Anyone go from 17s back to 15s? - Page 2 - Chevelle Tech
 39Likes
post #16 of 45 (permalink) Old Aug 4th, 19, 2:14 PM
Greg
I am thinking of changing to 17” wheels the tire selection for 15’s is about 7 mean while the selection for 17’s is about 700. Just an observation from what the market place provides, I for one want a selection of tires not to be told what I can buy because there are only a handful of choices.
Life is too short for caring about every bodies else's stuff
Grock-co is offline
post #17 of 45 (permalink) Old Aug 5th, 19, 12:40 AM
Re: Anyone go from 17s back to 15s?
Originally Posted by hydro462 View Post
Without the whole modern suspension those big wheels with short sidewalls are dangerous! Half the tire lifts off the ground and looses contact during a panic stop with the stock suspension!!
How does a panic stop change the contact between big or small wheel setups?
I have swapped two Chevelles from 15 to 17 inch wheels, and both handled better. Despite the shorter sidewalls, never a problem losing contact...
I even autocrossed my '70, and no negative issues.
stock "Chevelle" discs and suspension, although I did end up later switching to taller upper balljoints on my '70, which made it even better.
TC #1366
Sold
Sold
1966_L78 is offline
post #18 of 45 (permalink) Old Aug 5th, 19, 6:36 PM Thread Starter
Depends on what you are looking for. I want more meat in the rear tires so I actually have less options with 17s than 15s.
Mike Smith
72 Chevelle, LS 6.0 LQ9 4l80e
smitty454 is online now
post #19 of 45 (permalink) Old Aug 5th, 19, 10:12 PM
Originally Posted by Kirk's67SS View Post
Better than the Welds IMHO
Thanks for the response. I just ordered a pair for the rear. I think they look enough like the Prostars that I can run my Weld fronts with them for a while and probably not ever notice the difference.
any4xx is offline
post #20 of 45 (permalink) Old Aug 6th, 19, 1:47 PM
Greg.
I bet you liked the Price difference
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #21 of 45 (permalink) Old Aug 7th, 19, 12:03 AM
I love the look of my 15's with the white lettering. I just wish there was an option for a tire with a more modern tread.
Tire options are the 4-5 companies that make basically the same all season radial, or drag radials.
'72, 385 sbc, Voodoo roller, 219/227; .515/,530 lift; AFR 180cc Eliminators, RPM Air-Gap, 770 Avenger, TH350 trans, 12 bolt 3.42's, Eaton Posi, TCI 2000 stall, Pypes 2 1/2" X-pipe system w/Race Pro's
Vehicle weight: 3390 lbs
Autoengineer_ is offline
post #22 of 45 (permalink) Old Aug 7th, 19, 1:43 AM
Pete
I just went from four 235/70/R15 Rallys
to four 245/45/R17's AR TT2's
to finally four 255/50/R17's AR TT2's
Its only been about a 2 months and 1K miles but i'm loving them.
The car feels a lot more planted.
Now i'm looking at getting a big break kit
__________________________________________
1970-1 Chevelle (307ci w/PG) Now LS 6.0 w/4l60E
Progress Pics.
LS Swap
BigOiBoy is offline
post #23 of 45 (permalink) Old Aug 10th, 19, 6:54 PM
This'll be the last time I drift your thread. I mounted my new tires to the new Vision wheels today. They look close enough to the Weld wheels that I'm not concerned with running them for a while with the Welds up front. There are certainly subtle differences but I doubt that many folks will notice the mismatch.
Hopefully now someone will chime in with their own 15" retro suggestions.
Kirk's67SS likes this.
any4xx is offline
post #24 of 45 (permalink) Old Oct 25th, 19, 4:53 PM
Hi there - I just picked up a 70 SS tribute and it came rolling on ridler 18" chrome 18x9.5 and 18x8 w Nitto tires. The car drives very nice with them and I get tons of compliments, but just not my thing. I cant wait to put some 15" SS wheels w center caps, trim rings and BFG radial TA's. Probably going to compromise the ride quality a bit, but it'll definitely look right again! No offense to anyone, im just not a pro touring, bling wheel kinda guy.
hydro462 and boyd66k20 like this.
Tonys451 is online now
post #25 of 45 (permalink) Old Oct 25th, 19, 5:00 PM
Here’s a pic
post #26 of 45 (permalink) Old Oct 25th, 19, 5:04 PM
And a side view.
post #27 of 45 (permalink) Old Oct 25th, 19, 5:06 PM
You may be pleasantly surprised in going with the smaller wheel. A smaller wheel means a taller sidewall which will likely smooth out your ride.
B52bombardier1 is offline
post #28 of 45 (permalink) Old Nov 21st, 19, 12:50 AM Thread Starter
Those 255/50s on the front look GREAT!!! I was about to order some 15s but now you have me second guessing myself......... I have 17x8s in the front of my Chevelle. Im sure I can pull off those 255/50s
Mike Smith
post #29 of 45 (permalink) Old Nov 21st, 19, 4:54 AM
I went back to 15's for the winter. My 17" tires are summer only. It's nice to see the change, but I can't say I like one more than the other.
ZZ69chevelle is offline
post #30 of 45 (permalink) Old Nov 21st, 19, 9:32 AM
I have a modern suspension front and rear but stayed with the 15 x 7 Rally wheels. The suspension upgrades made a tremendous difference..
People say they need the bigger wheels for brakes, this isn't true at least on a street cruiser it isn't true. I stayed with the stock disc/drum brake system but installed Porterfield pads and rear shoes. Porterfield is the only company that sells there street performance compound on shoes to, that way you have the same compound on all fours.
I also removed the rear self adjusters and manually adjusted the rears, I have side to side bias set perfectly now. The car just stops straight and positive.
I used the SC&C Stage III system on the front along with a big Hellwig bar and a Lee 14:1 box set at 30 pounds for a manual steering feel..
Rear I used Spohn Del-Sphere rear control arms..
Set the alignment to 8/7.5 positive caster, .25 negative camber, 1/32 toe in. Wow what a difference..
ZZ69chevelle and boyd66k20 like this.
hydro462 is offline
