67 Chevelle - New wheels & tires - Page 2 - Chevelle Tech
 8Likes
post #16 of 44 (permalink) Old Jan 15th, 18, 12:12 PM
Kevin
Re: 67 Chevelle - New wheels & tires
I have 17x8 front and rear on my '67. BS is 4.75" with 235/45-17 and 265/45-17 front and rear respectively. There is about 1/2" of clearance both front and rear from lip to tire. I have UMI 2" drop springs with stock spindles up front and Baer 14" rotors and brakes. Both tires tuck up into the wheel wells slightly. The challenge with wider wheels and tires is rubbing on the front inner fender on compression. Mine does not have any. I used to have drop spindles but didn't like the issues they caused and decided to get the stance with springs.
"If you're not living on the edge, you're taking up too much space" - Jim Whittaker
AFR Eliminator 195's
Inglese 50mm 8 stack injection
FAST XFI Street
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Tremec TKO 600
Chevy67 is offline
post #17 of 44 (permalink) Old Jan 15th, 18, 12:51 PM
Thats what I was running in to with my 66. I ended up going with 17x7, 4 BS in the front and 225x50 tires just to make sure it was tucked in away from the fender lip. Worked out great.
Test fitting the above to my rear, Im going with 17x8, 4.75 BS like you, but smaller tire, either 245 or 255. Anything bigger it looks like Itd be pushing it.
yanniziomas is offline
post #18 of 44 (permalink) Old Jan 15th, 18, 12:52 PM
Originally Posted by map95003 View Post
Thanks everyone. I think I'll go with this combination, hopefully I can find some reasonable priced, decent tires with this combination.
Rims & Tires:
Front rims: 17x8, 0 offset. Tires: 225/45R17. This will be me a 25" diameter, 9" width and 4" sidewall.
Rear rims: On the fence between these 2 options. A few of you guys also reached out to me on the rear wheel offset which I really appreciate. Would a offset of 6 be enough for 285s?
18x9.5, ?? offset. Tires: 275/40R18. This will give me a 26.7" diameter, 10.8" width and 4.3" sidewall.
18x9.5, ?? offset. Tires: 285/40R18. This will give me a 27" diameter, 11.2" width and 4.5" sidewall.
On the rear of my '66 (with a stock 66 rearend), I could fit 17X9.5 with 275/40/17 with BOTH 6.0" BS AND 5.5" BS... The 6.0" BS will be close to the inside tub, while the 5.5" fit really well...
IMO, the 9.5 wheel with the 6.0" BS looked goofy, as the wheels/tires seemed to sit INSIDE too far...
Then again, with deeper back spacing, you can use a spacer to fine tune the location...
BTW, I ran 275/40/17 on 17x9.5 wheels all around... But due to the C5 Corvette disc swap up front (Kore3) and the thin spacer allowing the wheel to clear the caliper (weld bead between the center-section and barrel of rim rubbed the caliper fins), I had to run a 6.0" BS on the front... I wanted to run the same wheel/tire on front and rear, so I tired the 6.0" BS on the rear... Too much clearance (visually) at the outer quarter panel lip, IMO... So I ended up with the 5.5" BS on the rear (plenty of clearance for a rear disc conVersion, which never happened until after I sold the car).
Here is the 5.5 BS, although not a great picture..
true136 likes this.
TC #1366
Sold
Sold
1966_L78 is offline
post #19 of 44 (permalink) Old Jan 15th, 18, 2:55 PM
14" Baer brakes inside a 17" wheel? I'd really like to see photos of that,Kevin.
Clint44 is offline
post #20 of 44 (permalink) Old Jan 15th, 18, 3:23 PM
On a 66-67, a 275 front and 295 rear are considered big. Personally, I've never understood why people want to use a 17x7 or 18x7 wheel w/225 tire, on such a heavy vehicle. At a minimum, I would run midrange widths, with a 245 front and 275 rear. Just my opinion,though.
Anything wider than a 255 on an 8" width wheel is too much. According to Nitto, my front 255/35/18 555 G2's need a 9" width, for optimum performance.
Many people that own these cars tend to underestimate how much fenderwell room their cars really have. Where's Greg when we need him?
Clint44 is offline
post #21 of 44 (permalink) Old Jan 15th, 18, 3:29 PM
Originally Posted by 1966_L78 View Post
On the rear of my '66 (with a stock 66 rearend), I could fit 17X9.5 with 275/40/17 with BOTH 6.0" BS AND 5.5" BS... The 6.0" BS will be close to the inside tub, while the 5.5" fit really well... IMO, the 9.5 wheel with the 6.0" BS looked goofy, as the wheels/tires seemed to sit INSIDE too far...Then again, with deeper back spacing, you can use a spacer to fine tune the location...
