and that stuff is excellent. But it does help on these new BFGs.
post #15 of 33 (permalink) Old Oct 31st, 19, 11:13 AM
Sorry. Wesleys does NOT help on the new BFGs
Like I mentioned, Acetone and elbow grease seems to improve the coloring.
