What pressures?? - 235/60/15 & 255/60/15 - Chevelle Tech
 7Likes
post #1 of 17 (permalink) Old Aug 11th, 19, 6:44 PM Thread Starter
Josh
Hi all
Just put 235/60/15 fronts & 255/60/15 tears on my AR TTII’s
They are on my 69 Chevelle 2dr post car
Question - what pressures should I run?
Thanks all!
Bigbadjosh is offline
post #2 of 17 (permalink) Old Aug 11th, 19, 7:01 PM Thread Starter
Josh
I should say it’s running a 350 HO crate and has AC...
post #3 of 17 (permalink) Old Aug 11th, 19, 7:29 PM
Al
Re: What pressures?? - 235/60/15 & 255/60/15
I usually run the tire pressure listed as cold pressure on the side of the tire. If they ride too hard or firm, drop down about 5 psi. Keep an eye on your tread wear, if the center tread appears to be wearing faster than the edges, drop the pressure a little more. If they feel squirmy or the sides of the tires are wearing faster than the center thread area, I'll bump up the pressures.
Kirk's67SS and thebeast like this.
post #4 of 17 (permalink) Old Aug 11th, 19, 9:28 PM
The pressures listed on the side of the tire are for max load, not everyday driving.
oldcutlass is online now
post #5 of 17 (permalink) Old Aug 11th, 19, 9:38 PM
I usually always run tire pressure close to the MAX pressure on the side of the tire but since those tires are over sized for a 69 Chevelle, I'd say probably around 28-30 PSI
IF the vehicle still has factory stock tire size, I go by what it says on the door sticker.
Kirk's67SS likes this.
post #6 of 17 (permalink) Old Aug 11th, 19, 9:44 PM
"Wild Bill"
Same size tires that's on my old Camaro...I run 32 psi
LeoP and boyd66k20 like this.
1967 Camaro SS-Gen I
2017 Camaro RS-Gen VI
2019 Cadillac XT5 AWD
1990 Ford F150 XLT Lariat
BillsCamino is offline
post #7 of 17 (permalink) Old Aug 12th, 19, 6:36 AM Thread Starter
Josh
That’s great, thanks!
post #8 of 17 (permalink) Old Aug 12th, 19, 6:38 AM Thread Starter
Josh
Thanks all for the replies
As they’re not standard tyre sizes for the car I’ll go with first hand experience running these from Bill and see how I get on
Cheers
post #9 of 17 (permalink) Old Aug 12th, 19, 7:51 AM
I have those same tire sizes on both of my cars. I like to be in the 30-35psi range. Anything lower than 30, the sidewalls seem to squat a little too much. And anything higher than 35 seems to make the ride 'harder' going down the road.
v8liveson is offline
post #10 of 17 (permalink) Old Aug 12th, 19, 8:13 AM
Andreas
Location: Germany, Osnabrück (where VW Karmann come from )
my best performance is in front with the 235 - 45 psi, and on rear with the 255 - 30 psi, tires are cooper cobra.
engine is 383‘ stroker without AC....
little Video of my Chevelle Resto:
Andi is offline
post #11 of 17 (permalink) Old Aug 12th, 19, 9:27 AM Thread Starter
Josh
Did you mean 35 and 30 psi?
post #12 of 17 (permalink) Old Aug 12th, 19, 9:56 AM
Andreas
no, i mean 45 psi (or 3,1 bar) in front, 35 psi is to low for me...
Andi is offline
post #13 of 17 (permalink) Old Aug 12th, 19, 10:31 AM
"Wild Bill"
45 psi is too high
post #14 of 17 (permalink) Old Aug 13th, 19, 10:46 AM
Hank
I don't have the same size tires on my car both front and rear. In the rear I will normally run 28 psi in my 275-60-15 tires. In the front I will normally run 32 psi in my 205-75-15 tires. The reason I run 28 psi in the back is to get better bit with the tires and the reason I run 32 psi in the front is because the tires just seem too flat with the weight of the motor on them at a lower pressure.
HKalin is online now
post #15 of 17 (permalink) Old Aug 16th, 19, 9:00 AM
Yes , 45 psi is too high...
SimonJones is offline
