M/T 3355R on 69 - Chevelle Tech
  • 1 Post By SS427Rick
post #1 of 4 (permalink) Old Jun 12th, 19, 12:09 PM Thread Starter
M/T 3355R on 69
Shopping for slicks for my 69SS. M/T 3355R radial slicks 28" diam., 12.2 sect width, 10.2 tread seem to be the closest in actual size to the M/T 295-55-15s that are on my car with 15x10 Weld wheels with 5.5 BS. 1/10th wider tread and 3/10th wider section width than the 295s. Planning on using the same size wheels, just get another set for slicks. Anyone run this tire and have any fitment issues? The 295s fit perfectly, would like the slicks to be the same. Thanks.
SS427Rick is offline
post #2 of 4 (permalink) Old Jun 12th, 19, 12:58 PM
Greg.
Re: M/T 3355R on 69
Rick do you run the 1/8 or 1/4 ?
the 3355s are 29 lbs X5 compound
what about Bias-Plys M/T # 3055 only 23 lbs M5 Compound
https://www.jegs.com/i/Mickey-Thomps...3055K/10002/-1
the 295/55/15s M/T ET Street S/S have a R2 compound and if I remember right
one TCer said they are as good if not better than some Slicks
the Chart under the Overview Tab shows that R1 Compound is Softer than M5 & X5 Compounds
https://www.jegs.com/i/Mickey-Thomps.../3055/10002/-1
I guess a Slick with the L8 compound would be better !?
I am running the 295s at the Track and I am very happy with them
also bought some for the street
The next time I go to the Track I will be testing out the newly rebuilt TH400 with a Manual Reverse VB
and a new 9.5" Torque Converter with a Stall of 3,500 to 6,500 rpms
previously only had a 2,500 Stall Converter
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is online now
post #3 of 4 (permalink) Old Jun 13th, 19, 10:10 AM Thread Starter
Re: M/T 3355R on 69
I run 1/4 mile. Stopped in at the local speed parts place yesterday to order another set of wheels just for track/slick use and the owner has a set of Hoosier bias slicks for me to try out. 18155s C07 compound. He runs the same tire on his Shelby GT500. His Shelby is a stick car with over 1100 rwhp, runs mid 9's. Has also been 200 mph at the Texas Mile. He drives it to work. LOL. He says the Hoosiers work best for the 1/4 on his Shelby and he has tried quite a few tires.
I also run the MT 295-55-15's but they don't seem to hook until the tread is totally gone at the end of the season. Last year I was running 11.45s with 1.52 60ft. This year with new MTs, same tire, I am back to 12.2s. 1.7-1.8 60ft. Spinning every pass. Time for some sticky slicks. Street nights at S.I.R. are basically no prep/very little prep so sticky is good. I will give the Hoosiers a try and see what happens. I will use the MTs on the street.
Kirk's67SS likes this.
post #4 of 4 (permalink) Old Jun 13th, 19, 3:54 PM
Greg.
Re: M/T 3355R on 69
Before I went to the M/T ET Street S/S 295s in 2018 I had been using
M&H's Bias Ply Muscle Car dot Drag Tire MSS-001 Bias-Ply 275/60/15 Wrinkle Side Wall
........Tread Width: 10" / SideWallWidth: 11.7" / Dia: 28.2Ē
Ran a Prev Best time with them of ;
60' = 1.756
1/8 = 7.815 et / 89.06 mph
1/4 = 12.253 et / 111 mph
Tried a pair of HOOSIER QT DOT Drag Tires Bias-Ply 17110QT 275/60D/15
............. Tread Width: 9 or 10" / SideWalls Width: 11.8" / Diameter: 27"
But found them to be not as good as the M&Hs
Born 283 / PG / A51
60' = 1.664
60' = 1.547
