Weld Drag Lites - Chevelle Tech
 4Likes
  • 1 Post By any4xx
  • 2 Post By Tommy the Cat
  • 1 Post By zzzgott
post #1 of 9 (permalink) Old Mar 12th, 19, 11:12 AM Thread Starter
tom
Weld Drag Lites
Just tried to put a set of Weld Draglites 15X10X5.5 backspace on a stock rear end suspension 70 Chevelle Malibu and the wheels hit the lower shock support.
Weld said they would fit, but they didn't.
Cleared the wheel well with Mickey Thompson 275X60RX15 Drag Radials just fine, but not the wheels. I have Weld Draglites 4.5 backspace on the car now and they fit. I have seen where others have the 5.5 backspace and they work on a stock rear end 70 Chevelle, but not mine. What I'm I missing?
Thanks for any info
Tom6870
Tom6870
tom6870 is offline
post #2 of 9 (permalink) Old Mar 12th, 19, 12:37 PM
Re: Weld Drag Lites
I put Weld Prostars on my ‘68 El Camino. 15x9 with 5.5” BS. I had to grind about 1/8” off of the lower-rear-outboard corners of each shock mount for clearance.
any4xx is offline
post #3 of 9 (permalink) Old Mar 12th, 19, 12:38 PM
Hank
Re: Weld Drag Lites
My 71 Malibu has a 69 Chevelle 12 bolt in it and I'm running 15x8 rims with 5.5 BS. I put a 1/4" spacer in only because I saw a slight rub on the lower rear inner fender radius but no problems with the shock mounts.
HKalin is offline
post #4 of 9 (permalink) Old Mar 12th, 19, 12:41 PM
Re: Weld Drag Lites
Oh... and have fun balancing them. It took me weeks to find a shop that had the lug-centric adapter required to properly balance my Prostars because of that ridiculous floating center section. I love the wheels, but not sure I’d ever buy this type again just because of the hassle in balancing them.
any4xx is offline
post #5 of 9 (permalink) Old Mar 12th, 19, 12:46 PM
Re: Weld Drag Lites
I have the same wheels, no grinding necessary. Seems there's some variation on shock mounting. My 12 bolt is from a '72 wagon.
70 Camino...Roller
Tommy the Cat is offline
post #6 of 9 (permalink) Old Mar 12th, 19, 12:59 PM
Re: Weld Drag Lites
And to make it even better.... my right side hit the mount, but not the left. I’m running 295-65-15 Mickeys and had to relieve the heck out of the drivers side inner fender for clearance. The passenger side barely touched anything. But my stock rear suspension bushings are shot. I hope to put all new bushings on in the next few months and hopefully tighten things up a bit. These cars are definitely a collection of tolerance stacking.
Clint44 likes this.
any4xx is offline
post #7 of 9 (permalink) Old Mar 12th, 19, 1:19 PM
Re: Weld Drag Lites
True story. Not to mention your body may not be centered on the frame and your rear axle may not be centered either. I have new body mounts, all new adjustable control arms, perfectly centered body and axle and my 275/60s are a very tight fit. There's guys on here that have 315s on stock cars just like mine but there's no way they would fit on mine. Guess they stacked the tolerances on the tight side for mine.
Clint44 and Kirk's67SS like this.
70 Camino...Roller
post #8 of 9 (permalink) Old Mar 19th, 19, 12:42 PM
Re: Weld Drag Lites
I redrilled the mounting hole for the shock mount about 7/8" higher. Easy fix and allows a little more room to get the tire changed when the car is on jack stands
any4xx likes this.
zzzgott is offline
post #9 of 9 (permalink) Old Mar 20th, 19, 1:31 AM
Vince
Re: Weld Drag Lites
my 15x8x5.5''bs draglites
just cleared the wheels
if there was some flat weights stuck to the wheel it would have had hit or contact.
but no issues...
VinceS427bb is offline
MIG, TIG or GAS weld which is best and worst for sheet metal ? Doright Body Shop 18 Oct 25th, 18 11:05 AM
Dragstrip DRAG RADIALS: 295/55/15 ET STREET S/S or 275/60/15 ET PRO? rel3rd Performance 96 Mar 27th, 17 11:50 AM
Optimizing a drag car Iforgot Performance 27 May 22nd, 16 12:50 AM
Help with drag tire choice pockets Performance 15 Apr 1st, 16 11:27 AM
Butt weld vs. flange weld geo's 66 Body Shop 41 Jan 26th, 15 12:26 AM