So what you're saying, Tony, is a 9.5" width wheel w/5.5" backspace will fit fine, on either front or back of a 66-67, under normal conditions (stock brakes)
Clint44 is offline
post #22 of 44 (permalink) Old Jan 15th, 18, 7:37 PM Thread Starter
Thanks for your help. I've learnt quite a bit about wheel size and configuration from you guys here over the last few days...which definitely makes my decision a bit easier. btw, great looking 66
map95003 is offline
post #23 of 44 (permalink) Old Jan 15th, 18, 8:00 PM Thread Starter
With all the help I got from everyone explaining rims & tires, back spacing, offset, diameter, width, rearends...this all makes a lot more sense now. Been playing around with the numbers for various tire brands, sizes and $$. Based on what I know now and my budget, here's what I think I'm settling on:
Fronts
Rims: 17x8, 0 offset.
Tires: 235/45/17. This will give me a 9.3" width, 25.3" height and 4.2" sidewall. With the 2" BMR lowering springs currently on the front, this should be OK.
Rears
Rims: 18x9, 0 offset (I was able to save a few $$ going from 9.5" down to a 9" rim)
Tires: 275/40/18. This will give me a 10.8" width, 26.7 height and 4.3" sidewall. I wanted to go with a 9.5" rim and a 285 tire, but not sure it was worth the added $$.
The rear currently has a set of 1" lowering springs but I also have a new set of BMR 2" rear lowering springs that I'll use if the back end up sitting too high.
Thanks again for all your help everyone, really appreciate it.
map95003 is offline
post #24 of 44 (permalink) Old Jan 15th, 18, 9:03 PM
I would measure your front and make sure it fits. I understand what others say it should fit, but I do have a set of wheels and tires that I just bought and installed 2-3 weeks ago and I can see exactly what fits and what wouldnt.
What youre getting, would not fit in my 66, disc brakes. Your 8, is 9 overall and would leave 4.5 from the hub to the front (0 offset.)
Mine is 7, 0 offset which means 4 from hub to front. See pick below. No way another 1/2 wheel, plus 1/4 tire (mine is 225) would fit without hitting, Im looking at it right now.
Around 2+lowered, Ridetech street grip springs with 0 miles.
Its a pain to get it right, I used my old 14 wheels to estimate and got the width/clearance perfect.
post #25 of 44 (permalink) Old Jan 15th, 18, 10:41 PM
Let me get this straight, yanniziomas, you're trying to convince me a 17x8 wheel w/4.5" backspace (0 offset) and a 235 tire won't your 66, without clearance issues? Unless your car has some outlandish suspension parts or brakes that have widened the track a bunch, which I doubt, that wheel & tire combo should fit easily with room to spare.
Clint44 is offline
post #26 of 44 (permalink) Old Jan 15th, 18, 10:54 PM
Hey Clint, maybe because the car is lowered, or could it be because its 4 door car? Dont know, my knowledge on all this is limited, but I can guarantee you (standing in front of it right now with a tape measure) I have no room on the outside for another .5 - .75.
Glibal west control arms, disc brake spindles, all new front suspension and steering. Maybe something is out of order, dont know.
Also, mine is a 66, think same as 67 but not sure.
post #27 of 44 (permalink) Old Jan 15th, 18, 11:12 PM
Global west control arms, disc brake spindles, all new front suspension and steering. Maybe something is out of order, dont know.
Did you consider that a 17x8 w/0 offset, will have 1/2" more backspacing than your 17x7's w/4", so for all practical purposes, both outer wheel faces would be located in the same place, in the wheelwell?
66-72's have practically the same amount of front wheelwell room. If you are close to me, I would be glad to pull off one of my 18x8 fronts w/255 tires and bolt it on your car. BTW, my car has at least a 2" front drop.
Clint44 is offline
post #28 of 44 (permalink) Old Jan 18th, 18, 3:57 PM
Ken
Here's what mine came with when I bought it last July.
Front: 225-50R17
Rear: 255-50R17
Wheels are rally style 17" one-piece (not separate trim ring)
ID:	514761   Click image for larger version
67 Chevelle Malibu, ZZ4 350 crate engine, TH350, FiTech EFI, Vintage Air, Dakota HDX dash, FlowMaster exhaust, Digi-Tails tail lights and front marker lights, 17" Rally style wheels, Redline tires
darksky is offline
post #29 of 44 (permalink) Old Jan 18th, 18, 11:19 PM
Kevin
Hey Clint - They are old Baer Track 4 brakes and yes they do fit. Been driving with them for 7 years. They use the older C4 aluminum 2 piston calipers not the newer 4 or 6 piston calipers which will not fit according to the Baer rep at SEMA.
FAST XFI Street
Tremec TKO 600
Chevy67 is offline
post #30 of 44 (permalink) Old Jan 19th, 18, 12:07 AM
I had the Baer Track system on the front of my 69 Elco protourer but it used 13" two-piece rotors/ PBR calipers, like yours. They were a comfortable fit on my 17x9 front wheels.
The Track + system used a 14" rotor w/Alcon calipers. Big bucks for those. I know because I was a Wholesale/Distributor for Baer, back then.
Have you ever tried to buy new brake rotors, in that size? If you ever decide to upgrade, I would be interested in your front brakes.
Clint44 is offline
This Thread is more than 880 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
