Got 15x10s to fit!! - Chevelle Tech
 5Likes
  • 3 Post By __matt__ss__
  • 1 Post By Kirk's67SS
  • 1 Post By any4xx
post #1 of 12 (permalink) Old Mar 17th, 19, 10:12 PM Thread Starter
Got 15x10s to fit!!
I read a couple of post on how people said that you can’t fit a 15x10s w 28x11.5/15 et street slick under a chevelle without having some rubbing issues. Well my car already seemed to have some rolling of the quarters. So I gave it a try and they fit like a glove! So happy with how they look👍🏼👍🏼. I found a set of 15x4 weld wheels at super chevy with brand new front runners and went with the cheaper Jegs brand weld wheel knock offs in the back and they look great to me! Just wanted to share this on the page because I was about to return the wheels before I even tried them out, but good thing I didn’t!
ID:	589332   Click image for larger version
ID:	589334   Click image for larger version
ID:	589336   Click image for larger version
davewho1, kermitsass and Blown1932 like this.
__matt__ss__ is offline
post #2 of 12 (permalink) Old Mar 18th, 19, 12:26 AM
Graham
Nice!
6T9 Chevelle is offline
post #3 of 12 (permalink) Old Mar 18th, 19, 1:35 PM
Greg.
Re: Got 15x10s to fit!!
Originally Posted by __matt__ss__ View Post
I read a couple of post on how people said that you canít fit a 15x10s w 28x11.5/15 et street slick under a chevelle without having some rubbing issues. Well my car already seemed to have some rolling of the quarters. So I gave it a try and they fit like a glove! So happy with how they look👍🏼👍🏼. I found a set of 15x4 weld wheels at super chevy with brand new front runners and went with the cheaper Jegs brand weld wheel knock offs in the back and they look great to me! Just wanted to share this on the page because I was about to return the wheels before I even tried them out, but good thing I didnít!
I would guess you did not read enough/the right Threads then !
With the correct Back Space on any Width Wheel (8" to 10" Width Wheel) they will fit
especially in a 68 to 72 Chevelle which has wider Wheel Wells than
us 67 and prior Chevelle owners, who have less room in the Wheel Wells
Are those M/T ET Street R Bias-Ply Tire 28 x 11.5R15 # 3554s ?
https://www.jegs.com/i/Mickey-Thomps.../3554/10002/-1
Dia = 27.7" / Tread Width = 8.7" / Section Width = 11"
if so they are not as Wide as the Tires I have on my 67
https://www.jegs.com/i/Mickey-Thomps.../3454/10002/-1
Dia = 27.8" / Tread Width = 10.6" / Section Width = 12.2"
you can see them on my 67 in my Garage in the First Album at the Bottom of the page
I also have the JEGs Sport Stars Wheels on my 67 with the ET Lug Nuts
which provide more support than the Acorn Nuts do
Your car looks great with the Wheel/Tire Combo you have on it
Clint44 likes this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #4 of 12 (permalink) Old Mar 18th, 19, 10:34 PM
Looks good!
dell72 is offline
post #5 of 12 (permalink) Old Mar 19th, 19, 9:48 AM
Lew
What was the offset on the rears to get them to fit?
Lew540 is offline
post #6 of 12 (permalink) Old Mar 19th, 19, 9:57 AM
5.5" backspace is what works on 70-72 Chevelles
dell72 is offline
post #7 of 12 (permalink) Old Mar 19th, 19, 7:49 PM
10" width with 5.5" BS is about the limit before the rim interferes with the lower shock mount. Probably could just about fit a 295/55-15 MT Drag Radial in there.
Status: Car-Less
GRN69CHV is offline
post #8 of 12 (permalink) Old Mar 19th, 19, 8:55 PM Thread Starter
I guess the et streets run a little skinnier which works in my favor. You arenít running extended studs for at the race track?? I would for sure go with those lugs if I didnít have to worry about going with longer studs for at the track. Also hoping my car runs as good as yours does!! Your car looks perfect👌👌
post #9 of 12 (permalink) Old Mar 19th, 19, 9:13 PM
Do the Jegís knockoffs use that same floating steel center section as the Weld Prostars?
any4xx is offline
post #10 of 12 (permalink) Old Mar 20th, 19, 2:41 PM
Greg.
Yes I have the Longer Studs for Inspection
I have these ET Lug Nuts that are Open Ended 1/2" 20 Thread
https://www.jegs.com/i/Billet-Specia...99984/10002/-1
they also have 7/16"
Thank you for the kind remarks, but she is not perfect as she is a Driver
and she gets me from A to B on the Weekly Cruzins and to Friends/Relatives a 100 Miles away
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #11 of 12 (permalink) Old Mar 20th, 19, 2:54 PM
Greg.
NO
they are completely solid and 1 piece
You may need longer Studs for them as they are pretty Thick in the Center
have these on the Front
https://www.jegs.com/i/JEGS/555/66062/10002/-1
have these on the Back
https://www.jegs.com/i/JEGS/555/66086/10002/-1
Use them at the Track and on the Street and love them as they are under $ 100.us
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #12 of 12 (permalink) Old Mar 20th, 19, 3:49 PM
Originally Posted by Kirk's67SS View Post
NO
Thatís good to know. I love the look of the Prostars, but it took me a few months to find a tire shop within 100 miles of me that had the proper lug-centric adapter to balance them. A couple of shops tried the regular hub-centric cone system to balance them and it just would not work. You could see the wheel & tire moving up and down a full 1/4Ē as they spun. Now Iím wanting to pass these Weld wheels on and get a similar set from Jegís.
Kirk's67SS likes this.
any4xx is offline
did an experiment - 66 carpet set in a 68 and it fit great! RAMBO Interiors 7 Sep 9th, 17 11:49 PM
Which 12 bolts fit 66 chevelle Dansk Transmission & Driveline 11 May 26th, 17 1:21 AM
PUI bucket seat covers don't fit 1965 Chevelle statenine Interiors 17 Jan 4th, 17 7:23 PM
Griffin Direct Fit Radiator Fit Sucks! KaiserLT1 Heating & Cooling 8 Sep 5th, 16 10:54 PM
65 Malibu w/396. Can't find headers/ex. manifold that fit vegasjones Engine 19 Sep 12th, 13 5:39 AM
