Wheels for my 65 SS - Page 2 - Chevelle Tech
 5Likes
post #16 of 26 (permalink) Old Dec 7th, 17, 5:42 PM Thread Starter
Re: Wheels for my 65 SS
Man, I really regret asking for advise... I am more confused than ever.
I have been shopping around and like the Foose wheels the best, but I guess my first choice is not to be. They would look perfect with the new paint job. As purchased and after paint pics included.
Name:	as received (26).JPG
ID:	500841   Click image for larger version
Name:	new paint (1).jpg
- Mike
burrism is offline
post #17 of 26 (permalink) Old Dec 7th, 17, 5:51 PM Thread Starter
Clint - Maybe I am confused on the backspace calculation, but an 8" wide rim with 0" BS (or 1mm offset), wouldn't that be a 4" backspace? Wouldn't this give me an extra half inch of space between the tire and lip.
- Mike
burrism is offline
post #18 of 26 (permalink) Old Dec 7th, 17, 7:07 PM
8” rim with 0 offset is 4.5” backspace, it’s little confusing, 8” wheel measures 9” on the outside edges.
yanniziomas is offline
post #19 of 26 (permalink) Old Dec 7th, 17, 7:32 PM
Clint
Yann is correct. Once you understand how to figure that out, it becomes less confusing because some wheel makers list their wheels with available backspace and others list them with offsets.
To carry this a little further, one inch = 25.4 millimeters. Let's say an 8" wheel is listed as having a +6 offset. We already know that width with 0 offset = 4.5" backspace. +6mm is close to 1/4", that would mean that a 8" wheel with +6 offset = 4.75" backspace. That width with +12 offset = 5" backspace. Make sense? This also works in reverse with negative offsets. An 8" width with -6 offset = 4.25" backspace and so forth.
For that reason, I do not recommend negative offset wheels on these cars, unless your particular application specifically requires it. (narrowed rear end,etc)
burrism likes this.
Clint Hooper
Sold
Clint44 is offline
post #20 of 26 (permalink) Old Dec 7th, 17, 8:05 PM
Clint
Originally Posted by burrism View Post
Man, I really regret asking for advise... I am more confused than ever. I have been shopping around and like the Foose wheels the best, but I guess my first choice is not to be. They would look perfect with the new paint job.
As long as you don't try to go bigger than a 245 tire,on the rear, I think you will be ok with those Foose wheels, barely.
burrism likes this.
Clint Hooper
Sold
Clint44 is offline
post #21 of 26 (permalink) Old Dec 9th, 17, 12:54 AM
Originally Posted by Rich-L79 View Post
On a 17x8 wheel I found a (custom) 5-1/8" back spacing to be perfect for maximum clearance. I used 255/45-17s on the back on such wheels but given the clearance I have I could have easily gone with a 275/45-17 tire. Up front with a 17x7 with a 4-3/4" back space and a 235/45-17 tire there is no room to spare for a larger tire, more back spacing would jam it into the sway bar on turns and less would have it rubbing on the fender and inner fender. This was with a 2-inch drop up front dropping it using aftermarket control arms and tall spindles (well, stock spindles with tall ball joints).
My wheel specs are the same, and the manufacturer happened to have a 4 for the price of 3 deal on custom orders. My tires front and back are approx 26 in. Diameter at 255/45-17 and 225/50-17, Conti Extra Contact DW.
MikeMalibu is offline
post #22 of 26 (permalink) Old Jan 7th, 18, 2:57 PM Thread Starter
I finally got the new wheels!
225/45/R17 Foose in the front and 245/45/R17 in the rear. zero offset and everything fits like the Foose web site indicated. Data was loaded into the wheels and tires database.
Thanks for all the help!
ID:	510218   Click image for larger version
ID:	510226   Click image for larger version
- Mike
burrism is offline
post #23 of 26 (permalink) Old Jan 7th, 18, 5:58 PM
Clint
Glad to hear it,Mike. One question though, how are the front clearances with your drop spindles?
Clint Hooper
Sold
Clint44 is offline
post #24 of 26 (permalink) Old Jan 7th, 18, 9:03 PM Thread Starter
Clint - everything appears to be good (I only got them yesterday). so far no rubbing on the fender well or frame or suspension components. I will look at it more closely in the next day or two when it is in my garage and off the ground.
- Mike
burrism is offline
post #25 of 26 (permalink) Old Jan 8th, 18, 12:18 AM
Clint
I'm curious about your rear tire clearance, with those zero offset wheels.
Clint Hooper
Sold
Clint44 is offline
post #26 of 26 (permalink) Old Jan 8th, 18, 10:44 AM
Rich
The rear wheels look awful far back in the wheel well.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
This Thread is more than 705 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
